Everything posted by Conor
ASHP / Octopus Cozy - any experiences?
Conor replied to Paene Finitur's topic in Other Heating Systems
Actually, looking at the cosy, if you just set your ashp to avoid the evening peak, looks like a winner, esp as it sounds like, you run your ashp near continuously. Set your timers, weather comp and stats accordingly. -
Are you able to just run the ashp on the low rate only? We're on economy 7 and do exactly that, 90% of the time. During a real cold snap we'll run it 24x7 on the days required. If your heat losses are high (sounds like a a big house) then you would be better off running 24x7 on weather comp, low flow temp and a the cheapest standard tariff that doesn't penalise you for daytime use. -
I second the cheap cordless drill option. Impact drivers are great, but specifically at driving 1000s of screws at high torque. For 90% of the time a cordless drill will do the job. Something like this would do a decent job. https://www.ebay.co.uk/itm/175919185561?hash=item28f599be99:g:buYAAOSwbPhlEBHY&amdata=enc%3AAQAIAAAA0APVs5PUaB5jFLVF%2Bcu%2F%2BmKkNyaYLBlo6VmgVqCAUbLxmqQtJQZxBnf5Ocpnd4kbpj7xtiuOIOZPNvHKYPFtzv%2B%2F5iSfuEFQggulmax6%2FjNaH%2FIIXOXK3AU1nvgCfLfw14Jh6sluquMhdN%2FnMLDFtC%2FC7bZ6Iwzw2jdQQ6o4N8RUEhxdRw3st2E0fETj0bizL3Y0eqXAGf%2FDfdrWJibxrlwn5sQDNV%2B%2FkCUaS3%2FAEilWlhss%2B0vROzKKIWTOAXaOtmf7KgO0D9PCBkFeVStOr%2Fk%3D|tkp%3ABk9SR7ae9tnlYg But I've no idea what's involved in resorting a boat and if you'll be driving a load of 5/6mm dia screws deep into hardwood... In which case you'd want an impact driver.
Just show 5h3 screed guys where 5hry need to bring the screed up to and they'll take it from there. They'll start setting out and compare the datums across the floor. You'll find each external door threshold will be a bit different. Your tiler can make up for a few mm difference at each door. You could go to 125mm insulation but think it might be a bit tight for screed as leaves no margin of error.
The Conor Threshold: the Lancashire version
Conor replied to ToughButterCup's topic in Rainwater, Guttering & SuDS
Ha. I'll get back to this. When I'm the computer. -
5degress is basically a flat roof. Typically min. 15⁰ for a standard tile, I've seen some low pitch ones down to 10⁰. You'll need some sort of flat roof or zinc panel system.
When can you move into a new build?
Conor replied to Norbert's topic in General Self Build & DIY Discussion
Anytime, really. 5ho I think it's different in Scotland. When we moved in we didn't have running water in our kitchen, any floor coverings, and only one working bathroom. Bear in mind, work will grind to a crawl when you move in, and you might have vat reclaim issues as seems HMRC have (in the past) used the date of occupation as a definition of complete, and the three month countdown on vat reclaim starts. -
Th bit I had to fill in was long and narrow, just ran a couple lengths of rebar along the length. Tbh a few 300mm dowels or threaded rod drilled in to the edges of the slab will be enough.
In that case, shutter from below with ply, dowel in to the slab, and then fill with concrete. I regret not getting my openings done in the factoy, so much harder afterwords!
Did you check that size of opening was OK with the SE/supplier? Have you cut through one or two cables? For mine, once services through, I cut a piece of ply to suit, fixed battens to the sides of the slabs so ply was level with slabs. Bit of foam or cement to seal it off. You'll need to make the rest of the levels up with insualtion and a bit of cement + self leveller.
Unless the floor slab and walls of garage are insulated, no point. If you can foresee a use of the garage in the future that would benefit it being able to be easily heated, and kept warm in the winter, then change the design to incorporate insualtion. Putting a UFH loop in the screed/concrete will cost pennies. If it's filled with inhibited glycol, no harm in it sitting dormant for periods. NB building control implications of you make the garage part of the thermal envelope of the house.
Mortar under the dpc, mortar above the dpc. A 20kg coping stone isn't going anywhere.
What can I retrospectively do to reduce the bounce of block and beam?
Conor replied to Lal's topic in Floor Structures
Pretty sure the OPs house is finished and lived infor some time. Short of ripping up the floor and spending a fortune, nothing you can do. -
Vaulted Ceiling Extract Position
Conor replied to Jambutty's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Drop a small false ceiling down, maybe 300mm deep, 400mm wide, along the length of the room. -
Bed preparation is key. Weeds growing up through the new turf will be your biggest issue. Other than that, it's straightforward, just avoid hot, dry weather (so lay in spring or have sprinklers on the ready, same as sowing from seed really.)
Project Management - 1 page agreement with PM
Conor replied to JennyF's topic in Project & Site Management
Put everything down on paper, especially if he's assuming H&S roles and responsibilities. -
Each LA varies, but generally if it's a new dwelling, the access needs to meet the highways requirements. Regardless if it's the modification of an existing, or a new one.
Tbh, I'd spend the little extra and dig up all the old clay pipes and lay new PVC, outside of the extension area. High chance of old clay pipe failing when building over. Easier to move the lot.
We got the most expensive insinkerator brand one. Deals with bones just fine. Not tried teeth yet.
Get an insinkerator in your final kitchen.
Quite often, cutting a hatch through a board is easier than lifting an entire sheet, even if this just screwed down. 10mins with a multi tool and you're in.
Buildings and Contents Insurance
Conor replied to pauldoc's topic in New House & Structural Warranties
Money supermarket. Etc etc. What's your construction method? We're ICF with basement and got insured with LV for something like £350.
