Mr Punter
It is more the width of the footing. Extend it by at least 400mm on the low side and use some starter bars with hollow blocks, concrete filled. Add some weep holes low down. 800mm is no a lot but better done properly.
The render base coat and mesh is really sticky and forms a really good solid substrate to tile onto. We tried tiling onto the XPS and it just did not work.
I think that painted hardwood would look best. Other option could be aluminium.
I think we just used Weber LAC and the standard pink fabric mesh and then tile adhesive. It was on XPS.
The best comment I read was "I am a house builder and install air source heat pumps. They work very well with Under Floor Heating in our superbly insulated new homes, but they will not work well with radiators or old poorly insulated homes." It is about right I think.
AFP alluminium guttering. An ok business?
Mr Punter replied to epsilonGreedy's topic in Rainwater, Guttering & SuDS
I have used the plastic imitation stuff for lookilikey cast iron. For ali gutters I found Guttercrest good. -
But if you were in a converted flat or even purpose built over 15 years old your neighbours would not thank you. Lots of people work at home. Up, shower, breakfast kettle toaster, kettle again hairdryer lunch, microwave, fridge, computer printer, TV, lighting, cooker. Face it there is no way a normal person consumes 80% of their electric between midnight and 7:00 AM. Post up your last 3 bills and it will either prove me right or prove that you are not normal.
I recommend the non-slip textured GRP tread covers for those steps. I fitted some to some knackered outside steps that I would otherwise have had to re-tile.
With Economy 7 the night rate is 41% less but the rest of the time it is 16% more. Nobody in a flat wants to cook their meals or do the laundry at midnight so it can often end up costing more.
Do retrofit ASHPs need larger pipes to the rads?
Mr Punter replied to Ferdinand's topic in Air Source Heat Pumps (ASHP)
The boilers will be on sale for another 14 years. -
Average costing on an extension & 2nd storey.
Mr Punter replied to Ziggya's topic in New House & Self Build Design
I very much doubt the bungalow has an internal floor area of 1500 square feet. 800 would be more typical as it is 2 bedrooms. I guess the house you have shown would be around £750,000 to have built. @Russell griffiths says it like it is. -
Lower brick course separating along a 2 - 3 metre area of external wall.
Mr Punter replied to dssr's topic in Brick & Block
It does not look horrendous. Is it clay soil? Is there any way you could dig a small pit to expose the foundation so you can see depth, integrity and bearing soil? -
We did and it was fine. At least you have gravity working with you. You may even be able to keep the packaging on.
replacement window fitting - expanding foam or expanding tape
Mr Punter replied to riccol1966's topic in Windows & Glazing
You need the foam in any case as an insulating layer on the inner part of the frame. The expanding tape is then used on the outer part of the frame to seal to the structure. If you don't use tape you can use a mastic sealant. -
But it will only be 75cm deep.
I think they should manage. We got one up a flight of stairs with winders at the top. The doors come off these fairly easily.
There are some rules of thumb in kitchen design but they are not law. In a small kitchen there are often compromises and if you are happy with the current setup, don't change it. Why are you changing your current kitchen if it is less than 10 years old? They should be good for 15+.
Five months on from breaking ground I think they have made good progress. I like how neat and well planned it all appears. Inspires confidence. I bet BC will not be breathing down anyone's neck on this job.
Flat roof considerations: Safety, Rain and Shine
Mr Punter replied to puntloos's topic in Flat Roofs
Yes. -
Access via the small rooflight with a telescopic ladder would be my choice. They could clean the window from on top with a reach and wash taken up through the house. They could probably get there without actually stepping onto the roof. -
Most of the gas main is iron or polyethylene. I think the FF is PF which could be pitch fibre but I didn't know that was used for gas. SI and CI I guess iron. ST for steel? Maybe an experienced excavator operator could comment as they will have hit all of them over time. Speech bubble looks like it is pointing to a valve.
I would not mess about with a fixing point. Have the big window at a slight angle with self clean glass. I doubt you will notice unless a passing vulture unloads over it. -
Can't you get to it from the smaller rooflight? -
Get one like the V & A: -
+1
