Russell griffiths
    65
  1. If you go concrete first floor you will need a crane to lift the panels in so your looking at £800++ just to get them in place, then you will need to work out how to run pipes and stuff either under or over your concrete floor. Metal web timber joists and you can run all services between them. Just a couple of things to think of that may alter the pricing.
  2. Have done that, so mentioned to them that I consider their product to be worse than if I had bought seconds. They have asked me to come up with a figure I would be happy with.
  3. Maybe compensation was the wrong word, a reduction in price on the item to save them coming and replacing them.
  4. I’m thinking if they have to come and get it 1-1/2 drive, load it then 1-1/2 drive back that will cost them £200 in wasted time and wages.
  5. I won’t need to cut any, going under rafters so full sheets apart from a couple of cuts on the ends.
  6. I had no idea where to put this, so because it’s to do with insulation I chucked it here. So the other day i put a post post up about some pir insulation I had delivered that I wasn’t happy with, so to cut the story short I have to work out how much compo I want from the supplier and they will consider it. I will be thinking about this myself obviously but thought I would ask you lot in case you come up with some random idea that gets me enough to buy a small yacht. So the situation is i have 2.4 x1.2 sheets 70mm thick the edges are sunken back to the point I won’t use it, so the plan is to trim the sheets down. Work involved. Trim each sheet on both long lengths by 10-15mm as I see it labour, pay a man to cut these. Cost per sheet ??? disposal of debris, I will be left with debris I wouldn’t have had. Cost ??? smaller product, by cutting it down I no longer have a product 1.2 wide but 1180. Cost implications??? bit of a random thread but it is Friday night and she’s gone out so I’m bored. What you think. Will I get my yacht.
  7. Would you like me to come and cut it for you. Tart.
  8. Here you go geezer.
  9. What are you building the rest of the place from, or what is existing icf would seem a bit strange just to build a dividing wall if the rest of the place is timberframe, and visa versa.
  10. Thinking outside the box. Can you afford to not have the money in one lump. You could in effect supply the finance to buy your own plot of you, monthly mortgage payments to you instead of a lump sum.
  11. Can you not get them to hire them and add it all to their bill , so zero rating it.
  12. Watch out for the solar gain police to be along soon ??
  13. Only one cable cool. Tbh I’m a bit disappointed, I came home imagining loads of Micky taking, especially from @AnonymousBosch, I had loads of good comebacks planned and not one bit of random p##s taking. You lot are far too nice.
  14. @Nickfromwales garage could be twisted around a bit to get the roof facing the best way. At the moment this could be a year away.
  15. I thought you lot @Jeremy Harris @ProDave Had answered this for me. Thank you. But it has now led to a new question which could be a bit silly so cut me some slack I’ve just got up. If I put the pv on the garage I need a cable to take the newly made electricity back to the Cu. Got that. Do I have a separate feed from the Cu to the garage to power the garage itself ? does the electric travel both ways down the cable. Or is a separate cable needed. oh god as I’m typing this I can imagine you all laughing at this. Im just thinking about water you couldn’t have water pushing both ways. Thats my justification for a silly question.
  16. I thought most doors and windows where bespoke really there are lots of companies around specialising in large doors and windows it really depends on your spec. I have just had triple glazed ally clad doors and windows from a company called norrsken the big door weighed a smidge under half a tonne so not exactly small. I know of a few on here that have used them as well as loads of other companies. I dont think what you are after is particularly unusual.
  17. You need to satisfy yourself that the new location is ok for example, if they have a drain run close to the house are you going to end up with inspection chambers in the middle of a nice path instead of hidden in the garden. Have a good think of why why it was drawn up the way it was and what implications it will have with a new layout. If you are not happy get it done as per the drawing simple as that.
  18. I notice from your pdf that you have one roof ejecting water onto a lower roof, these are the areas you will need to look at carefully as the increased volume of water can overwhelm the lower gutter.
  19. I base a lot of my views on what I have seen fail over the years. I would say that most flat roofs fail because of inadequate fall and water gathering i would say that most gutters fail because the water cannot get out quickly enough i would design it to get that water into the gutter as fast as possible, then get it out of the gutter and down a pipe as fast as possible. There used to be rules regarding one gutter outlet every so many metres, now I see a whole house roof going down two outlets one front one back. Completely different to your situation, but I have a massive roof area all at a low pitch and my first thought was get that water off that roof get it in a gutter and get it on the floor quick smart.
  20. My eps blocks have been exposed for a year and a very persistent bird has pecked a 60mm diameter hole in the outside, I think discovering the concrete core really put a downer on his plans.
  21. All ICF, if based on either eps or xps will susceptible to both rodents and any solvent based products. Get an eps icf block and chuck some acetone on it, it will melt away in front of your eyes. I don’t suppose that your suppliers thought to mention this as I thought it would be common knowledge. Its a bit like saying will my timberframe burn, yes it’s made of wood.
  22. Have you a better pic, it looks to me that this is not a window in an original location, if you look at the brickwork you would not end up with a mortar joint up against the frame. Looking at the terrible silicon I think it has been patched up previously i think it is probably a job for the spring where you will need to cut out all the manky stuff and work out where it is getting in. It is probably just penetrating through the jamb around the frame is it solid brickwork ?
  23. Brilliant answer dave, it hadn’t even crossed my mind to put all the junk in the garage, I was trying to envisage stuffing it all in the services cupboard. Will measure distance tomorrow.
  24. I think wavin make a silent pipe as well.
  25. I’m thinking of putting PV in at a later date, my main concern at the moment is actually having the cash to finish the house without things like PV so im thinking of a remote setup on the garage roof that will be built some time after we move into the house what I’m after is what sort of ducting to put in place from the garage back to the house. Is there a distance where where it gets unviable to have it remotely, I presume the further away the larger a cable is needed. Where do I run back into the house. To the consumer unit? Or to a place that has the space to store all the solar gubbins can the solar stuff be in a utility cupboard that houses the hot water tank and ufh manifold, but it doesn’t have the CU, that is in a cupboard just across the hall. Any thoughts @ProDave @Jeremy Harris
