Conor
    12
Everything posted by Conor
  1. No reason why a small number of storage rads and a small DHW cylinder all running off-peak wouldn't do the job. BUT be mindful that for mortgage valuation and resale, a house with no central heating can still be an issue for some. AND you say "approach" passive house standards. Quite different from hitting them. We are the same and even exceed the min U values in most places... but would not be without our ASHP & UFH. But we did successfully heat the house in its first couple months with a couple dehumidifiers and a fan heaters. Still, can't beat the convenience of UFH that costs pennies to run.
  2. Our rooms are all 20-21c. No complaints. Light summer douvets all year round. Stop overthink it.
  3. Interested in this as well, we got three of the damn things, the elements are ment to be hardwired in to a fused spur and left on 24x7. Haha.
  4. What's your water supply going to be then if there are no mains nearby? Borehole?
  5. We didn't leave a service void on the walls, just chased out using a hot wire cutter as needed.
  6. Slide a length of 180mm twinwall drain pipe over it and be done.
  7. You can't pump surface water in to a drain unless you know where it's going and you have consent to do so. I think looking at your topography, high water table and soil, you'll have to learn to live with it. You've created a large, flat area with minimal vegetation, a bit of creative landscaping will do wonders.
  8. I have the fall continuously away from the door I have a nominally 25mm gap between door block and the pacing / slab. It's just gathering crap at this stage so I think I'll fill it with silver sand. Ours is very sheltered, yet to see water on the door. Combo of North facing, deep reveals and deep roof soffit. I'm assuming dpc from all the way from under the door frame at the threshold down below the slab? That's what I have then another peice on the reveal at 150mm above FFL.
  9. Plasterboard the lot.
  10. Is the floor insualted in the porch? Can you measure the flow temps using a infrared thermometer?
  11. Not an expert on the boards you are using but we used plasterboard. Just fitted as normal, we're taped and filled, the used a mapai tanking kit. You have to use tape on all the joins and corners. Floor to splash height all round. Then two coats of tanking paste. I left the tiler to do the alcove as I didn't have time... I don't think he did a good job as looks like the ply underneath is getting wet and swelling. Alcoves really important as you'll have water sitting their for hours.
  12. Glad I've only done a shed roof and a balcony then 🤣
  13. No need to insulate, you just use fewer loops from the other zones where the pipes pass through. You can use flexible 20mm electrical conduit for the first metre or so, just so that the room where the manifold is doesn't get too hot. How come GSHP over ASHP? Haven't heard of anybody here installing one recently at all.
  14. ?? Any kit I've ever used has been a specific one layer chopped strand kit. I didn't know multi layer was a thing.
  15. Just needs a good rub down with fine sandpaper and it'll be fine. Topcoat in theory protects against UV damage, otherwise aesthetic. Looks like a pretty good job btw.
  16. What you're proposing to do is illegal under the 1980 and 2002 water industry acts. You'll need to apply for your own connection to SW, or drill a borehole.
  17. For context, bathshack would have been the cheapest local company in the past. We used them before but not impressed with their quality/prices this time round. Soaks, Neptune, and all those other places in Boucher take the piss with the prices. Never considered Beggs.
  18. We got ours from bathline (Haldane fisher). Good quality stuff and got the price way down from the first quote, something like 40% lower
  19. Building control will most likely want to see a piece of paper showing that the ballustrade meets the loading requirements... So you might need to get the glass supplier to include these fixings as supply it as a "system" and confirm it meets the requirements.
  20. Assuming this is freshly compacted soil, as the grass grows and nature does it's thing, water channels will develop through the soil profile and natural percolation will start.
  21. For the ridge beam, our guys machined a length of C24 wall plate timber to the same angle as the roof, and fixed it to the top of the beam, then (in our cause) roof panels just screwed in to the timber. In your case the roof joists would be fixed in to the timber as well, joiner will know what to do.
  22. Can the ridge beam be brought down so the rafters sit on top? Means no cold bridge at the ridge and a simpler fixing detail.
  23. What other electrical appliances do you have that could maybe be faulty and consuming large amounts of electric? Tho with that consumption there would be a lot of waste heat generated and fairly noticeable in the summer. You could completely isolate your ashp and DHWC for 24hrs and monitor the house consumption.
  24. I bloody love mine. If you build your house right, and don't scrape the bottom of the regs to pass U values, your house will be warm and cosy no matter how you heat it. We still haven't had our heating on this season yet. Our annual energy consumption is about a quarter of the national average for comparable size.
  25. Who is your mortgage provider? We went with ecology and everything was completed in 6 weeks. 12 would be worst case, and assumes you've not got your documents etc together. If you and broker are on the ball, no reason why an application would take more than 8 weeks. You can start that all now, ask what the provider will require and start putting it together in a folder.
