Mr Punter
I guess that with the woodcrete you can direct render or stick tiles or slips? Polystyrene you may need to fix a carrier board or something back to the concrete core.
If that is earth you need to remove it first. There should be foundation underneath. You will need DPM under the concrete, linked to the dpm on the existing floors.
Insulating a Cathedral Roof - Mould and Condensation
Mr Punter replied to LeRouret's topic in Heat Insulation
If you want to add a vapour control layer and insulation from above it looks like you would need to strip the triangular battens to get access. You could add insulated plasterboard from underneath and still not be lower than the beams. -
There is a fair amount of saving on the fire curtain, so you should have a bit of budget. Most of the metric doors are 2040 high and widths normally start at 626 and go up in 100mm increments. It should be simple to shave a bit from either side. Contact the supplier to confirm. Some have 20mm lipping so your 11mm sounds doable.
The squashed in mineral wool as suggested by @tonyshouse would hold it in place.
Perhaps blown cavity wall insulation - either beads or fibre - would be an idea.
I have also used Polarwall for a basement and found them very helpful. Construction is pretty simple.
Well done. Any chance of a mixed case of vintage Krug and Cristal?
Ask now for his agreement that you can get someone else to use his plans for Building Regs and Construction drawings. It sounds like you are nearly there with the planning drawings and if he is on a fixed price he may as well get it submitted.
Without a protected staircase that would be dangerous in the event of a fire. Upgrading the fire alarms with an interlinked mains detector in every room would be a way to mitigate, so that you would have a good early warning. It would probably be better than an upper story escape window.
No you would need planning consent Here is the guidance: https://www.gov.uk/government/publications/permitted-development-rights-for-householders-technical-guidance/permitted-development-rights-for-householders-technical-guidance#class-b--additions-etc-to-the-roof
For clarity please confirm that was the external temperature!
Maybe put down some porcelain tile or hardwood. It is too late to grieve about the mortar colour. I am considering using silver sand, white cement and lime on a project but I may just go with whatever is cheapest. I would need the brickies to use the special mix for the external brickwork only. Odds on they just use it everywhere.
My point was that they are uninsulated and still score better than @Marvin's place which is highly insulated.
I have some flats with electrical resistance heating and hot water, solid uninsulated walls and single glazing and they achieved E.
I would not fancy tiling once the units are in. This is the second one of these kitchen onto damp screed topics this month. I think it is best to delay the kitchen install. Get the floor tiled and grouted first.
garden Topsoil or no topsoil, that is the question
Mr Punter replied to Ebrin_devon's topic in Introduce Yourself
I have worked on sites where if you are planting trees in the winter the hole you have just dug will fill with water before the tree is staked. Make sure you have paving where you are going to walk or you will end up with an unsightly track over your new lawn. As above, 150mm topsoil is what you paid for.- 13 replies
- clay
- landscaping
(and 3 more)
Airtightness, boiler controls, PV (should be good on a bungalow), accredited construction details all make a bit of difference. Get Jet floor to spec the floor to the u value you would like and get the SAP guy to use their value. If they won't / can, just use normal beam and block with a bit more PIR. Will be cheaper. Can you do ground bearing floor, or are conditions unsuitable? Floor insulation is cheapest and easiest compared to wall and sloped roof.
Including crack control is a really good plan. Even better if you can place it centrally under the door and start the tiles either side, with mastic instead of grout but I think once it is fully dry you could get away with filling the crack and tile straight over.
