scottishjohn
Private road management agreement
scottishjohn replied to a topic in Party Wall & Property Legal Issues
been here and bought the T shirt you can make any agreement you want ,but if one of the nieghbours says they don,t have the money to repair --what you going to do ? would need something to written into the title deeds some how,same as you would do with shared septic tank --so if they don,t pay you can sell their house to get the money sounds bad i know --you can,t get blood out of a stone . or a neighbour you fell out with so you need a default position in the agreement that everyone understands and is enforceable without spending years in court arguing about whose car is damaging the road . if it is a possibility for council to take it on ,what ever it costs it will simpler. we had all these osrt of problems up here with new estates --builder built house --said hr would do the roads last to stop damage guess what --he went bankrupt so now council insists on all roads and services be complete before ANYBODY moves in. my problem was with an equestrian center who ran horseboxs up the road and damaged and never had the money to repair it tried blocking it --not allowed to --so If i got all that crap when it was only one other person --what would it be like with more!! -
Fire spread/ garage to house.
scottishjohn replied to Russell griffiths's topic in General Self Build & DIY Discussion
my rememberance of garage attached to house is full fire protection+vapour protection to house so will need alot more than that . will be double or triple layers of drywall fire board on ceiling and smoke barrier might be easier to build up divining wall like you would if it was join to another house sharing loft floor of garage must be lower then house to stop petrol on fire running in in you have a door +that will need to be fire proof --if you get mean BC go check regs -
clearfox Eating worm monster arrived
scottishjohn replied to readiescards's topic in Waste & Sewerage
ouch--air pump i think -
nope --no such thing --your planning is what it says it is anything else and your in trouble--so you want to change it --put in another application complete with updated plans etc
think you just said it all "demolish +replace"--to try to start changing it after it was got on appeal --sounds like problems
Insulating an existing corrugated roof.
scottishjohn replied to Dee J's topic in Roofing, Tiling & Slating
first stop is building control regs to see what is minimum insulation value on roof and walls ,and is there a dpc in floor+ walls of the building any conversion you make will have to comply with CURRENT requirements for a habitable dwelling -as it is a change of use ,you may even find that the roof structure will not pass for a dwelling if it was an agricultural building to start with .- 1 reply
I missed the costs of the units ? could you repost -
wouldn,t have it as a gift -no stabilising bars going front to back from 4 bolt bases to spread load from bases £1000 brand new gives you a clue on the quality had enough garages +ramps and seen all the problems of ramps fitted to doubtful floors you start swinging on a g/box and it is easy for them to come loose from floor If you are going use that --then floor needs to be minimum 8" with lots of weld mesh and BIG bolts http://www.garageequipmentdirect.co.uk/contents/en-uk/d12.html look at second one down --"boston " that is actually a hoffmann under different name --and is same set -up as ones i have -you can swing on it all day and it won.t tip over
listening to the video. It don,t sound like its seen a grease gun in years and even with play in pins its worth greasing it EVERYDAY ,while its warming up in the morning, if you want it to last longer and if it had been done daily to start with it wouldn,t be a rattling now oil+ grease is the cheapest set of spanners you will ever buy
the advantage of a jcb is you can drive it on the road all depends how serious you want to get ,but a jcb can do most things
Getting Fit for Self-Build
scottishjohn replied to Ferdinand's topic in General Self Build & DIY Discussion
try telling HSE and your employees lawyer that if you have a worker with a back problem can,t think of any gearbox on a modern car that,s less than about 40-60kgs old viva was fine --not now they all FWD boxs with difs -
£1000 can be seen working before you unbolt it to put in on your trailer not trying to put you off --but if you have the space +height i would go for 4poster with "wheel free" beams if i was having one ramp only
wait till you get to my age you just a boy 67 and starting to do a build this year --.LOL must be nuts!! -
a manual handling course??? that means you won,t be lifting anything then --25kg If i am not mistaken as being the max for one man lift a bag of cement is 25kg I remember when a cement bag was twice that plenty of wheels +tyres that are more than that now -
Insulation on Existing Floors linked to New Extensions
scottishjohn replied to slridg's topic in Heat Insulation
if you sticking to "thin insulation" better make sure its PIR --not eps -far better insulation value -
buy a gorilla gripper for 8x4 boards one handed getting a bad back --will be with you for ever --I know so don,t tempt fate--its not the weight its the funny angles you twist to lift things https://www.ebay.co.uk/i/183430311050 myabe some cheaper if you hunt around If you doing plaster boarding single handed buy or rent one of these cheaper than 2 visits to the back man https://www.ebay.co.uk/i/201969018140 -
you can get up to 5hp single phase motors now but iwill be looking at a 3phase supply if possible for new build -for all my lathes ,millers ,welders etc but with modern invertor tig welders you don,t need 3 phase anyway --just i have a 375 amp synchro miller tig machine and the new units are much cheaper as well--you used to need 3phase to get good smooth welds at big amperages--not now with invertor
the ramps in my garage have motors that can be wired either single or 3 phase ramp only need a 2hp motor so --so a single phase 2 hp is no problem I ,ll sell you one if you like !! 2 poster hoffman 3ton
unless your going to use SIPS roof panels you still going to have to insulate a "bison" beam roof .. we have a flat bison beam roof on a petrol station --it has 4" of polystyrene laid on top of hot poured tar.then roofing felt +chips villains tried to break in through what they thought was felt roof --got a shock when they hit the concrete best of it was i did not know for 6 months until was up there cleaning out gutters found this big hole --but it never leaked inside --the hot tar sealed it all very well there are other ICF roof systems like the velox one which is made from preformed wood crete http://velox-systems.co.uk/products look under ceilings and floors or you can go for a poly type see https://econekt.co.uk/wp-content/uploads/2016/02/ECONEKT.-ICF-Elements-Brochure2.pdf loads of different types available
as it has a vent to atmosphere to allow in air --that has to be prime suspect for the smell if you get a situation where air comes out rather than going in . I assume it has air admission valve on the vent pipe, same as you have on toilet waste system--maybe a bit sticky? certainly i will have no problem in siting it well away from buildings -
how expensive is expensive? -
cost I think no need for cranes and definitely hurricane +fire proof
any body heard of this before. watch the video makes me wonder if you could not do the same thing with gyproc "jumbo drywall framing =cement board panels??
then you could do it the spider tie way ,if you like . whole house is a nuclear bunker,then wrap it in insulation
