Mr Punter
    27
  1. Filthy swingers bathing in a soup of bodily excretions and skin. They get what they deserve.
  2. I had exactly the same recommendation from a builder I know who does loads of work on rental properties.
  3. My boiler has broken down in the winter before and it was 2 days before anyone noticed. In a modern house it takes a very long time before you feel cold.
  4. That is a huge step up in floor space. Have you costed it?
  5. It would be nice to have a coping on the parapet with an overhang both sides and a fall towards the valley.
  6. I got planning on a site in zone 3a. It was town centre and needed redeveloping. If it was out of town we probably would have got nowhere. Zone 2 should be fine, just a few extra fees.
  7. I just met with someone and they have spent £250k on a planning application for 50 dwellings.
  8. You could tack on some hardboard of you are that bothered.
  9. Like a lamb to the slaughter... I have put in some CAT 5 cabling here and in other developments. It only gets used by a few purchasers. I have had a Lutron dimmer switch which was OK. I have some SONOS stuff for audio but the firm seem quite scammy. I am never quite sure what I want to automate.
  10. Strange because I recall that you can tile on it.
  11. Does this continue up to the first floor? If so you may need to remove the first floor section or provide support for it.
  12. Sometimes pir has a fibre reinforcement.
  13. I have seen these where they just say that no other sites are under the ownership of the applicant and so were not considered. You probably have to do this as part of a flood risk assessment, where you submit plans and EA flood map information. There are lots of firms who will do the report. Get lots of quotes!
  14. Well this guy did a fantastic job and reckoned it was his first go at tiling!
  15. Hi @annec and welcome. Just to recap: The house is 140 years old. You bought the house 8 years ago and 2 years later paint began to bubble and fail in several areas of the house. The roof was mostly replaced 8 years ago but you have had further roof repairs. At some stage after the problem emerged you had CWI installed and the outside rendered. A couple of observations from the photos: The plaster does not look original. Nobody replasters for fun so it may well have been to cover existing damage. Your second roof photo shows very little overhang on the tiles - either at the verge or the eaves. This makes it much easier for wind driven rain to find its way in to the top of the wall and down the cavity, where it is now less able to freely evaporate. It may not feel damp indoors as it is nice and warm and will evaporate away.
  16. No. That is not what it is designed for. It is manly used as insulation and they do a stronger version (Perinsul) to be used in a single course to prevent thermal bridging between wall and floor. Marmox also do a similar product (Thermoblock) to Perinsul but a fair bit cheaper.
  17. My son mentioned it. He is an electrical engineer designing building services. Maybe it is a best practice thing for H & S? I have often seen people accessing the fuse board on small sites.
  18. I understood that a 3ph supply and board is not considered appropriate for a temporary builders supply.
  19. I would be very pleased if architects would start showing 400mm thick external wall on their planning drawings. Far easier to then adapt for brick / block, timber frame or ICF.
  20. It would be nice to see some temporary guarding around the stair opening.
  21. Great progress and a really nice tidy site.
  22. If you have a scaffold tower it would be much better than a ladder. Are you just putting back the bits that came off, or renewing the whole thing?
  23. Yes, the builders who you had originally are definitely your best bet even if you have to wait a bit or pay a bit more.
  24. Don't tell @tonyshouse! If you plaster instead you will have a nice airtight layer. With dabs you often find that cold outside air can find it's way in and move around freely behind the plasterboard.
  25. Velfac and IdealCombi are very similar and part of the same group. They have ali external sash and timber internal frame. I have used both and they are OK. I prefer the IC as they have an insulated bit near the glass, so less chance that the timber will suffer with condensation. Rationel are also worth trying. Same group but installers rate them slightly better. Sliding doors IC are OK if the sliders are smaller. Rationel do lift and slide which is loads better. The IC fitting was fairly crap. We did Velfac ourselves.
