Mr Punter
Ask them to give a price for each valuation. You can then weigh up when to do the drawdowns.
With the passive slabs you may have to remove a lot of material and fill with compacted stone. If you are piling, the augered method causes less disturbance to neighbours than driven.
Average number of trench concrete blocks per day
Mr Punter replied to iMCaan's topic in Bricklaying, Blockwork & Mortar
The guy in the shorts has done well not to fall in. Was this knock down and new build? -
What do you want from an architect?
Mr Punter replied to CharlieKLP's topic in Surveyors & Architects
I think you may do better with the sort of schemes you are working on for your current practice. Perhaps see if you can poach some of the clients you get on OK with. Self builders often don't even know what they want from an architect, or what to reasonably expect. Looking at the whinging about architects on here should be enough to put you off! We seem to pay architect fees of between 2% and 3% of build cost. About 1/3 for planning and 2/3 building regs. -
So if there are 3 of them I would expect 300 blocks daily, so 900 blocks in the 3 days. If one of them is labouring he will get paid less money and you could maybe expect 220 blocks daily and £520 daily wages. -
Locksmith came out but could not gain access. The customer was locked out with her baby. I smashed a small triple glazed window at the back of the house. It took a fair few blows.
He said on day rate. Really needs to be price. I would think 100 blocks in a day would be OK. Would they be about £2 a block to lay? That looks like a fairly big house. -
Seeking FD30 Doors in traditional designs
Mr Punter replied to Paene Finitur's topic in Doors & Door Frames
Fire resistant glass. Tempered and often laminated with a clear intumescent layer. Expensive. -
If you get no joy you can report this to the warranty provider.
The warranty firms are not keen. I understand corrosion protection is an issue as ground conditions have a big impact on this.
If you cannot use a soakaway you may still be required to have attenuation tanks so that water does not splurge into the sewer as soon as there is a downpour. Get some more quotes for your piling. Underpinning may be no good as you need to go deeper. If you keep the existing foundations and strengthen with screw piles or whatever make sure you get a proper guarantee against failure. Once you have had underpinning, future buyers will be very cautious.
If this is for demolish and rebuild, it looks like you will need to install piles to 10-12m. From the report the existing foundation is not suitable for additional loading. Unless there is obvious subsidence I would either leave the foundations and building loadings as they are or demolish and start again with augered concrete piles and ground beams.
This one is not FD30. -
How to fix a breathable membrane to a block wall
Mr Punter replied to GaryM's topic in Brick & Block
Hi @mattdeluca and welcome. You can just fix battens to the wall. No need for membrane.. If you are desperate to use some, wall, membrane, battens and cladding. -
Measure from the right to the ground. So if your structure is 250mm, will this be 750 above ground level? It would be fine if there are no neighbouring gardens that could be overlooked. I would not want people looking down into my garden from an elevated position.
No as I imagine the glass will break and the thin glazing beads will burn away. It is possible to get fire resisting glass but it is expensive and you would need larger section special glazing beads. -
Having glazing in FD30 is difficult as it needs to hold together. Wired glass does not look pretty. The glazing bars will not last 30 minutes. -
I am with @AliG on this. Lots of natural ventilation this summer and the MVHR properly commissioned and SWMBO is happy and you will be fine.
- 131 replies
- triple glazing
- condensation
(and 3 more)
Underfloor Heating with Electric boiler & Stove
Mr Punter replied to Curtis's topic in Underfloor Heating
The stove will pollute massively. Do you have a free source of timber? https://www.bbc.co.uk/news/business-59546278 -
Do the offending windows have heavy curtains? I don't have MVHR and RH here is about 50%. No condensation on the windows.
- 131 replies
- triple glazing
- condensation
(and 3 more)
Lowering a (roof) ceiling
Mr Punter replied to DeanAlan's topic in Lofts, Dormers & Loft Conversions
Why not just add the insulation over / between the ceiling joists and keep the extra headroom? -
End of stairwell ceiling
Mr Punter replied to Pocster's topic in General Self Build & DIY Discussion
Shotfire timber with Hilti gun. Cheap to hire. -
Roof ceiling joist strengthening.
Mr Punter replied to alexbr's topic in Lofts, Dormers & Loft Conversions
Agree with @redtop those ceiling joists look really flimsy. It should be cheap to get an engineer to spec this and they will make sure the rest of the roof and the external walls are all sound as well. -
The resilient bars are a good call. I also wish I used them. No point for the OP unless they are attic trusses.
If it makes fitting the boards tricky you could pack the joists with hardboard or gouge out a bit of plasterboard.
