Everything posted by Conor
The system you are describing sounds like EPS, reinforcing mesh with base coat, and silicon / acrylic render skim on top. These are somewhat breathable (EPS is like a sponge and is vapour permeable) and moisture will make its way out eventually. I'm sure our in-house render expert will be along soon. In the mean time, ignore the rest of us.
MVHR ducts and manifold
Conor replied to Apple's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Need to see a drawing, floor area, required flow rates etc. In the meantime, I've a hybrid system. MVHR, 125mm ducts to each floor (three floors in total), then a 6 port manifold serving each floor. Keeps almost all of the 80mm runs to the valves under 10m, and meant only two cuts through the slabs at 125mm each. -
I found the roof lights upstairs had to be open a good couple of inches, or else the reveals would be soaking the next morning. Rest of mine are tilt and turn so just left them tilted in, so about a 80mm gap. Experiment and see, but I'd leave the top floor windows / roof lights on more than just the trickle latch. Also, don't raise the temp of the house too quickly. Start at 12c and bring it up a degree or less per day. Two weeks to get to 20c. We soon sealed up and used dehumidifiers tho, more efficient and effective. Bought five £120 ones from Screwfix and sold them all on a year later for £80- £100 each.
Get a dual rate. I'm surprised they are not the standard now. You can have an normal tariff on a dual rate meter, but not the other way round.
Your house is full of 100s of litres of water. Open the windows. It'll take weeks to dry. All heating is doing is lifting the water from warm parts and depositing it on cold parts.
Would a reciprocating saw do the job? Easily handle 4" stems. I find them way more versatile and easier to use than a chainsaw. Unless you need something long reach?
No recommendations, but we had a large (6x2m) shade specified. I priced round a few online aluminium manufacturers. Prices were all in the £5-6k range for supply only. We could have had something made locally from steel, but would have needed substantial fixings that were not considered when designing the wall (basically a set of narrow concrete columns housing the 5m wide windows). Instead we winged it, extended the fat roof above by 600mm, and so far no overheating issues. There are definitely more elegant, smarter, practical and cheaper ways to keep heat out.
Is this internal steel? Is it not being boxed in then? What about fire protection? Anyway, sand back the offending areas back to the steel, re prime and paint again.
Send some pics of the finished roof please. If they encountered something that was not included in the quote, then that's fair enough. If not, you'll need to come to some sort of agreement. I had this with our builder, he openly said he messed up the floor area in his quote and would be out of pocket. There was a discrepancy on one of the drawings (dims all correct, one annotation on bottom of drawing stated wrong floor area) so we my half way. Sometime need to be pragmatic. Sounds like this guy mis-priced the job and is chancing his arm.
Concrete Cavity Fill Techniques For Large Houses and Volumes
Conor replied to jwoodhead978's topic in Brick & Block
Why is the cavity only 65mm? What's your wall buildup? -
2.5tonne mini digger. Set an area with polythene sheet for the mix to be dumped out. This time of year, you'll have a good couple of hours or more working time, at least. Have a mate with a shovel to help get it in evenly and spread out. Mini digger hire will be less than half of a concrete pump. And I'm sure you'll have a few other jobs for it to do while you've got it. If you've never operated one before, get it the day before and get practicing. Valuable skill to have. -
We got our from Martin Phillips carpet, all the carpet they sell is low tog and suitable for UFH. It's not overly thin anyway.
What design and heatloss calculations were done? Do you have a table showing required for rates fro each zone? If it was designed for a 30c flow temp and it's set to 25c, your house will never be warm. Oh, and nothing wrong not zoning individual UFH loops, in fact better as a single zone. All three of my manifolds are set like that, I run the house as two zones and it's perfect.
We've normal carpets with the special underlay and it works fine. You don't need that much heat output upstairs anyway.
One at the back and then a steel strap along the front, fixed to the unit sides, not the worktop. But the adhesive they use seems rock hard.
All we did was leave the sink in the box in the kitchen and the guys from the worktop company did all the figuring out when they came out to template. Can't fault them. Ours was then glued on by the worktop fitters. I didn't trust it so fitted a a timber batten across the back. Not fallen off yet.
You need ~15mm cover over the pipes, so about 16mm for a pipe, a couple mm sticking up here or there meaning you need a min depth of 35mm. They say min 50mm on basis you'll have high spots and it'll be thinner. There's not much you can do about it anyway. Move on to the next job.
Applying for mortgage.. after build started?
Conor replied to sunflower's topic in Self Build Mortgages
+1 for ecology. -
It's a £350 extra to convert if you have bought the ducted version. We bought 5he extract version but didn't install the duct work as was almost impossible to get a good run that would have worked.. ducts too big for either burying in floor or in ceiling void below. Tbh, if ours is on its either 9 or P. I don't think any downdraft works on low speed, you need high velocity for the effect to work. Rest of the time it's off and the MVHR copes well with general steam and light odours. In your case, either open the nearest window (I assume you have at least one openable window in the kitchen for BC compliance) or install a in-wall extractor fan.
No issue using brown pipes above ground, as long as they are not exposed to light. Most of my internal soil pipe work is brown as there was a better range and availability of fittings. BCO happy as well.
Footings work by spreading load over a large surface area. This pipe will only be a relatively small surface area. It'll make no difference to the structure of the house. I do think that BC will ask you to lay a new land drain away from the house and cut this one off. The risk is the pipe fails, water starts escaping and flowing, erodes away the earth and creates a major weak point in the earth below the footing.
If the pipe is just going under the footing, then should be easy enough to divert it a metre or so. But first trace it both ways and see what it does!
Ha, no such thing exists. If there is a detailed drawing, I'll only show indicative lines only Get a plumber in and they'll give you the story in an hour or so.
Small blanking plug missing from my Willis heater based UFH
Conor replied to dnb's topic in Underfloor Heating
It'll be 1/4 or 3/8, likely the latter as widely used on heating systems and components. I bet if you unscrew one of the pressure gauges, it'll fit. Definitely worth bringing it down to your nearest plumbers merchant and getting it right first time. Or just order a selection of plugs, will only be a couple quid. A small box of random brass bushes, reducers, straights etc is sooo handy to have. -
Wooden Floor thickness UFH and heating costs
Conor replied to Foldyard's topic in Underfloor Heating
How much insualtion do you have under the screed and what flow temps using? Everything else is incidental.
