Corrugated Metal Roofing
Russell griffiths replied to Tom's Barn's topic in Roofing, Tiling & Slating
Just get the standard one from the local builders merchants, ask which one they sell the most of. -
All sites stopped here a fortnight ago and I think they must be thinking of being shut for a while, as they have all put temporary window coverings up in the openings, I think if it was only for a month they would leave a timber frame shell open but they have blocked them all up and run house wrap over all the temporary frames. Regarding work ore it’s not just if a bloke can stay 2 m away from his mate i know a few families that he wants to work but cannot go out as they have lost all child care, if the wife works at the hospital and her mum and dad normally baby sit then that has all stopped i read about a lot of lads who have taken over the home schooling.
What he really meant was, i haven’t worked for 4-6-8 weeks so when we are allowed to go back I won’t really have the time for all the stuff I have booked in, I wonder who I can get rid of. I know a few lads who are really panicking that anymore than a month off will start affecting work booked in for 2021.
Depends who you are and how you like to live are you an old fogey who likes a separate dining room or a young couple young kids likes a big open plan kitchen diner. The house we are building doesnt have a single wall downstairs to separate kitchen dining living it’s all one big space, but that’s us. How do you want it to work for you.
The first thing you needed to do @TheMick was explain what you wanted to build, everything revolves around that, the specification for a 3 storey commercial building will be very different to a single storey building in the corner of someone’s garden. Looking for a specification from a website they will be cautious because they think you will fit their sheets to a big barn in an open farm yard. I think you mentioned garage so I presume single storey, 25mm battens will be fine, you can get the mesh online it’s stainless steel fly mesh. Fit your counter batten then fit the first batten right on the edge, you can staple your mesh to this. Use a fixing that is long enough to go through batten and through the counter batten into the rafters that way you are not relying on a 25mm to 25mm fixing so you want a 90mm fixing for the top battens, make sure you buy tex screws for wood not metal look for a vid on how to torque your screws down so you don’t destroy the rubber washers, it’s all in the finger on the trigger control. -
Finger jointed timber, is it available over here?? reading the other thread on skirting I thought to what I used in Australia and I remember it being all finger jointed radiata pine I used it for skirting architrave and all door linings, it came pre primed like mdf but as soon as you cut it you can see it’s timber inside. Had a quick google and its all american or australian websites. I really liked it and would definitely use it again.
Wall Insulation - Internal or External
Russell griffiths replied to canalsiderenovation's topic in Heat Insulation
Reading that both are INTERNAL one using 65mm dot and dab fixed the other 37mm boards fixed to a softwood batten Have you not supplied a specific guide as to what they are quoting for ? this could be where your price differences are coming from, between those two different specs could be £2-4 grands worth of insulation do this a few times on different aspects of the build and you can get vast differences. I think you need to get a set spec done done and get that priced by both parties or your not comparing apples with apples. -
Bedding thickness for foul drainage pipe: how thick?
Russell griffiths replied to ToughButterCup's topic in Waste & Sewerage
I can get it, I’m just trying to avoid people i can go to Tesco and pay at the pump. Poor ol @AnonymousBosch sidetracked his topic, sorry mate.- 14 replies
- foul drainage
- approved document h
(and 2 more)
This is for dumper and digger, digger probably only uses 10 litres a day, but I’ve been sat on it for the last fortnight and will be for the next couple of weeks.- 14 replies
- foul drainage
(and 2 more)
This is how I would do it cover the tops of the rafters with a good quality breather membrane, then a 50x25 counter batten that fits on top and parallel to the rafters then a 50x25 batten fixed on top but at 90degrees to the rafters, fit sheets on top use a ventilation strip at eaves and ridge you want airflow but not bugs. Those battens are 100x25 and are spaced 100mm apart you won’t need to do this, space them how far apart the sheet manufacturers say you need the fixings 600-750mm whatever, remember you won’t be able to walk on anywhere there isn’t a batten. mesh at facia level -
I’m putting normal diesel in the digger, breaking my heart and bank account £60 this week already 100mm by the way.- 14 replies
- foul drainage
(and 2 more)
Did you get your pet beaver to chew that pipe to length c,mon bud you can improve on that. Or or I will inform @Onoff
This all depends on your ventilation details, what are you doing to combat condensation you will get lots of condensation on the back of the sheets so you need to work out how it will dry out good ventilation is the first answer -
Self build and selling some plots off
Russell griffiths replied to Leigh-s's topic in Introduce Yourself
Sounds interesting have you got any plans drawn up yet. -
Hi Leigh, welcome. -
I don’t think you can have what you want have you heard of that triangle of 3 things time - quality - cost. I think you have the same situation but with different headings no maintenance looks cost. So. Timber - looks good- lots of maintenance plastic- cheap- looks shit aluminium - looks sharp and modern- expensive you need to make a choice i have chosen timber, it was expensive and I know that I will need to re stain it every 2-3 years, it looks absolutely spot on and nothing else would have looked right except probably powder coated aluminium. Work out what you are trying to achieve.
Is there a way to insulate pipes from giving off too much heat, my design at the moment has a group of pipes running under a section of our kitchen floor, I have seen pipes with a thin duct around them in areas that might get extra wear or movement, is there a way of insulating a pipe so it doesn’t give out that much heat in a dedicated area. I did wonder about cutting every other pipe into the insulation surface and covering with another layer of insulation before the screed just to keep the heat output down in this location.
Hmm, what to get on with…?
Russell griffiths replied to Dreadnaught's topic in General Construction Issues
Thats a good bit of fall you have, wish I had some more fall, mine as looking very flat you will have a proper ??⛷⛷? -
Cut price insulation are doing deliveries of both pir and plasterboard, just had an e mail from them.
But the main question on my mind mr @pocster is HAVE YOU BLOODY WELL SWEPT UP YET. ?????????
Oil Prices nearly 30% Down
Russell griffiths replied to Ferdinand's topic in General Self Build & DIY Discussion
I’m just think of getting a list going of all the costs to use it versus an ASHP the maker of the boiler is not far from us, I did contemplate taking it back to them for a freshen up. -
That would depend on if you use the Australian government guide to showers while I was over there they sent to every household an egg timer with a rubber suction cup to stick to the shower door, you flip it around as you get in and take a 3 minute shower. We had two girlfriends of my wifes staying and they asked what the egg timer was for, I explained and the said how do you expect us to have a shower in 3 minutes. I thought of how to explain and did a little demonstration that went something like. Armpit, armpit, fanny, bum and now your done. I don’t know if it was the New Zealand Sauvignon Blanc or what but they where all rolling around the floor.
That’s ok I put you on the banned list already. ??
Totally off topic @Mugwanya but anyway, I would be very careful with regards letting agents and holiday properties we own two holiday letts and my wife handles the books for a few others, ours are ok but we have noticed that in times like now when people are cancelling holidays that the letting agents are still taking their commission even though the holiday doesn’t go ahead. Look into a contract very carefully. Ps, if you let someone wash their dog in the bathroom you will need to refurb them every year and extra cleaning every week, warm tap outside for dogs, showers inside for kids, no bath takes too much hot water. We allow dogs and charge an additional rate for extra cleaning.
