Mr Punter
It is very messy and does not come off your hands for a couple of days.
It depends so much on ground conditions, access, loadings, contamination etc. Just get several prices and see what works out most economical.
I have used them a few times. You really just need to shop around and compare prices. They did a slab supported on driven steel piles, one on hollow stem drilled piles and one with open augered. Roger Boulivant are also a good firm,
Zinc is expensive and difficult to DIY. ASHP seems to be the winner over GSHP. You could get it priced in brick / block (by others) with a tiled roof (by you). There will still be plenty of work to keep you busy.
Is the whole bed "fed" by a trap door above?
No eaves/gutter with standing seam zinc?
Mr Punter replied to SuperPav's topic in Roofing, Tiling & Slating
I think it could look quite crisp to have the wall and roof meeting seamlessly. I can't see a reason it would be an issue. The are some uni halls near me that have this and I think they are finished in clay tiles. -
There is a large difference between the price of Thermowood and Pine and I guess this is reflected in the cost of baking it. Don't underestimate the transport, handling and storage costs.
Can you just double up the sole plate on the timber frame and increase the building height by 38mm?
I think you need to leave it another couple of weeks. Get the ceiling and the door reveals tacked and plastered and the whole room at least mist coated.
Perhaps you can just ignore the joists and fix through to the lower OSB. 18mm OSB has a pretty decent pull-out rating. Just make sure you have the correct screw lengths for the differing insulation thicknesses as the screws will only be threaded at the end 60mm, The tube washer type fixings look good as the screw will not pop through the waterproofing if the insulation is compressed.
Low flow what do i need to increase
Mr Punter replied to Ahmiccc's topic in Boilers & Hot Water Tanks
It is true that you won't get enough flow for 2 showers with the combi you have but the accumulator will help with pressure and flow rates and hot / cold imbalance. If you really want to run 2 showers at once you additionally need either a hot water cylinder or a high flow storage combi, -
What would you use in this circumstance? Some sort of cement board as the top layer?
Where would the moisture causing the condensation come from? I have seen some roof insulation where they bond a thin ply layer to take membranes etc and they have BBA.
Sounds better than firrings. What fixings are you using for the top sheet of OSB?
Not read all but a cold water accumulator with pump is often recommended for pressure/ flow issues. -
I have used RAK sanitary ware in the past. Very good value and the quality seems fine.
You may find it difficult to mount the post you are looking at without it being a trip hazard. How about an overhead door closer with hold open?
No you need to delay the kitchen fitters.
Problems with Baumit.com thin coat render system - part 3.
Mr Punter replied to ProDave's topic in Plastering & Rendering
Before Grenfell, Kingspan and Celotex were BBA certified for use on tall buildings. -
Notification of Statutory Undertakers?
Mr Punter replied to Tracey Gardner's topic in Party Wall & Property Legal Issues
The landowner is responsible. It may be that they can persuade the owner of the gas main to stump up some compensation, especially if the main is not shown on any asset plans and / or there is no wayleave in place. -
The domestic alarms for new build are normally mains heat and / or smoke detectors with integral sounders and battery backup, interlinked so that they will all activate. They are installed by the sparky. Battery only alarms are not acceptable for new build. Commercial alarms have a central control panel where the building can be split into zones. The sensors and sounders are often separate. They may have break glass type call points. They normally need an annual service and installation from a fire alarm specialist.
Semi-final plans --- feedback/critique welcome!
Mr Punter replied to RK6's topic in New House & Self Build Design
You could well be right and it can be modelled. In some places you can just open a window to prevent overheating but in others it will still be oppressively hot. The 7 figure budget is rather vague. I would not expect this to cost less than a £1M with a main contractor but you may not want to go too crazy. There is a Corten house just down from me that was on Grand Designs. I am not a great fan of the finish and it is not that easy to work with. Make sure you get detailed costings, especially on the non-standard bits like the retaining wall and the cantilevered roof canopy, before you apply for planning consent. The interior stuff you can change if you need to but the exterior form and finishes is part of the consent. -
Garage/Car Port Conversion to Annex
Mr Punter replied to livingthedream's topic in Garage & Cellar Conversions
An existing and proposed plan may be useful. For foundation depth you can normally just do as per the current house. I really dislike macerators and if there is any way you can achieve gravity drainage then do that. There is no issue with water and drainage in the same trench. Water will normally be at the bottom, at least 700mm below ground. -
From the renders the sun will be over half way into the living room. Someone on here @NSS? has Sage glass, which can be tinted automatically to reduce unwanted solar gain. Maybe worth considering now as you have the funds.
