Mr Punter
    27
  1. Photo is the cavity facing side of inner leaf.
  2. MVHR is just to do with providing ventilation without heat losses. It is not suitable for heat distribution.
  3. No. It is the inner leaf. The rain will not jump the cavity.
  4. Much easier to get mortar on the beds than the perps. They have done a fairly crappy job. It won't fall down but I would not be thrilled to pay for this.
  5. If it is sound I would leave it on and go over it. Sometimes with old walls if you hack of the plaster you find big chunks of wall want to fall out.
  6. I think they may be OK for smaller areas but not so much for whole house, so that could work for your kitchen. I know of the mist systems going into kitchens in student housing.
  7. The sprinkler heads are very reliable. They don't cause more damage to your property than a fire or a visit from the fire brigade with hoses on full pelt. If a fire breaks out, only one sprinkler head would normally actuate. You may find that an existing water supply will suffice. Failing that, you could get a dedicated sprinkler supply connected. Once you have the system connected, it is up to you whether you have it checked and cough up £250 a year. Nobody will be around to arrest you if you don't.
  8. It looks like render and set.
  9. Why not just get sprinklers?
  10. Is the rest of the lean-to coming down?
  11. Before you do anything, tidy up the site!
  12. Leca is one I have heard of.
  13. When I have had a project with sprinklers I have the system professionally designed, specified and installed. You will need a tank and pump. The tank will be 1 - 1.5m3. The mist systems may allow a smaller tank but they are more expensive.
  14. I thought oil tanks were bunded?
  15. You may be able to use some sort of geomesh system to prevent erosion and stabilise the bank.
  16. The fire rated ones are £23.30 each, the non fire rated are £11.60 ex VAT. Cut them on a sliding chop saw. Get some nice meaty galvanised fixing lugs. With some windows these twist fit into the frame. Ask your window people what they recommend. God knows how to fit those cranked eaves windows. Make sure you have allowed for the gutter and downpipes either side.
  17. Before you pumped it out, was the water the same level as the gravel pit lake?
  18. It will still need foundations and sub structure blockwork. What is the outer finish? If it is brick or render, you may as well just go conventional construction.
  19. Why not just use standard 200mm cavity closers? There is a choice of PIR and mineral wool insulation ones. They close the cavity, stopping your blown insulation escaping, prevent thermal bridging and stop any rainwater tracking past. Some stainless straps to the inner leaf of block to secure the windows.
  20. I had a customer put solar panels on a 5 degree mono pitch roof which was North facing. This was in Sussex. Apparently the efficiency was not too badly affected.
  21. MVHR is all about ventilation - providing fresh air to occupants and extracting stale moist air. I don't see that this is appropriate for a garage. You will also need to run your unit harder to get it to cover the garage and if the garage is not heated you will need to have the ducting insulated.
  22. In England there is an optional requirement where you need step free access to any connected outdoor space on the entrance storey but otherwise it is the front door only.
  23. Forget the MVHR in the garage. A complete waste of ducting and the system. I had an insulated roof put on an unheated garage a couple of years ago and it stopped all condensation. They came in large plastisol sandwich sheets with 40mm pir. Single garage was £1600 plus VAT all in including removal and disposal of the old asbestos. Mine came from these people http://www.icroofing.co.uk/ There must be someone similar down your way.
  24. I think the PIR is a really good solution. You could fix strips of 25 x 38mm batten to the sides of the rafters to maintain your airflow gap. You could use further short pieces under to hold the PIR firmly in place. 40mm PIR is easy to cut but quite rigid.
  25. The downpipe is already discharging into the grid at the end of the channel. You could direct the flow a bit better.
