Garden buildings
Russell griffiths replied to Russell griffiths's topic in General Self Build & DIY Discussion
With all the talk about screw piles and garden rooms next to trees I thought this would be a hotbed of conversation. -
Did you expect it to be that exact that each piece wouldn’t be plus or minus 1-2 mm. Mark your corners and work towards the centre, trimming the centre block to fit. Sorry but it’s not the space shuttle plus and minus 1-4 mm per block would be fairly normal with eps. If building in icf you start at the corners and have a straight or common joint that you cut to relax the difference in block sizes. Its just the same with laying bricks or blocks, the mortar will allow adjustments, being youhave no mortar you trim to fit.
There has been a bit of chat lately about garden buildings, I’m watching this so thought I would share it.
Oh god, don’t. I’m having some serious loss of sleep after fitting all our windows this week.
Evening all has anybody used a company called. Underfloor heating supplies, based in Leicestershire. Just looking for a bit of feedback. Ta very much.
6mm cement sheet, something from James hardy. I have used a smooth faced version before and it paints really well.
Block choices for foundations above ring beam
Russell griffiths replied to dnb's topic in Foundations
You won’t find a 215 solid, they are too heavy and I don’t think they even make them any more. You normally use a 100mm block laid on its side, two courses brings you back up to height. If you get the right blocks you can you can probably save a chunk of cash by having a full load, as you can use them in the block floor as well. -
Anybody willing to offer any advice.
Russell griffiths replied to Big Jimbo's topic in General Construction Issues
Why not put a small section of electric ufh in shower room and a heated towel rail, nothing worse than a damp towel or a cold floor when getting out of the shower. The rest can be added if needed as long as you install extra power points, an oil filled rad on a timer should keep it warm enough. -
Why are you thinking of permitted development? get planning and building regs for what you want, don’t build something that doesn’t fit your purpose just because you can get it under permitted development. How big is the building there already, I cannot see any reason you can’t replace it.
Self-build on Family Farm
Russell griffiths replied to A-String's topic in General Self Build & DIY Discussion
I would go and find a local planning consultant, best £4000 I’ve ever spent. They will know every loophole and local planning policy off by heart.- 4 replies
- farmland
- self-build
It is like a closed cell structure rather than the rice crispy type. Dries to a firm rubbery texture instead of dry and crispy.
I’m just fitting my windows so I thought I would share this info. If you are after a better quality low expansion foam look at the products made by ILBRUCK I’m using their FM330 and it is on another level compared to the normal crap. Same price as all all the other brands if you buy a box. Thats all.
HEP: distance between clips ?
Russell griffiths replied to ToughButterCup's topic in General Plumbing
Are they insulated? i would avoid too much contact with the metal in the pozi joist, I know they have rounded edges but I would still try and avoid contact in case of vibration and wear on the plastic. -
Can you do me a favour and buy a broom. ?????
I suppose this all depends on your budget, and what you want to end up with. If you repair what you have there it will always be a bit of a compromise. If you want a nice workshop with heating good light and a flat floor you would be better off flattening that and starting again. I see no reason why you won’t get consent to replace it with a better built and better looking building.
Be very carful with the community infrastructure levy, if this is not going to be a self build for yourself. Have a good read before you even put a spade in the ground.
Drilling screws into lime floor slab help!
Russell griffiths replied to Snowbeetle's topic in Floor Structures
+1 to stick them down.- 15 replies
- lime
- partition walls
It’s a funny old world, when I got quotes for mine I thought transport would be expensive, so I looked for local firms. Then I read on here that I could have got them cheaper in Ireland including the transport, so I think the best thing is just send your plans off to two or three companies and see who you like. Concrete products are very cheap in Ireland.
Floor drain: can I get away with ...
Russell griffiths replied to ToughButterCup's topic in Waste & Sewerage
How high is your water table, any chance if you leave it you might get water coming up, or that it won’t drain like it is if water table rises. If you answer no to both then why not leave it alone. I know someone who installed a shower in an outbuilding with no drain just a pipe out the wall into the field next door. -
Have you tried IRONMONGERY DIRECT. or one of the other online screw suppliers,
DIY design for a brick cutting jig.
Russell griffiths replied to epsilonGreedy's topic in Brick & Block
I’m not sure if you realise but the cut does not need to be accurate as the cut face will not be seen, it is the end of the brick that will be laid as the face. -
Go and hire a brick cutter with a sliding table popular make is a clipper, it will have a wooden bed inside a steel tray, you screw a piece of wood down so each brick sits at the correct distance, water sprays on the disc, you will cut hundreds of them in a day. Probably don’t need to cut all the way through, 1/3 through and tap with a hammer. -
Structural opening dimensions for window frames
Russell griffiths replied to Moonshine's topic in Windows & Glazing
I have recently had my windows measured and the surveyor said that they now require 30mm above any large openings for sliding or bi fold doors as they are getting too many call backs due to the openings settling. We have left 15mm in the width, 7.5 mm both sides and 15mm in the height. These are for windows the company are fitting, I have allowed less for the ones I am fitting as I am happy with a tighter tolerance.
