Mr Punter
Gap between window and sill - new uPVC windows
Mr Punter replied to ST1978's topic in Windows & Glazing
The simplest thing to do would be to make sure it is all clean and dry, gun in a load of silicone and leave a neatly tooled finish. -
Well that's a poke in the eye with a pointed stick
Mr Punter commented on LSB's blog entry in Little Stud Barn
Be very aware that to qualify for Class Q this must be a conversion and incorporate the existing structure, not a replacement. This seems very stupid and petty in your case, but it is the law and from what you have mentioned your local authority would keenly enforce it. I understand that new foundations are a no-no for Class Q. -
What you have there is well within tolerances. If you laid some Astroturf you could use it as a bowling green. I assume the puddles were not deep enough to cover a 5p piece?
It looks like rain could easily find its way in, especially if it is blown by wind. Once it is in there it will be trapped. Also cold air can circulate around the frame. -
Help on conservatory upgrade.
Mr Punter replied to Andy DIY's topic in House Extensions & Conservatories
If the room has fixed heating and is not separated from the house by an external door is will need building regs. If you want to turn a connie into an extension it is normally best to remove and start afresh. -
+1 and even more so if you have the SE design based on the system. Can't you get someone to quote just to build the structure?
Yet another inner city infill! Get a 5p piece and lay it flat in the centre of the puddle. If it is not submerged you know it is less than +-2mm.
Maybe you are just getting the MAC address of the router.
The underpinning sounds OTT. It may be easier to do a section of wall at a time - demolish, new foundations, rebuild. There is always a danger that this will no longer be deemed PD, so don't do too much in one bite and retain / repair / reinstate as much of the steel frame as possible. SEs often just spec something that will work, with little regard to the cost. I had one spec 2 layers of A393 mesh for a ground bearing concrete slab. When challenged they were happy with a single layer of A142. Did you dig a trial pit to establish foundation depth? Also, have Building Control been to site? They often have a good idea of typical acceptable foundations in the area. -
Sometimes in garages it is good practice to lay the concrete to a fall towards the door in case of fuel spills. This won't work with the self level stuff.
I think I will. It will save a world of pain.
Brighton. Only 3 flats. Decent plumbers seem hard to find. Plumbing is 90% of callbacks.
Yes that is the plan. I will see if I can rustle up some quotes from some vaguely competent plumbers. Gas is a PITA but they are small 1 bed upper floor flats.
The only bit I am currently interested in is to run the pipes under the slab. GSR guy may not be needed until we have built the structure. Groundworker is doing foundations, drainage, water and BT. It tends to be we get a plumber for the whole heating, DHW, sanitary ware and kitchen plumbing part of the job. I didn't want to go to the trouble of putting this all out to tender right now if I can avoid it.
For 6 months, that just seems very little. We are on gas and have averaged 30kWh per day, plus 17kWh per day for electric.
Well that is a kick in the bollocks to any ASHP deniers!
We are starting a project in January and I would like to run gas to 2 upper floor flats from the meters at the front, under the slab and up with the external soil pipe. There is a 150mm concrete ground bearing slab with 150pir. We have not got a plumber on board yet. What is the best way to do this run? I would prefer not in the PIR as that is another flat. I am considering Tracpipe, yellow plastic etc. Do we need ducting? Is this a job for Gas Safe plumber or groundworker?
Are you sure you did not miss a zero from the end?
Exterior Wall Insulation - advice re options
Mr Punter replied to mdroyle's topic in Heat Insulation
It is a good idea if you are detached. You need to consider the soffit overhangs, windows reveals, soil pipe positions and anything you are planning to fix to the outside. I have seen it done with EPS and with PIR. I think EPS would be my choice. They use adhesive plus a few mechanical fixings for each board, then thin coat render with a mesh coat. You should try to get floor insulation done at the same time. All fairly disruptive.- 15 replies
- insulation
- exterior
It will be much easier to spread adhesive evenly on the backer board but quite a faff and expense to do.
That is a great finish. It looks very like your original image. Did you join the ends where the vertical meets the soffit? A couple of points: I heard that with some of the ventilated cladding insects are not an issue as they don't like the constant breeze from the chimney effect. We have used Tyvek UV Facade membrane in the past and it seems very strong and does not look vulnerable to insect damage.
- 63 replies
- cladding
- open joints
I was thinking solid plate. But I won't be paying.
Can you use some 8mm x 300mm steel bar to bridge over the screed?
The really big warehouse type steps are really heavy and difficult to store. Scaffold towers are awkward to climb or use on your own.
Gap between render beads and lintel
Mr Punter replied to MortarThePoint's topic in Plastering & Rendering
I can't work out why there is a gap, but it may be good to cloak the lintel and the gap it in whatever material the windows are finished in.
