Mr Punter
    25
  1. The inclusion of this in the planning objection will make no difference. Planners are not concerned with who owns what. The overlay drawing from Survey Hub did not show anything of note.
  2. If the house is on level ground, the dpc would be the same all round but the ground will be higher at the level thresholds. I quite like the blue bricks below dpc.
  3. A mixture can be good. Evergreeens like Eleagnus x ebbingei Gilt Edge, Viburnum tinus mixed with some deciduous like hornbeam and beech. You can get mixed native hedging bare rooted and although it takes 3 years to establish it is v. cheap, looks great and good for wildlife.
  4. I assume the Survey Hub plans is based on Ordnance Survey mapping. The OS site plan can be a good starting point when tackling for these issues. If you post up the Survey Hub plan (anonymised) it may give a better idea.
  5. It would be sensible if you could take photos of the boundary, including any reference points if possible, so that if they install a fence in future you can ensure it is placed on their land.
  6. The forum at https://www.gardenlaw.co.uk/ is a good resource for these issues.
  7. Ebay is a good call. Look for second hand ones near you.
  8. Yes, the vapour control layer should go on the warm side of the insulation. It is not crucial in your case as the final layer of insulation is thin and is not bridged by timber etc. It will be much easier to staple onto the studs than the Kingspan. That was why I suggested just alu tape, but it really does not make much odds either way. It would be a much bigger deal if you have mineral wool type insulation fit the vapour control layer outside of it.
  9. I would fix the insulation boards with screws and penny washers, then foam and gaps, secure the polythene with staples, then plasterboard.
  10. 125 Micron (mu) / 500 Gauge. Transparent is better so you can mark the joists on the insulation with a sharpie and see where they are.
  11. Fit joist hangers to a timber ledger and nail the ledger on with Hilti?
  12. After you have fixed the top sheets you can either use foil tape over the joins or polythene over the lot. I would use foil tape as it is not easy to staple the polythene onto the 25mm Kingspan.
  13. @James94 are you also @James1994?
  14. Hi @James1994. We have not even started construction so I am afraid I can't be much help. We did a bit of demolition to find out what was what, then had to do some redesign. Not got pre-start conditions or building regs approval yet. Also, I was going to do the gutter with some flat roof on another part in the same material but building control wanted BROOF(t4), which is a fire resistance standard and I am not sure is GRP will comply. We will be doing similar to your abutment gutter detail. I am not sure how we will do the outlets at the ends. Probably leadwork into a hopper. We will get a roofing contractor to do the job. Your flat roof looks nice and neat. Hopefully you have some OK weather for the GRP. Can you post up some pictures of progress?
  15. Well worth 5cm to avoid a kick in the bollocks!
  16. @Faz & @Conor I understand this but there are times when you need to connect below ground. I am surprised that the fittings are so poor. It is a pain if they go wrong and the are 700mm below your nicely paved drive or patio! There are a lot of below ground MDPE fittings out there and there must be millions underground. I think everyone would agree not to join but sometimes they get damaged by excavators, tee off, reduced etc. This seems a very high failure rate. Is Plasson, JG, Floplast etc all the same poor quality / high attrition?
  17. Insulated plasterboard is quite pricey. Are there many sockets, switches and rads? Thicker one makes stuff a bit easier to run but not much in it.
  18. If this is the full width of your property can you not set it out as @ProDave has suggested, so the edge of the wall comes out at 90 degrees from the house? I assume there is an internal party wall that you can use as a reference to get the external line. Even a sniff that you are building where you are not entitled to and you will be asking for trouble. Hopefully you have taken account for gutters, fascias etc. The party wall surveyors are not interested in boundary disputes or who owns the fence.
  19. He meant the house build cost was £200k which equated to £815 per square metre. Trouble was he was driving with one hand and rendering a wall with the other, while supervising some tackers and quoting on another job, so the texting was not the perfection we have come to expect from young @nod.
  20. How so? I have not read them.
  21. @tanneja do you have pictures of the floor from underneath? Interested to see the ends of the joists and the mid spans.
  22. I really think the job looks excellent. Well done!
  23. Agreed. To all other readers, don't use 18mm chipboard onto joists. 22mm only please. It is cheap enough anyway.
  24. But the OP, who is not an experienced builder, is asking if they can build a 315m2 house for £250k. My answer is no they can't as it is less than £800 per metre.
  25. Interesting. I did not know this was an issue. Is there evidence for this? Any particular make / type?
