THIS POST GOT WELL OUT OF SYNC BUT I WILL LEAVE IT NONE THE LESS. Sorry - needed to sleep - but yes it does have to heat up a large amount of water but there is no waste and you may have hit the nail on the head of how your system is configured as the boiler only heats the top of the tank so it should be quick to provide heat at the top of the tank for high grade heat for showers / baths etc while the rest of the tank can run at a lower temperature to drive the UFH. @PeterW talked about stratification - this is where the tank can hold water at different temperatures up the tank in 1,2,3 or more (depending on tank size) layers. You might expect convection to sort this for you but in fact you get stratification. It may be that the plan included this phenomena so you heat the top for showers with the boiler and allow the solar system to do the rest. As, in all your copious paperwork, I have not spotted any notes on the design goals we may never know. Lets wait and get a set of temperatures from a single source (thermometer) that can be compared and then we will know, as today is a sunny day we may even get an indication of how well the solar is working. You probably need to label, actually or in your head, the various target points and pop the results in a spreadsheet, then take the readings at each target at intervals which would allow you to plot what is happening across the system.
Yes but if the immersion is powered from one of the cheap rate power lines it will be much more cost effective than the boiler in cheap rate times and it may, may, also help the water being heated in the top of the tank by the boiler heat the whole tank because it will set up a convection current in the tank. The immersion heater is all bar the shouting 100% efficient in that all the heat goes into the water, none is wasted - until it gets to the outside of the tank and leaches away into the air.
There is at least one immersion heater there, what is that doing I wonder, is that the prod the system needs to syphon I wonder.
Milk in Earl Grey, my sainted Aunt, - somebody needs to spend time in the appropriate gulag for 're-eductation'.
That makes sense - in schematic the pellet boiler is the prime mover, with the heat pump doing a low grade heat input at the bottom of the TS and coping with the UFH if it can.
Yes but able to afford to leave a 24Kw boiler on all day!
The difference is bonkers and means the losses are massive. Lets wait and see what the temperatures are at the various points when you can measure them.
Hmmmm... That sounds Odd - loosing 20Deg across the circuit feels very high and is incredibly wasteful. Might need to insulate the pipe work from boiler to Heat exchanger and heat exchanger to TS as well as the heat exchanger. (Unless somewhere there is some system in control of the TS based on the Boiler water temperature which feels like a remote possibility.)
Great to see the meters and the Teleswitch (Which is the thing that tells your 'system' that cheap rate electricity is available.) The difference between the boiler output temperature and the TS temperature - 20 deg loss seems high and is interesting, It will be good to see the temperatures of things when you get the thermometer tomorrow, as this this will clear up loads of details. PS was the TS temperature rising, even very slowly above the 45 / 50 or was it dead stable?
This is design dependent so your SE will tell you if the internal floors are in any way structural as they may well be.
Look its horses for courses. I have the Lidl corded one and it is great. I also have the dewalt cordless which was a gift and is also great given that I have other Dewalt tools so a number of batteries. The thing is not about cost is about value in the end the choice is down to the way you see the value proposition.
@newhomeHave you got a cooking thermometer anywhere? If so touch the end on the pump and lets see how hot it actually is.
Do we know the fluid temperature circulating round the boiler / plate heat exchanger circuit is that at 70ish?
Naturally.
Is 'girls' acceptable in post femamist era discourse when referring to women? Perhaps or perhaps not. Interesting article HERE.
This is a safety thing I think although@ProDave will confirm. You seem to be well protected by the circuit breakers you have as they have built in protection but given that your boiler is now on a different sort of breaker you may want to be sure that if a fault occurs your earth can cope. Dave will put me right if I have that wrong.
Don't worry I wasn't - but the Uni now states its address as Brighton, which I also found weird when I checked.
I Have the Dewalt cordless version which is great, lasts forever on one charge. https://www.howetools.co.uk/dewalt-dcs355n-18v-multi-function-tool?utm_source=google_shopping&gclid=EAIaIQobChMI-fHY4_a32QIVo7ztCh2Q9w5kEAQYASABEgJEUfD_BwE
Not easy but you could draw a box over it, filled - from the ADOBE COMMENT menu, then save it as a picture then upload the picture. Alternatively I think you can use the box cover and then save it as a non editable PDF but i am not sure you could not then remove the box if you wanted to enough. Alternatively get a post it note to cover it before you scan / photo it.
Don't listen to him on this one - his son is at the University of Sussex (The University of East Sussex would need to be in East Sussex but it isn't cos it does not exist, yet, although curiously the University of Sussex is no longer in Sussex but in Brighton - since it became a city!) On other matters - welding, tiling, bathroom design / layout /modelling and many other interesting things you should listen to him. Welcome to THE forum.
@newhomeIs the temp gauge above the silver pump (on the heat exchanger to thermal store circuit) the one that now only goes to 50 when it used to go to 60? [Or is the temp dial on another cicuit I cannot make out from the photo?] Think I have it I can see the other temp gauge now I am on my PC. What temperature does the first temp gauge, mentioned above, get to?
As I understand it the second meter is the economy 2000 meter and is the one that supplies the boiler and is the one that takes the three phase electricity into the boiler. Somewhere on that meter, or very close to it in a separate box will be a switch that is controlled by the electric company and is used to tell your system that the electricity is cheap. It would be usual to use that switch to control the boiler so it only runs when you have cheap electricity. Can you photo the meter, perhaps you have I think I may have missed a bit of this series today, so we can see because we need to work out if that switch is still being used or if the timer, fitted as you described, is running it. If they are both in the circuit then the boiler will only run when the electric company switch is on and the timer is on. If just the timer is in control hen as as @ProDave says you may or may not be using cheap electricity as it (the timer) knows nothing about the cheap rate times.
Brilliant post Nick - love the TLA (Three letter abbreviation) explanations. It really is quite a system is it not.
Yes but if you are unsure what you are looking at how would you know definitely not to touch.
Relay is an electric switch. It, usually takes a very small, tiny, amount of electricily to turn a device that uses a large amount of electricity on and or off.
