scottishjohn
    23
  1. I hear what you are saying but maybe its the very low angle which is allowing the water to just sit and not run off ,so making it a very wet area most of the time how much gap is between the the roof and the plywood -- when I looked at zinc roofing -- a real air gap and a minimum slope was very important to stop corrosion from what you say there is no gap -so water could just sit there by capillary attraction + never dry out I am guessing that this aluminium roof is a coated one --so maybe also movement has worn through the coatings where fixing touch --and then you loose some of your corrosion protection
  2. there will be one in rainwater harvesting system
  3. is it a heated space in the rom below the flat roof --If so thats not enough insulation and what is theroof made of and what us the surface on flat roof that you wish to walk on
  4. insurance would require it to be done by a sparky I would think and along with a record of test and when they are done
  5. depending on tank size and usage you might not have any excess --most rainwater systems have a top ballcock from the mains for when you run out of rainwater
  6. Idoubt it is actually that much more expensive once you factor in paint +labour and then doing it again later and yes that not the question he asked -- maybe he should have asked that earlier in the build ?
  7. have to ask why use painted wood cladding when you coculd use man made concrete board that looks the same ,but does not rot away or need any protection
  8. is it not just a case of your soakaway tanks are not big enough -- maybe make them into rainwater harvesting and use it for house toilets+washing machine + garden it would also cut down on your water usage bill?
  9. I used the 150mm steel studs to partion my building at front with staggered19mm plank then fireproof Pb -- solid as a rock once you get the PB attached to it and very sound proof -by the time you have the fire curtain hung in the middle back of building was a 9"soild killer block wall to 8ft ,with butresses then same 150mm stud to go to the roof If it was not a car workshop --might have been tempted to do it all in steel studding but also was getting a bit high in the center bought the fancy tool to join them together --not impressed with that --would us wood nogins if doing it again would def consider using it in a house --when did you last see a straight bit of CLS
  10. I agree with all above- the extra efficiency only really works in countries like canada where you have months of -20c which is only time GSHP will have big edge on ASHP the uk is never going to be cold enough long enough to be worth the extra costs and as you are building a very warm house anyway -- heating costs will be small and if you have mains gas -then that is still the cheapest to run and probably to install as well
  11. they used REAL wood and did not sit it on the ground probably large lumps of stone where the structure would hit ground with lots of draft space under it
  12. you mentioned sand as sub soil in one post and now peat --not a combination I have ever heard of peat needs bog to form --sand is free draining very strange
  13. pity my hill faces s/w ==or that could have a been a good usage -- select country jewish cemetry
  14. aty leats yuo have a house Ican,t even get started at this rate i think i should ask planning to include a mausoleum in the grounds --in case i never get it finished +build that first
  15. got test results back ==water is fine however although the lab complies with all required codes I still might have to get the council to do a test -- why ,because I do not have the qualifications to take the samples !! anyway water is fine which what we needed to know for now last email from head of planning was to say that due to covid he can give me no time scale as to when a planning application or site visit can happen my spies tell me it could be next year before they are working normal --and that is measured on a glacial time scale
  16. before ordering make sure your delivery includes damage insurance - as part of delivery cost
  17. delivery from europe would be main cocern on costs
  18. post up costs for products and quoted delivery costs--not a guess
  19. loking at that tank ,but twin coil -for solar and ASHP - set ASHP to 35c and that would allow solar to work most days of the year ,probably? maybe a thought - separate tank for DHW?
  20. If that your idea then look at VELOX ICF -- that would be easiest to do that with
  21. render both sides?- ask the maker of your chosen system
  22. which ICF system ? poly type --then maybe not --but this is just a feeling woodcrete -you going to get a good bond for the render on it and easy to fix things to it just my feelings nothing to back it up could be talking rubbish
  23. As I said at the beginning If it was me I would rake out and repoint all of it --not just where you can see holes lets suppose that these holes you can see and others you cannot see yet could hold water and then freeze and expand or maybe it is leaking through the outer skin to void how long before it causes a rot problem on TF inside No one can say so If it were my house I would sort it sooner rather than later we can gather from quality of the job that maybe other things inside this ,like the house wrap may have been fitted to same std as the brick laying
  24. I would forget it and move on - as I think it could be classed as a professional fee --its a test --not actual construction - so not relcaimable my arhcitect told me something interesting about new changes to VAT reclaims If you are vat registered --then you pay it and reclaim it -- no need to got HMRC -- If that is correct that should allow alot more things to be claimed t I cannot say this is gospel --but worth some checking out-- some corvid thing to take load off HMRC maybe
  25. I agree -- but no convincing the wife that it will be she opens windows every day even if its below freezing outside -- So I think this is one battle I will avoid
