plastic insulation fixings with torch on felt
Russell griffiths replied to netmonkey's topic in Flat Roofs
Two ideas, 1,you will need to countersink those tubes into the ply or you will have a little hump in your roof covering, so why not countersink a little extra and fill flush with a bituminised thick paint type of stuff. 2, why not use the insulation with ply glued to it purposely for roofing. Kingspan also do an insulation board especially made for torch on felt. No ply needed. -
I sort of agree with the ward member, the new design doesn’t have much wow factor compared with the old house thinking back to when the old one was built it was probably very grand and drew plenty of admiration, whereas the new one looks a bit lacking. I can see from the drawings it could be the way it has been produced, so maybe some new drawings with a different printing process. Apart from increased footprint I cannot see a reason for refusal. Regarding increase in size, have you looked at how big you could make the current house under permitted development ? we did this, we stated that our current place could be increased massively, to be nearly as big as the proposed one, after we bought this to the planners attention it passed.
Very impressed with my aluminium, powder coated stuff, extremely well made and fits the look of the house well.
I've had it with steel rools
Russell griffiths replied to ToughButterCup's topic in General Self Build & DIY Discussion
I have recently bought a. Milwaukee Stud tape measure. Best tape I’ve ever used, all metric, large numbers ( important for you old people) can be read from both directions, i will look for a wooden one, I think I was given a couple by the Siga rep. -
Relatives working on site.
I’m a bit disappointed I cannot have my life over again as I believe the amount your average bloke in the street can do is getting less and less each year, I firmly believe the multi skilled man will be able to change whatever they want to do the simplest of tasks, as your average bod is incapable of changing a plug. -
As with everything it depends on your actual spec you want. i have seen some very poor skimming jobs and terrible boarding, yet have seen some fantastic tape and jointing. If you specify a top notch then taping and jointing will look and last equally to skimming.
Hi where abouts are you.
Have you considered bent and fabricated i paid £740 tonne but that was fully fabricated, only had to tie corners on site, saved hours and hours of work.
Nervous as to what might be under the concrete
Russell griffiths replied to MortarThePoint's topic in Demolition
Not necessarily, it’s actually fairly safe if not disturbed in a way to make dust, I would be happy to bury it on my site if I new it would never get disturbed in the future. -
Cabinet glass shelves light up green, any simple fix?
Russell griffiths replied to Wagas's topic in Kitchen Units & Worktops
glass is surprisingly cheap, why not ask at the local place for a different type. -
This is by no means the correct advice, but does it need to go off site, do you have enough land to do other things with it ? how about hardcore under a detached garage. A person i know ended up with a lot of large concrete that he didn’t know he had, so dug out another area on site and buried it. Under the driveway ? As I said by no means correct advice, but sometimes you just have to do what you have to do. Reading back through your post, my friend had far more than 45m that should be 3 truck loads, so reasonably easy to re,distribute under a driveway. -
Push the metal bit in the live side of a socket and then stick your tongue on it you know how you used to with those 9volt square batteries.
1. Yes 2. You can change to whatever you like above dpc, but is it worth it for 1 course. 3. Below dpc bricks need to be frost proof, so maybe a class b engineering brick in red then swap to face brick above dpc. 4. You really need a section drawing of your wall build up as you don’t want a cold bridge at floor level or a cold sole plate, so it needs to be designed to have an insulation layer in the cavity to prevent this, also a tray dpc to prevent water inside the cavity reaching the inner frame. You need to get this design right before you lay to many blocks.
Omg as im sitting here bored I thought I would google RESTRAINT STRAPS well that turned up a few images I hadn’t thought I would see at 7.30 in the morning. ??
What you need to consider is where you live, the timber frame house I built in Australia was held down by large threaded rods that went from the roof to the foundation, these are known as cyclone straps. Over in good ol sunny England cyclones are a rare thing so wind uplift is not really required, so a simply system like the two listed is all that is required. You should check with building control though though to see what they like.
I thought he said he was up to damp, when his friend said why you using dense blocks. Will re read.
Are you not using 100mm for outer skin or have I misread something.
I have used the same membrane and not found any problems, in fact I was surprised how good it was. I personaly wouldn’t be happy with the bit that has separated. I had seen an e bay seller with this but decided to buy from the merchants as it was reasonable priced. If you need some I think I have half a roll knocking about if it will get you out of trouble over Christmas.
Don’t use aircrete they are proper shit, use a concrete block but light weight, they are sometimes called ag-lights, look very similar to dense concrete but have a proportion of lighter materials incorporated. Go to your merchants and see what is available.
I brought mine direct from the manufacturer, they normally come in 50 mm increments so might be 25-30 mm long but that just allows for a bit of wiggle room, didn’t cut any of mine. Builders merchants prices where a good £6-800 dearer.
Well done. Enjoy it, don’t turn it in to a nightmare, be realistic with timescale and cost and it will be fun.
Negotiating a project fee
Russell griffiths replied to H F's topic in General Self Build & DIY Discussion
This depends on a few things. Do you feel that you have a job this contractor wants or do you Need this contractor theres no harm in asking but it depends if you feel you are in the driving seat or not. I personally wouldn’t be offended, but my price wouldn’t change. You dont go in the butchers and say I like your sausages but will you take £2.20 kg instead of £2.50.
