scottishjohn
    23
  1. ASHP is nothing like an air con unit it runs on electric I suppose it depends how cheap you get your hot water from distict heating system . It needs to be outside the building and does make some noise,less than air con unit so position from neighbours needs to be though about
  2. maybe needs more coats to seal all the porous surface of the grout stuff i was going to use said 2 to 3 coats maybe choose a black grout?
  3. bolted to a foundation ? thats has DPC belowit?
  4. Iwas told the same +didnt, --but 4 years on it is getting discoloured in places ,especially in toilet --so will not be listening to "professionals " again
  5. so if you so good at quoting why did you not ask the guys if they were sure that was enough . and ask for breakdown of costs labour +parts. my roof man would have said was --no OSB- -go ask someone else if you want OSB proper 19mm t&g flooring mdf only his quotes are very simple £100sqm for making a new grp roof so he would have been more expensive --but maybe better in long run especially for balconies I,m not trying to rip people off by getting cheap quotes, I ve had cheap quotes and seen what they intended to do and said no thanks like double glazing one time --got price then noticed all plasterwork etc was up to me--they didn,t get the job--they wouldn,t give a crap how they pulled it out they didn,t have to fix it they came back 3 weeks later and wanted to know why --all of a sudden 4 days later they are back the plasterwork and touch up with my paint was included--they were very careful how they cut out old windows needed hardly nothing other than decorators sealer--to start with they said my inner widow ledge would have to go --it never was moved ,but by same token don,t try to rip me off- with materials listed in quote you can see if they are using what you would consider correct quality materials
  6. yes I know ,thats why i asked cos any advert you see they always show NO gap to make them look better. did you seal the grout
  7. I take it you have a tile laying machine to place these monster units. you won,t hand lay them 60kg ? why would you need to tile in small bits around pillars -- just cut out corners of tiles .sounds like you need a few osb 1200m x1200 mm tiles to play around with it and then use them to cut templates for nasty pillar fitment --and scribe on to real tiles. no one can see what you have got so it will be a nice krypton factor job for you alone. osb tiles are the answer to working it out you bought the tiles yet ? maybe tile maker might have a bit of software he can work it out for you
  8. slight derail what is minimum you would want if going for PV and maybe selling some back in future
  9. I agree with that --local trades always want to do "a time +materials " rather than quote which i just won,t put up with now --unless it really is something that cannot be quoted for , local plumbers are the worst --never have all the common fittings and keep disappearing off job to go get them . they just make the job last all week and work slowly man comes into me and says "how much to do a clutch on a mondeo"--he expects me to give him a quote and stick to it .then usually expects it done super fast would be great if i could say the same ,and then make it last all week
  10. It shouldn,t most portal frame buildings are ontop of a slab and portal bolted to slab DPC is under the slab now it is not that type eg post holes and frame legs dropped in them+ concreted ,then concrete floor laid inside that tank all the perimeter floor in between the legs and up the legs --job for your structural engineer to design and detail for your plans, could be he will want you to dig down at outside and tank that. might easier just to lay another slab with dpc on that one and around the legs--job for the architect or SE to keep BC happy If its an old agricultural building ,may not even have a dpc --farmers get away with everything
  11. bottom line if you use one man band trades --you got sod all chance of getting money back so use trades with good rep if in any doubt. probably different here as a very tight knit area --you can soon find out who not to trust by asking around but alot less choice as well. I must a have a reputation --cos when I look for quotes very few reply -cos they know I ain,t going to take no crap job. and would go knock their door very quickly if a problem . If you go for the cheapest you usually get what you pay for
  12. I,m very much a scuffy out door type --so that is what is planned for my build . To be fair I have mixture of hard floors in present house of quickstep and tiles --been down over ten years and the quickstep still looks good and its in kitchen and hall ,so high wear zones the wife after living with them for years now and seeing just how much crap must have been sitting in carpet is a full convert and would never go back to soft floors did you butt those porcelain planks up tight and if not how wide a gap+ what sort of sealer on grout
  13. no not really --costs a few percentage for them to take the card payment between 3-5% usually then about £50 a month to have the facility +machine--for very little usage so I would be suprised if builders had a credit card facilities. builders merchants --different story ,as they would be happier not giving credit to small one man bands sometimes
  14. thats why so many people ban shoes in the house -- cuts down on damage dramatically you want no damage,then cermaic tile it--good choice if under floor heating
  15. moved this from your other thread "Thanks John, damp is a concern. There is a tiled gutter along the ground between the two down pipes, maybe we should extend that. I quizzed the tenants when we looked round it, they reckon it isn’t damp, hopefully our surveyor will agree! I’m hoping that there’s a bit of a gap (just a foot or so) under the floor beams, it sounds pretty hollow". do not rely on the surveyor if all he being paid for is for a mortage application need a much more in depth look then they ever give .the fact you know someone has made a half an attempt tells you there is a problem and needs sorting right first time get professional advice now as how to cure it .my guess its tanking brick work and pouring new concrete floor with a DPC.stud walls with vapour barriers +thick insulated plaster board and leave an air gap from top to bottom behind walls into roof space/soffits for ventilation --i could be talking crap --get professional help now before spending any money
  16. my first thoughts are if its victorian it is probably solid brick wall --no void ,so it will be lather +plaster and air gap up the back of it If you justinsulate and do not attend to wal dampnes possibilites insulating it could make all sorts of problems I am guessing you r ground floor beamns are just supported on soil and slate packers -- again dampness possibilites seal it all up and no ventialation you will get mould I see ground is built hard up to outside wall and door threshold is nearly ground level again another damp possibility if you can can you need a nice drainage system around the outer wall to stop dampness going into brick + then into house you need some proper inspection to address these possiblities before racing into insulation
  17. cost only,,but now doubt that is a real option with changes in laws coming
  18. if you have the option of mains drains --take it your own septic tank or sewage treatment plant needs REGULAR maintainance and emptying from time to time --all cost money so main drains if possible soakway drainage fields block as can reed beds
  19. if making a disabled w/c then look at regs for that all depends how nasty they going to be there are 2 types full disabled and ambulent toilet your sizes wont, comply for full dasabled check the regs 2m x 2m from memory wheel chair must be able do complete turn round in there you will find pklans on there for what is acceptable .or got tywfords and look at disability w/c washroom kit --there is a plan on there as well
  20. how much flow is there in this as from plan i am guessing it goes underground at bottom of your plot. surely work out max flow then put a concrete/pvc culvet twice or 3 times that flow rate with a inspection chamber somewhere in case it gets blocked although would be much simpler if you could do a proper deal with neighbour lets face it he can see a nice little earner here,as you would if in his place
  21. a good story for all to take notice of don,t skimp with foundations or weld mesh in them if any doubt on sub soil , also looks like age of house where no expansion joints required
  22. looks more like the pebble dash has come loose - tap it with handle of a screw driver or something all over if it sounds hollow in places--then thats your answer strip off and rerender looks like ex-council house --most of them in DG have needed re -render by now looking how little window ledge sticks out of render --that would suggest someone has already put another coat on without removing original . which is what council would do -- penny pinching down there is no drip check as far as i can see --so that will make more likely to have water behind it-maybe even some damp on inside--all fixable
  23. correct--just extend the pipe so its well above w/c pipe connection if you can
  24. would never buy a house with shared access - not getting this sorted now will make it hard to sell later and certainly devalue it. which is why I,m trying to buy both plots --not just one --so i get control of everything to start with
  25. don,t know about that but you could definately glue it on with a good PU adhesive --not sealer try a test on some spare bits if you need convincing something like sixaflex255 --used for bonding in car windscreens --that never lets go ,lots of other choices
