I have used i joists for a small section of upper floor as they came free when I ordered all my roof timbers i have considered cutting them out and throwing them on the fire, the trouble I’m having trying to get all my services running through them is untrue, by the time I’ve finished with ducts for mvhr pipes for water and cables for electric yhey will look like Swiss cheese. If you will have lots of services I would go with the metal web joists.
That’s it. Make sure you tie the laps well, in case they pop up as somebody stands in the middle.
Minimum cover to protect steel from corrosion, and to allow correct strength to be achieved. It can sit lower, but then you don’t want it to close to the underside, how thick is your slab. 100mm???
Planning our en-suite.
Russell griffiths replied to ProDave's topic in Bathrooms, Ensuites & Wetrooms
Those cabinet legs come in two pieces, you just yank the tube bit out and attack it with a hacksaw then push it back in. You can chop it down to about 75mm. -
New build - confused between timber & i-stud
Russell griffiths replied to osmononame's topic in Timber Frame
My I beams 225x 75 were double the price of solid timber, but the benefits could be well worth the extra cost. If you use 145 solid timber you have got to add extra insulation if you go with a wider I joist you can get more cheaper insulation in instead of the expensive pir. Lots of lots of sums to to do and at the end of the day you just have to make a choice. -
As far as I’m aware your smallest I joist would be 195mm so a bit bigger than your solid timber, and these will be a pain to fit pir into -
Just to add my bit. my pipe runs have lots of ic I could remove half of them and use long sweeping bends WHY? I want to access every pipe directly inline with its final point why would I want to increase the rodding length from 7m to 14m i want a house that functions well and is easy to work on. If you are having a very posh drive and don’t want to see an ic then I can understand why you would want to reduce the number, but if you can hide them in garden areas I see no reason to reduce the number.
Depends on the sink has it got a pedestal? is it in a wall hung vanity? or is it just a wall hung sink with a fancy chrome waste. If the last one I would get the brochure for the sink and the waste, some wastes have an extending neck so can go up and down
I’m not sure if you are getting your terminology mixed up. An I STUD would be used vertically for building walls an I JOIST would be used for a floor or roof a METAL WEB JOIST will be used for floors. If you are using them as studs for the walls you can use a deeper stud 225-300mm this way you can fit in more insulation, you will not find many solid timber studs over 145mm so these require a way to get more insulation in so you normally end up fitting insulation over the studs to stop cold bridges. -
It’s annoying isn’t it. We came across hundreds of trees that we felled that all had a metal bar in the centre, turned out somebody thought it would be a good idea to use a piece of 1/2 inch re bar as tree stakes when they planted them.
Griggs did a full design for my roof, not sure if they can do a whole structure.
I brought all my I beams from Griggs timber in Gloucestershire I’m in Cirencester
I wonder if it’s had a silicon waterproof coating on it and now the paint is separating as it cannot sink in.
Curtain pole fixing
Russell griffiths replied to oldkettle's topic in General Self Build & DIY Discussion
Fix it to the wall instead ?? -
Do you know you don’t need to put that bit of timber up to fix those brackets to. You can get a little insert that you drill a hole in the block poke in insert and screw stud into it and insert expands in the block. I will shut up if you already know this.
I love the smell of napalm in the morning.
Look at different piling methods, if you go for a driven pile there will be no muck away with this as opposed to drilling a hole.
Opening Windows and Internal Colour
Russell griffiths replied to canalsiderenovation's topic in Windows & Glazing
I have just fitted all my windows and it did take an age to get the right spec for each room, as far as I’m aware there is nothing to say that any window needs to open unless it is for fire escape purpose if you are using it for this purpose make sure you specify this to get the correct openings also check glass specifications in case you need toughened or laminated we have a bungalow and decided to go laminated all round as the extra cost was very little. We have 7016 outside and also inside. They look excellent. Be aware some internorm windows have a white section in the inner part that you see when they are open even if you have a colour inside and out. I think it was their upvc version. -
Shower rooms, STPs, anti syphon traps and AAVs
Russell griffiths replied to jfb's topic in Waste & Sewerage
Does that toilet not go out through the wall?? if it does how about a small stack outside. -
I have a 1.5 tonne machine that is fairly high spec, so it has a zero swing counterweight, so it turns within its own footprint, it also has variable track width so it’s nice and stable for working but will squeeze through 900mm- 1m cannot remember exactly. I would get a man and machine, owner operator as he will be quick on it which will save money, just concentrate on shifting the stuff.
If it has fences down the sides you will want to screw plywood to protect them, or price in to replace them afterwards.
Recommended kitchen sink pipe gradient?
Russell griffiths replied to MJNewton's topic in General Plumbing
As long as it doesn’t slope up hill it will be fine get on with it will ya, I need you to come and guide me through all this cat 5-6 cabling stuff. -
Oops so that means you haven’t done it. You have a hole to dig it’s 1m x1m x1m so you would expect to excavate 1msquared. If you imagine what you dig out is now loose and fluffy not compacted into a 1m block so it now has gaps full of air, your 1m hole has now produced 1.4m of spoil. This varies depending on soil type. As a safe margin if you think you will dig out 100m allow 40-50% for bulking.
Steady son, I thought I was the only non pc one on here.
