scottishjohn
    23
  1. trying to get a design and basic construction that we like and planning will accept take house down to one level -repair all walls replace oak lintels with concrete ones etc parge coat it with waterproof cement then build TF inside +use closed cell foam to finish off the water proofing and air tight seal and insulation and stick TF to granite walls the calculation i have been sent by the foam manufacturer is 100mm closed cell -in two separate layers allowing first to skin then hit with another 50mm + 22mm insulated PB + service void will give walls at 0.25value and with only a small reduction in room size 150mm per wall--maybe 50m of closed cell and then other insulation - but keeping secondary wall to 150mm ok the floor --torn between block and beam -to get easy services and solid concrete Is there much difference in costings ? yes it will be UFH same goes for new roof -which will be a flat one to sit a Tf/sips house on partially second storey and give large balcony areas all round thinking maybe of 6m x10mm and lower level will be 26m by 8m comments and suggestions please need to find a builder to quote for removal of top layer and putting a lid on it my health has gone backwards somewhat --so have to accept i canot do as much as I would like with stone work -- too heavy for me I have thought about flatten and build in ISOTEX -but then I,m sure planning would require it to be cladded in granite and same old type of small windows in bottom layer I do not think i will get away with a total modern build on this site and I can find no one that would want the old granite -so no money back from that --Ihad hoped to find someone who would flatten + remove for all the stone work ballpark from architect to rebuild from scratch in TF what is already there is not on -£850 is his first guess --so that will not it in real world I have to think and I do not need over 400sqm+ then there is still the stable block to do later --maybe
  2. and because it is stuck to the wood of the roof there is no cold surface anywhere on underside so no condensation
  3. I would remove what you have done so far --let it dry out and get a froth pak -closed cell kit --job done - and if you want to then sheet the joists --no problem you can rfit your solid insulation after if you like and get even better insulation I hope your tumble dryer has a direct connection to the out side world or you will be making another problem the thought of making numerous holes in your roof membrane to vent the void is a bad idea and maybe making more areas that could leak https://www.abbuildingproducts.co.uk/froth-pak-600-spray-foam-kit.html
  4. pefect job for spray closed cell foam but I understand where he is now -and if like your picture he cannot get a draft though very easily to dry up any moisture - so could be just trapping in moisture to rot roof above If this space is going to be heated that makes it worse
  5. would vapour barrier not be better above the insulation --so if any condensation forms purely by temp dif it does not come through -- any slight gaps in insulation will allow hotter air to go up and start the condensation at the joints many cases of this with sips panlled roofs in alaska causing rot of osb sheathing in the panels at the panel joints when using shingles on directly top of panels -- solution was to make a second roof with a void so they have a draught and shingles stay cold .like you would do with a tiled roof using batons to lift them off and giving a gap
  6. THE MAIN THING THEY NEED TO DO IS STOP THE SELLING OF QUOTAS - SO YUO LUSE IT OR LOOSE IT. those boats will have bought quotas from uk boats --that what needs to be stopped needs to be caught and landed in uk by uk boats and when sturgeon gets independence thats what she will sell
  7. yes that i can see might cause a problem
  8. for all types of floor then ? If using ufh the diference in size ,presuming you do it in normal conditions will be miniscule ,eg ufh on at 22c can,t see there would be any need wood --yes i can see there could be problems if floor bounces etc interesting
  9. me being thick -- but what is pupose of decoupling mat maybe I been lucky but my lounge tiiled 15years ago with 450mm tiles on top of my suspended wooden floor in which i buried UFH not had any problems
  10. what ever his reason it works for me maybe with this lockdown coming he thinks something is better than nothing ,if the builders stop like at the start when we had full lockdown
  11. its that cheap I might have hired it just to play --even if i didn,t need it.LOL which I do as my site is so big lots of bits to move and tidy up plus fuel of course maybe it was because i greased the last one i hired from him
  12. a wee winner i think spoke to my friendly hire co given me a 6month old takeuchi tb290 9ton digger -- charges will be time on the clock @£12/50 per hour from now till 11th of jan and no delivery or pickup charges who says christmas spirit is not real thats a winner
  13. yuo would be the definative of that
  14. we have the only large fish stocks and crabs ,lobsters etc left in europe --cos the french and others have fished out their own waters long time ago and don,t get me started on the Italians -on net sizes and how they shoot all the migranting wee birds for sport as they come across the med -they do not even eat them ask any game keeper that runs a shoot about french and Italian shooters --if it flys no matter the size they want to shoot it and the ones that come widfowling to the solway -shoot swans and say theythought they were geese -- if you can,t tell the difference --like its white and a very long neck --then you should not be shooting -- so we definately need to keep the fishing and also stop selling of fish quotas by Uk fishermen - same as you cannot sell netting rights for salmon -use it or loose it
  15. and the iother place its bad is where there are more camps --belgium- nothing fake and just as valid as most of the other so called data backed surveys
  16. strange how the countries the immigrants pass through before they camp in calais have the worst covid problems -- another coincidence?
  17. on that subject looking at what ISOTEX are now suggesting for that a self adhesive house wrap by proctor- so yuo do you air sealing on outside of build and before widows fitted - wrap all walls inc round where windows fit -then seal when the yare fitted to finish it off-can also be used on TF looks good will be investigating that some more nearer the time -- its like tanking the whole house
  18. now if you talking big green houses like above -then the ground they are on can be the worst sort of land as they do not plant in the ground --just needs to be flat to errect the green house I got 30 acres to start with on my jetty -that could be used for green houses no problem --
  19. even the most bent businessman gets his books signed off -- we are talking forensic investigation which has happened a few times in the EU and every time it is stopped before it reports --
  20. and they have never balanced the books for the EU EVER --had numerous accounting firms and when they start finding problems --they get sacked
  21. if floor tiles are thicker --then carve some pB away so they can fit flush once they are loaded with adhesive --can,t be much more than 2 or 3 mm to remove from thickness of PB not ideal but it would work might be easier to just cut out PB there and fit thinner ply or maybe 9mm cement board to get space needed to use thicker floor tiles for the upstand you want
  22. then its not marble --just that you could have polished up cut edegs if they were marble so when you cut them what colour is on the cut edge --maybe different than top ?
  23. or one floor tile dead in middle of door way ? Iwould play about and see what going to look best and see how cut bits at edge are going to work out
  24. are they tiles or real marble ? looks like marble in piccie
  25. well if start wanting SE survey and report that the structure is strong enough to be moved etc --then that will kill it and would mean you would have to have full drawings before you start --so savings soon vapourize . think you need a very agreeable local planning dept - so that will be a big NO for D&G
