Depends on the clay content, I used to lay tonnes of it a year and after it’s rained I wouldn’t want to walk on it and then into the house. How about bonded gravel, not cheap but nothing is anymore. We get as dug gravel from the local quarry, we are in Cirencester, it varies and sometimes has a bit of clay. Again something I wouldn’t walk on and then go indoors.
Uneven concrete floor - what's the worst that can happen?!
Russell griffiths replied to Glenn's topic in Floor Structures
I’ve actually just done that. what i did was, find the worst bits and mark on the floor buy some high build floor level compound and chuck it in the low areas. Use eps insulation instead, cheaper and easier to work with. Lay the insulation boards down and if you don’t like the amount they rock mark them up and sand out an area on the eps so it sits over the hump better. Tounge and groove chipboard all glued together so it acts like one big sheet. 4x1 timber as a skirting board to pin it all down. Garage floor paint to keep out stains. Worked a treat, just done before lockdown so no pics I’m afraid. -
I would do some sums on the sale value of the land and work out what it’s worth to you. Then make a counter offer based on the percentage sale figure. Our planning cost us just shy of £15,000 worth every penny.
A Energy Rated unvented cylinder
Russell griffiths replied to Robert Clark's topic in Boilers & Hot Water Tanks
So I know nothing about this, but could you make a plastic bag that is a tight fit around the cylinder, put the cylinder inside and fill it up with spray foam creating an extra layer of insulation. Is it that simple, what about all the pipe connections. -
Definitely.
How do you intend tying the new bit of concrete into the original bit, I wouldn’t be happy just pouring a funny shape bit of concrete on the side. I would want it all tied into the original pour.
Roof area and local used tiles
Russell griffiths replied to Gymwear7's topic in Roofing, Tiling & Slating
If you have large cement tiles why do you think they are only going to last another 10 years?? if your removing them I would want them for a lot less than £500, who else will want them? -
If your paying for it,
You only need the one with the protection layer if you are leaving it with no roof above it for some time.
If it’s nothing complicated find a local architectural technician, I paid £20 per hour.
Cavity trays over air bricks and telescopic vents
Russell griffiths replied to MAXWELL's topic in Ventilation
You need to look at the situation and stare at it, thinking if any water was to enter the cavity can it run to the inside, any chance of moisture in the cavity must be shed to the outer leaf. Are you not having a solid floor ? re your other question, or are these to serve the original property. TBH a roll of dpc cost pennies so your better off just doing a nice tray damp course all around. -
Shouldn’t be any hardcore nowadays. Type 1 compacted sand blinding dpm. Concrete insulation screed. Or alternatively. Type1 thin insulation dpm more insulation concrete. Theres many ways to do it but hardcore and concrete should be left for a shed base, there is no way to compact it sufficiently to avoid voids in it.
How to heat my converted converted Garage
Russell griffiths replied to mfmcdonagh's topic in Garage & Cellar Conversions
What insulation is in the floor and roof. -
We used a planning consultant, best money I’ve spent in a long time. I would find one locally that knows the area and then check them out, see what they have achieved lately. As above I wouldn’t waste too much money on drawings for something you won’t get permission for, you may need all the money for the big fight you have in front of you.
Whereabouts are you.
Depends what it’s holding up. Ive laid concrete straight onto a plastic dpm straight on the dirt. But I wouldn’t put a house on it.
Lead trays for windows & doors in a timber frame?
Russell griffiths replied to Nick1c's topic in Windows & Glazing
I think it’s 925 air sealing I used. Too many numbers bouncing around in my head. -
Concrete Slab - Collapsed wall help
Russell griffiths replied to carlosdeanos's topic in General Structural Issues
You need to get your floor level worked out and damp course levels to make sure it all works. And look at weep holes if you now have a full cavity. Check it it all out before you go further. -
Reason it happened. Blocks too dry, mortar to dry, insufficient bond between the two, too much concrete, don’t dwell on it too much, learn and move on. Here’s a wild idea. Smash off the top course of bricks that have collapsed. Extend dpm into cavity. Fill cavity with concrete level with what you have. Build inner leaf from that adding a tray dpc to end on top of block shown. You dont need an open cavity below dpc, you could fill it, well you started to ??, sorry couldn’t resist it. Obviously without seeing levels of ffl this could all be nonsense. Otherwise i think you need to get the kango out. -
Gap filling prior to skimming
Russell griffiths replied to MJNewton's topic in Plastering & Rendering
Leave them the plasterer will not have a problem with them, can you imagine some of the stuff they deal with. -
Anyone used Jackon Thermomur
Russell griffiths replied to Kernow's topic in Insulated Concrete Formwork (ICF)
I have heard on the icf grapevine that the plastic cross ties can be a problem when pouring concrete, i was told the flat surface on the top of the ties holds concrete, so it’s possible to get voids, and also on your second pour you end up with lots of dry snots that then break off and fall into the cavity. Just what i was told never used it. -
Anybody using Velox ?
Russell griffiths replied to Tim Alsop's topic in Insulated Concrete Formwork (ICF)
That looks excellent @D Walter??? -
That’s cool as long as you knew where you are heading. Lots of people with champagne taste and a beer budget.
How early can you apply for demolition notice?
Russell griffiths replied to magutosh's topic in Demolition
I don’t see why you need to wait BUT DO NOT KNOCK A THING DOWN until you have approval for the new building. -
Have you priced them. I bet that’s £10,000 plus for those two doors.
