New acronym in this space - any ideas:
It is horses for courses - @Mr Punter is correct (and very funny) just a load of chipboard boxes lashed to the wall, and in lashing they probably bugger up your air tightness. Anyway the clear fact is, as he also hints, that its about the doors (painted MDF, book matched obscure veneers or solid gold), the worktop (Melamine, Quartz, Wood, Corrian or whatever), the appliances (double dishwashers, double ovens, Range cookers, AGA, Fridge, Freezer, coffee maker(s) and built in juicer - don't forget to the get brand right, if you cannot afford Gaggeanu - and if you have to ask the price you can't afford it, we won't think the worse of you) and above all the 'usability' of it all so you can entertain your friends while simultaneously producing a gourmet meal that would, had you bothered to enter, have put you at the top of the Master Chef league. All you need to remember is that when you are buying a kitchen you are buying a workplace that has to double as a badge of wealth while exuding your interpretation of effortless style and you had better hope your friends agree otherwise social death, or worse, them sniggering to each other as the leave - 'did you see that kitchen I bet it came straight from ....'! Curiously the super rich don't bother with kitchens because they never go there - only the hired hands do that, and for them IKEA is good enough!
Hi and welcome to THE forum. Yes gas is a good option even if a bit counter intuitive, there is an old item HERE that sets out the issues and takes a reasonably big picture view of the costs and emissions. The whole field is somewhat shifting as government policy and global understanding of ecological systems evolves. The article suggests that provided you can keep your COP (Coefficient of Performance) above 3.05 then you might beat natural GAS however to achieve this may well be hard work and if you take a look at the @JSHarris blogs you can perhaps see that to keep the COP high requires careful control and some luck with environmental factors. There is, of course, nothing to stop you having both - many here do, this would in theory allow you to run the ASHP when you can get above 3.05 COP and the GAS at other times but once you factor in the climate costs of making both items of plant, the ASHP and the Boiler, along with the dual infrastructure and mixed infrastructure you may well arrive at other conclusions and go for just the one. However to run a gas heated UFH (Under Floor Heating) system for instance requires quite a bit more infrastructure if you want the boiler to work at its most efficient output and there is also the interesting, and perhaps most challenging, complication of DHW (Domestic Hot Water) to add to the mix which tends to swing it more in favour of GAS but this is dependant on the size and type of boiler. Finally and perhaps most crucially there is the option of free electricity, after you write off the cost of installation, to run the ASHP if you have PV (Photo Voltaic) generation system. This then brings the cost of the electricity down and makes the ASHP an improved option with the additional possibility of storing excess electricity in something like the SUNAMP system (Other options are available) that can be used to provide DHW from the excess electricity. Essentially - not straightforward and dependant upon your feelings about how 'eco' you want to be and whether that is on a global warming scale, big picture, or local scale - just you keeping your costs down and doing as much as possible. Hope that helps many other will pile in.
Vaillant ecotec 938 heating resume delay faultby 2 minutes
MikeSharp01 replied to shab's topic in Boilers & Hot Water Tanks
@Nickfromwales will be along shortly and he knows all about that boiler so with luck you will get an answer. PS Welcome to the forum. . -
Conceptual and detail design software
MikeSharp01 replied to LouiseSJPP's topic in New House & Self Build Design
Autocad won't do all you are asking anyway, not that you need it realy, the answer is probably Revitt - even more expensive and harder to learn. -
I thought you did those up before fitting and drop the whole lot through the hole. Least ways that is what I simply recall doing last time I fitted one. They usually have an 'O' ring so maybe hand tight is enough but I would not think so.
What is wrong with the clay? Our passive slab, AFT, is on clay and nobody has raised any objection.
You wonder where they hide the inductor - must be the biggest part. What does the ripple look like on the output as BUCK inverters are not good at dead flat without extra components. (If you have not dismantled it yet I guess you might get a look at the ripple using a photodiode reciever.)
Cool interior - is it your place?
Take care because building regs will kick in and the accessibility aspects will dictate the minimum size. If you look at the regs you can seen the various layouts and sizes you can get away with. It's part M of the regs
Indeed it is, I'm amazed that they managed to fit one in the base of one of these small bulbs, but they have, as when tested the current reduces as the voltage increases, exactly as expected for such a device. Wonder what the design is.
Progress at last!
MikeSharp01 replied to Moira Niedzwiecka's topic in General Self Build & DIY Discussion
Looks great and, in the end good news on the Windows. -
Makes perfect sense when you put it that way. Making a small DC-DC converter would be no mean feat. Alternatively just get a cluster of small LEDS and drop the voltage with them in series - we did this with PWM brightness on roadside type approved LED vms signs in the 1990s worked a treat. Not one LED failed in 10 years of operation.
Make your own by popping down to Maplins, getting an ultrabright white LED, work out a suitable resistor, unsolder the base of that bulb to remove the glass and fit the LED and resistor onto / into the holder - bingo.
Systemair VSR 500
MikeSharp01 replied to Stones's topic in Mechanical Ventilation with Heat Recovery (MVHR)
How significantly? -
High speed broadband a legal requirement by 2020
MikeSharp01 replied to a topic in General Self Build & DIY Discussion
All the better to receive notifications from buildhub. (Sent from my gigabit connection - 512Kbps is gigabit/annum isn't it, inside the M25 - if they can't deliver it here - where I believe the retired MD of a BT company lives in the village, I am not sure what message it sends to the rest of the country. We have been offered it - £8k per household. I will stick with my wet string connection.) -
80w outdoor warm white floodlight - any recomendation?
MikeSharp01 replied to Fallingditch's topic in Lighting
Ah - now it all makes so much more sense. -
Welcome to THE forum. We went a good way down the road with GBS on our build. In the end they were a bit to 'chunky' but the price wss good and the service they gave through design and the competitive quote process was excellent.
Sorry - have to say it - something of an anticlimax - which is not an excuse for anything further from the group norm - whatever that is.
Got this far and still have not clicked the link - self control or what - I will await pulling the duvet over my head later and find out what it is all about - great day.
Exterior design app.
MikeSharp01 replied to Russell griffiths's topic in New House & Self Build Design
Have an answer for you @Russell griffiths but thought I would keep it to myself until my curious is satiated over the bad language post. No - only joking - Look for 3D game environment building apps these are free and most allow you to fit / project materials on surfaces. Have a look here: http://mashable.com/2008/07/10/tools-for-3d-creation/#o68NrEunJuqu -
Planners are just human but in the end the only way to find out is give them a call, or just stick it on an NMA form and wait for them to reject it or not.
+1 it is after all just a house not an oil refinery!
Had to read all this to find that the whole reason for reading it does not yet exist! Surreal or what
You might simplfy life a bit by removing the soil pipe through the roof and using an Air Admittance Valve inside the building if acceptable to Building Control.
