Russell griffiths
    63
  1. The more insulation the better, but obviously every job is different you probably need a chat with your builder, or do a test hole and see what you have there now.
  2. So looking at that pic with the dog is that not what you are trying to achieve? little soffit, remove gutter and fit a facia. Or am I barking up the wrong tree, boom boom.
  3. In that case you could do with digging down further and getting more insulation in the floor, the extra insulation is relatively cheap, it’s the digging down that’s a pain, whats the headroom like ? Can you go up instead of dig down.
  4. Not meaning to be a killjoy here is this already a habitable room i really don’t like the idea of a kids playroom in a cellar, is there another means of escape in a fire ? i may be barking up the wrong tree but would hate for anybody on here to advise that this is a good idea without knowing more facts.
  5. Ps, how did the dog get up there.
  6. If you trim the rafters back will you not have to redo the whole roof? does your roof not extend down to the end of the rafters and run into the gutter? need a pic of the roof slates really i believe you used those funny slates that fit to an aluminium rail am I correct? If so can you remove the first row without compromising the rest fit you tilting fillet and dress your membrane down as it should, or fit a nice facia board and mini soffit that abuts your cladding. All a bit of a guess without seeing it clearly.
  7. Morning mr @zoothorn now how about this, every time you ask a question and I reply we can have a little bet that can be judged by the forum, so if you ask a question and I answer incorrectly I will lose, if I answer correctly then you lose. Why don’t we say £100 a question just to make it interesting for sombody who cannot look up the price of a sheet of insulation you seem very confident that I’m wrong, so should be an easy £100 for you. What ya reckon,
  8. Metal roofing sheets. 6 inch feather edge boards, lots of creosote.
  9. You will find that a concrete lintel is far cheaper than a steel one so it wasn’t put in for cheapness steel lintels are supposed to be propped in the centre as you build the brickwork above, when the brickwork above goes off this when full strength is achieved.
  10. Tighten the joints up, looks a bit heavy on the mortar.
  11. Double boarding will cost you double in labour.
  12. TBH looking at the pics you have some ceiling fixing to do where you have removed that wall, you may as well cut a 600mm square hole so you can reach in and do it properly, then board the hole and repair where that wall was. It may be easier to overboard the whole ceiling and reskim it.
  13. Hollow blocks with concrete fill ??? block on the flat ???
  14. You can get a connection that has an additional pipe to take away condensation it looks like a straight connector with a joint to take a hose to drain off condensation if you think condensation isn’t a problem then just a straight connector.
  15. Not sure I understand the problem cut a new hole for new vent fill in old hole. Its really that simple, the hardest thing will be having a long enough cable to power it. ?‍♂️
  16. Are they even legal to use nowadays under health and safety ? unless you have a team of dedicated brickies I think you will struggle to get anybody to want to work with them, I certainly wouldn’t lay them.
  17. Have you got a picture i bet you have a broken tile somewhere, the water is running down and pooling behind the facia area as there will be no anti sag method in place so water is dripping onto the top of the wall and getting in the cavity then it’s like others have said no weep holes to let water out so it runs to the inside and drips off the top of the window.
  18. I found most of the local mills only stocked English, and it was the specialty cladding companies that stocked overseas.
  19. What @Mr Punter would be the difference in labour? i cannot see a huge difference between 50mm boards and 70mm boards, just longer screws.
  20. Patrick, your neighbours are going to love you, i think after dropping a tree on them and now waking them up your going straight down when your time comes. ????
  21. Is there a reason you don’t like this window, surely natural light in a workshop is good. You will have major noise issues with the door, a window will not make it much worse, why not build some shutters that can be pulled closed when you do noisy stuff, I would also build shutters over the door to stop noise as well.
  22. Patrick, your neighbours are going to love you,
  23. @Big Jimbo why not find another piling company? all companies will charge you mobilisation plant costs mine was about £1200 i had 29 piles to 8m for £12,000 I asked 2 companies for quotes and both said that the ringbeam was a loss maker as they took to long and made more money from just the piles.
  24. Not trying to state the obvious but I take it you are going to fit this vertically.
  25. I do like a bloke who doesn’t mince his words. Straight to the point boom.
