scottishjohn
Will I need a compound mitre saw for a diyMax build?
scottishjohn replied to epsilonGreedy's topic in Tools & Equipment
Ihave a titan 9" angle grinder which ifitted with blade for block cutting some 10 years ago worn out 2 blades doing block paving as well as a few metal grinding blades gearbox has been noisy for 5 years fitted the spare set of brushes supplied with it still going strong. I did repack gearbox .but still makes noise think it was £30 all those years ago --now £69 --but looks the same and it will still bite if your not careful !! very handy the way the handle swops round for left +right handed good cheap tool# I bought titan aligator saw at same time --thats still going strong and has been well abused -
then trying to do it cheap will be hard . If you lifting roof then you could always run a couple more rows of blocks round the top of wall to give you hieght? maybe just jack it up where it is with acrow props and secure while first row of blocks are added-then dop it back down--then up again for next row of blocks --or just pack it as you go , thats what I,ve done that before on old scottich barn . using a car trolly hack to lift --then adjusted acrows to suit ---tight against wall so it can not wobble how much height do you need? make up plywood box beams in lengths and slip in like a very thick sole plate , I made one of those to use instead of an RSJ could not get crane in to lift RSJ but made in plywood --was man handleable by 6 men --26ft long -to replace roof truss support that previous owner had cut out when removing supporting wall to make car show room bigger 15"deep with zig zag internal bracings all glued and screwed and one vertical support-you would need no vertical support as it would still on wall head its still there now 25 years later and roof never moved?
If you are changing the roof and the floor --sounds like you need a bulldozer and start again -it could end up being cheaper. nearly always cheaper building new -other wise you are spending lots of money on carefully pulling things to bits, supporting things ,trying to save things ,which is time consuming, then trying to rebuild around problems you already have and compromising all the time. with new floor built on top of original means all door frames etc will be wrong by 150mm (6")minimum,so you are now into altering walls and lintels to fit new door frames ,or have them hobbit size ceiling heights could be too low after --the list is endless ,so you need to think it all out now before starting
Use IBC (was "mbc") as a soakaway ?
scottishjohn replied to scottishjohn's topic in Rainwater, Guttering & SuDS
you are probabnly right --just wondered if any one had done it I am expecting ground to be very rocky anyway ,as its on a hill and there is a granite quarry further up the hill just a way of dumping all the rock in one go in the hole like a gabion . finally getting closer to getting the plots bought -after all the usual solicitors searchs etc ,etc -
more expensive and yes i did say fill the IBC with rocks and geo textile arund outside https://www.guttersupplies.co.uk/products/soakaway-systems/soakaway-crate-(heavy)-rainsmart-65t-flat-packed/?keyword=&matchtype=e&device=c&campaign=&utm_source=bing&utm_medium=cpc&utm_campaign=BS | Test&utm_term=4584345012945761&utm_content=All Products you would need 4 @£65 each to be same volume as 1 x IBC Iwould intennd to make big hole for 110pipe inside and lots of holes in plastic --weight of stones will keep it in shape will it not? -
Solar PV Diverter setup - "Head Scratch"
scottishjohn replied to swisscheese's topic in Photovoltaics (PV)
If it were me I would suck it up and make it hard wired for long term reliability a bit of conduit buried and cable through it. short cuts don,t always work out better in the long run . but I am a ludite by nature simple is best .LOL also leaves easy upgrade potential for other sensors etc -
As the title use IBC in its cage filled with rock and geotextile around outside between cage +tank + lots of holes what do think boys ?
that what air bricks are for to ventilate under floor sealing under joists will improve insulation dramatically --trapped air is best insulation you can get
Building extension over a private water pipe
scottishjohn replied to DC5's topic in Party Wall & Property Legal Issues
dangerous to use diggers when you don,t know where things are -
first job must be to find it get your water divining rods out AND FIND IT.and also your water supply pipe and fit a toby move it away from your extension you damage it --you will be liable for all the costs and claims from those downstream you really want a digger to be rumbling around over this OLD water supply. maybe now is the time to get the water tested --maybe it all should be replaced anyway ? asbestos water pipe sounds like 50 +years old very unlikley it was buried 6ft down --thats costs money 2ft is more like it very much in range of digger for new foundations !!! -
thats total bollocks -springs and water courses are rgularly piped just fit correct/larger than needed pipe surround it in solid concrete with inspection /access hole both ends of unsder ground section they cannot object to that
even more reason not to push the limits , if you get hurt doing and things go wrong house may never get finished you don,t bounce as well at 40+ as you did at 20. you are supposed to get smarter with age not more stupid. how many of your ladders are actually tied to something ?
If you not going battery then go 110v --then you won,t get dead when you cut through the cable there is a reason all site tools have to be be 110v by law you know 240 is DIY . even my cement mixer is 110 v
Before I break my legs, some advice please...
scottishjohn replied to ToughButterCup's topic in General Joinery
If its stairs to hump stuff up ,then better to make them smaller riser height and less angle to save the knees when loaded 200mm riser( 8") is too big 150mm will be better to run up and down when carrying a load -
Vertical slate cladding & the pond
scottishjohn commented on vivienz's blog entry in Blackmore House
If it dpoes npot fill up by march --it never will you will need to fit a liner -
I just looked on u-tube --must be 100 videos on how to buildd a staircase -
first layer what ever you choose needs glue +as well as fixings to increase strength and cut down on squeaking. my choice 22mm t+g chipboard your design should state what thickness to match up with joist spacing and joist sizes.# everybody is guessing including me as i see no REAL definative spec on joists -150mmdeep but how thick+ what type+ what span ?
I would not be happy with no mechanical fixing at lower edge if this stud wall has a door frame as part of it , just asking for long term problems .when people bang doors you should use a thermal gun and find out where the UFH p[ipes are ? then fix lower rail so you miss them .
why not make stud wall on the floor to start with make it short in height - use top packers -then apply glue to bottom rail when you raise it up and fix top rail with spacers if needed to make it tight . lot easier to make stud wall on its back on floor
Air conditioner or air source heat pump?
scottishjohn replied to MrSniff's topic in Other Heating Systems
don,t confuse the non techie people ,not as though hes going to make one is it? -
If like here you can have a buried gas meter away from house or on the wall what ever you like --so they can just bring it into the plot and cap it off till you ready to connect ,just ask them .
-- get sizing checked by independant heating engineer-if not right size it will not be as cheap to run as you think and what happens if it dies -who pays to replace it for the rest of the 7 years
Protecting Your Money
scottishjohn replied to newhome's topic in General Self Build & DIY Discussion
good man -
osb +grp i hope my man would not fit any decking unless he could do grp same day -
when I get to that stage will look to see if they do a 2 pack sealer --that will not fade could it be the cleaner is eating it away?
