May be a consideration where sunlight is shaded, eg door and window reveals, and you end up getting an ‘uneven’ look.
Help with kitchen renovation/ 1st house.
Nickfromwales replied to zoothorn's topic in Bathrooms, Ensuites & Wetrooms
It’s ok. We just hooked the back up generator in whilst you were uploading pics these days -
AFTER THE FECKING BATHROOMS DONE!
Just build one. The neighbours aren’t going to get planners out anytime soon ?
Just can’t fathom out why they’d be popping. ? Can you get a deffo hollow one up from somewhere at least slightly inconspicuous? Be interesting to see if the adhesive has stuck to the tiles and lifted from the floor / vice versa.
New build - heat and energy considerations
Nickfromwales replied to Tyke2's topic in New House & Self Build Design
I just get bladdered and the place can burn down around me ??? -
+1. @lizzie, get typing and snapping as it’s probably summat daft. -
Do all the tiles sound the same ? Eg ones a thud and another a clack ?
And the focus when the sills are done ?
Excellent. You can get classic car insurance then ?
UFH in slab or screed, eps or pir insulation?
Nickfromwales replied to Tin Soldier's topic in Underfloor Heating
Cant happen here you'll be glad to know. We have a structure which avoids SPoF and no individual can make any such decision on their own. The FMG ( made up of 17 staff / members ) get together and discuss it like grown ups, we discuss it, and it gets voted against, or for, if there are mixed opinions. You'd have to seriously piss us off before getting shown the door. Only one has earned such privilege to date IIRC. Enjoy! -
Its a strange scheme tbh. If export is to the DNO, and the FiT is deemed from installation, as is, then the only thing that should happen if you move things around or add a couple more NW panels is the FiT stays the same and you export a little more to the DNO......So bloody what ?!? Would adding panels afterwards see you getting more out of the government or do they use your total deemed 'revenue' as the benchmark for your payments? Another ill-thought-through sack-o-crap afaic. With a recognised export limiting device there should be no repercussions if you decide to 'beef up' or optimise your system later down the line.
Look at the Apollo Gem and My Energi’s Eddi unit. Very versatile and the ME Zappi will sort the EV charging out.
Time for a new plumber. Jeez ! -
Excellent idea, the chicken will cook much quicker in one of those than if it were just sat on the hob ?
I can recall the MI’s with one stating NOT to have cutlery or metal utensils immediately below for whatever reason.
Yes, but felt over felt isn't a good example and the OP expressed anxiety over their brand new, sarked, membraned roof so I'm going with apples not rotten tomatoes
- 59 replies
- flat roof fall
- firring
(and 2 more)
Building regs Part X compliance
Nickfromwales replied to Tennentslager's topic in General Self Build & DIY Discussion
JFDI. If she comes around to moan, bend the tree over, one up the jacksy, let go of the tree and bingo. Theres your xmas 'seasonal festive' fairy lol. -
20mm over 3000mm will be more than enough to stave off standing water. Get a length of 28mm copper pipe, stick a 20mm chock under one end and pop a marble in. This isn't something you should be worrying about tbh, and most 'flat' roofs I've seen have been in for decades with pooling water, leaf litter, grot and more and don't leak one drop. As long as the boarding has been done well, and the firring pieces in at 400mm centres max, then I'd say this'll work just fine. As asked, have you done a run-off test with a hose / had a bit of rain on it yet? Proof is in the pudding
- 59 replies
- flat roof fall
- firring
(and 2 more)
Weather comp, as your typical generic OEM unit, is quite an arse from my direct experience. Vaillants offering was more like a bloody switch than a real time variable / compensation device Then I had the added grief of wanting to apply it to a house with a system boiler and GF UFH / FF RADS + UVC which meant when WC kicked in and attenuated the boiler flow the rads cooled down but the UFH became U/S. Ok I thought until they said the s-bus system wasn't clever enough to ramp the temp up when providing DHW to the cylinder via an S-plan. OK again I thought, ill do W plan DHW priority. Nope. Not supported as WC still governed the max flow temp. I think WC is massively over rated, over complicated, poorly executed and very mis-understood. Good controls are the better investment eg room stats with very short hysteresis, digital not rotary / mechanical, and lashings of user awareness of how and why things do what they do. Most folk still think a TRV on a radiator controls the radiator temp -
They’ll be too busy seeing if you have put an AAV on your ground floor WC.
I use a strategic partner to undertake my PV referrals. They supply and fit direct to the client. I did look at undertaking the install on a non MCS basis, but it still has to be registered and notified to the DNO with the equipment listed so for larger or more bespoke installs I just found it wasn’t worth ‘getting in the middle’ tbh. PM if you want details of the installers, but for DIY you’ll get all the answers right here. Ill post a link to the SE inverter ASAP. What’s the warranty like with the SB inverter please?
Link to follow.
Solar Edge Fill the roof up and export only 3.8kW ? Remember you should use this to mitigate against costly uplift caused by mandatory DNO infrastructure improvements. Fit a solar edge and tell them to FO. Aside from that the SE inverter is also attractive because it uses dry capacitors and comes with a 12 year warranty. Happy days.
UFH thermostat wiring, floor probes
Nickfromwales replied to oranjeboom's topic in Underfloor Heating
Something said during the “McEwans event” must have hit home.
