Russell griffiths
    65
  1. Really, so are you doing the blockwork, that will only work if you fit them as a bricky team are not going to stop to start drilling in ties.
  2. Do you turn the inner board back when not in use, normally saves staining and dirty brickwork.
  3. You cannot use full size boards as the wall ties will get in the way, need to use correct size sheets that match the tie spacing. That is why they make those small sheets purpofor the job.
  4. Have you considered moving, new build so should sell quickly, upgrade to a larger version on the same site, save 18months of agro.
  5. Look for products made by ILLBRUCK I have been using sp295 it comes in foil tubes, sticks to everything. Most people use the stretch tape on timberframe
  6. Cheers chaps, I did think that was the case. I will check with the manufacturer.
  7. Evening all. I have some 16mm mlcp pipe for my ufh that fit to a Euro cone fitting to then connect to my manifold. Does the pipe require a tool to re- round it and put a chamfer on it before using the fitting. Im positive it needs re - rounding, but not sure about the chamfer.
  8. It all comes down to the design of the rest of the building really. Why the warm roof ?? They eat up height. Do you have a drawing of it. Or just winging it as you go along. If so you need to do some sketches or you will end up in a world of pain.
  9. Good minds think alike ??
  10. Is there an echo in here. ??
  11. I think you will find the opposite happens, old house moves around like a lunatic, new house won’t budge. I would draw up a list of your concerns and go and have a sit down with the structural engineer. I worried for weeks about a few things, so a 2 hour drive and an hours meeting and everything made a lot more sense.
  12. I would look at planning permission and build it properly. That lintel will bend like a boomerang and your doors won’t open. You need to do it differently. Two kerto timber beams over doors with maybe a steel flitch plate between them, then hang your roof timbers from the inner face of the timbers NOT on top, this will keep your height down. Theres a million ways to do it, but that skinny concrete lintel is not one of them. 2150 is the lowest I would go with finish ceiling height. My ceiling in the place we live now is 2150 and it’s not exactly fancy and I’m only 5 foot 6.
  13. Get some 1mm galv wire and a pair of nippers, tie them up just like reinforcement cages.
  14. I would look at stainless sack ties and a twiddling tool, hog rings are weak.
  15. No, these are long ferrules about 15-20mm long and roll around the wire to form a tube.
  16. Do you know about the metal ferrule type things that you can put on the wire to make cages, come with pliers to squeeze shut.
  17. Because I’m a clever fooker Been there got the t shirt bud. Sprayed a few houses in oz. always back roll. You get a hairline crack you cannot just grab the roller and give it a quick run over, as it will show up like dogs balls.
  18. If you put a light in the wrong place you cannot patch and move position, without re spraying the whole ceiling.
  19. Are you going to back roller your top coat.
  20. Can you not insulate the one you have. Years ago the go to method was to put loft insulation on the back covered in a plastic sheet stapled to the back of the door. Just depends on how much you want to spend.
  21. If your not having to comply with building regs then any amount is better than none, I would avoid the cheap loft insulation it’s a horrible bastard thing to use, buy some better quality more user friendly stuff, the brown knauf stuff is a lot nicer than the golden coloured glass wool.
  22. I’ve had a number of projects where gabions would have been perfect, but every time I’ve priced them up it all works out too expensive. In the past I used them but it was always with a big landscape architect and cost was not really the issue. Could you make them out of sheep netting? a friend of mine has just made some cages out of sheep netting, he has made them round by just joining the net back onto itself, but if you put these in a row you could flatten the front. As long as you place the front rocks so they won’t fall through the back stuff can just be loose.
  23. Are you not using a decoupling mat under the tiles, if you do this will probably bring you up to the height you need. Have you got ufh.
  24. Is there a reason you cannot get them the same. I would try very hard to achieve the same height, either some floor levelling compound under one or the other. What are the make up of the two finishes.
  25. Ok cool, I’m going to separate them a bit in the morning even though it’s all ducted, the last thing I want is getting Chanel 4 news on the intercom when the postman rings it. I will I’ll come back to you clever people regarding the cable type later on. Ta very much.
