Mr Punter
Hello and welcome. It is unusual but useful to have a cottage with high ceilings. Have you made a start, or are you at the planning stage?
Could a wooden window made on site get BC sign-off?
Mr Punter replied to epsilonGreedy's topic in Windows & Glazing
Stop it you hippie. -
Connecting sole plate to block work with Marmox in between.
Mr Punter replied to SeanDean's topic in Timber Frame
I would have stainless steel restraint straps externally. Have the top bent over top of the sole plate and then rum down the outside 500mm and fix to the blockwork with plugs and stainless screws. Get them 1200 long and cut in half. Light duty if the engineer says it is OK.- 28 replies
- sole plate
- marmox
(and 4 more)
If labour is cheap in Lithuania I would get them painted and delivered. -
If you have a section drawing it would be useful. Handy to see foundation, ext level, slab, insulation ffl etc.- 28 replies
- sole plate
- marmox
(and 4 more)
Solid conductor wire to 2 stranded circuits
Mr Punter replied to NeilScotland's topic in Power Circuits
The Wago 221s should work for solid and stranded - thick and thin. -
How to fill large voids left from skirting board removal?
Mr Punter replied to Oxbow16's topic in Plastering & Rendering
Another vote for skirting. Or you could tile. -
SSQ or look at the range at Roofing Superstore https://www.roofingsuperstore.co.uk/browse/pitched-roofing/roof-tiles/slate-roof-tiles/natural-slate.html
Painting timber windows for new build
Mr Punter replied to MortarThePoint's topic in Windows & Glazing
It is well worth getting a sample. I had a front door with painted finish and it looked cream rather than the white I ordered. -
I have seen this on a project. They had some breathable insulation on the outside. Probably like the Steico stuff. Also, some internal walls have OSB sheathing added for racking strength.- 28 replies
- sole plate
- marmox
(and 4 more)
2 of the Wagos with 3 terminals. Don't connect the earth if there is none on the transformers. Blues on one Wago, browns in the other. -
Gloves to prevent finger amputation.
Mr Punter replied to epsilonGreedy's topic in Tools & Equipment
You are unlikely to sever a finger with a 4" grinder. A tendon, maybe. Eye protection is at least as important, Sometimes bits of blade can flick up into the eyes. -
Can't the straps go on the inside? less likely to corrode.- 28 replies
- sole plate
- marmox
(and 4 more)
Hello, from two Lake District Passive House wannabees
Mr Punter replied to LakeDistrictEugene's topic in Introduce Yourself
It is not easy to tell if timber has been treated. @Faz 's "old school" approach could lead to trouble as it looks like a commercial scale site. We have recently used a community timber recycling scheme, where we keep the waste timber separate from other waste and they come and pick it up and take it away. Works out half the cost of skips. We also use a firm to collect waste cardboard. Just break down the boxes and store them in the dry. Free collection. I think we could have sold it had I had the time. -
It is not a great plan but if the fire is very hot you can get timber to burn fairly cleanly. I guess the alternative is that it goes to landfill. Many years ago we burned all the timber from a bungalow on site. -
Not good enough I am afraid. There is plenty of time to finish this and tidy up during lockdown. I will give you another 2 weeks, then I expect some photos.
Not sure where your FFL is related to the photo but I assume it is top of brickwork. Maybe look at removing the top course of blocks and filling cavity down to the foundation with concrete to get to your 140mm bearing. You could then run some coursing bricks and a course of Marmox Thermoblock as an insulated base to the timber frame.
From the photo you only have about 250mm wall thickness. If you are going with brick outer leaf you would lose a fair bit of space to internal wall insulation. Actually the cavity may be a fair bit wider - just the angles and the higher brickwork playing tricks.
Just tell them you are using 32mm pipe. 50mm will be expensive, expensive fittings and meter and not difficult to install.
Joining ceiling timber joists together
Mr Punter replied to Casti's topic in General Structural Issues
I would go with Screwfix cheapo coach screws like these https://www.screwfix.com/p/turbocoach-coach-screws-yellow-zinc-plated-8-x-70mm-50-pack/38295 I don't mind an impact driver if I am the person using it and I have a similar attitude to multi tool. Both are very annoying when used by others! -
Which tool to shave 5mm off a brick.
2mm is a very small tolerance. Is there not a trim you can use to cover the gap? -
You could hire a diamond chain saw. I would get a grown up to help.
