Nickfromwales
    346
  1. So who answers this question definitively? Who do I ask for a smart meter to be fitted that supports net metering, and to then evidence it?
  2. As long as the cyl stat and immersion are facing front, you’d be ok to bury the UVC in that ‘deep’ afaic, plus it looks like you have planned spacings to allow its retrospective extraction ( should ever become necessary ). Just make sure the cylinder does NOT use a sacrificial anode. For the UFH, how are you going to manage the differing temp requirements at each of the manifolds? A pumped brach Will only allow manipulation for the flow temp at source, and is not a good idea IMO, especially if one is on an upper floor?
  3. If that's 5m horizontally then you''l likely only need to pump the rads, but tbh I'd prob leave the pump where it is and run with the design you've been given. If you're really concerned about running that extra pump then delete it and just cap end the run to the rads circuit and manage without it until / if you decide to install the rads.
  4. The pump is there to put flow onto each of the heating circuits. You cannot move it to after the T as you'll then be sucking water backwards out of the UFH circuit. What you can do is T the 2 pipes coming out of the LLH and install swing-check non return valves on them. Then the one to the UFH manifold pump can be left 'pump free' and the pump can simply be installed on the leg feeding the rads. If the rads aren't getting fitted now, don't fit the pump. How close to the LLH is the UFH manifold + pump & TMV?
  5. He's good to go after half a shandy.
  6. In a nutshell. Very relevant actually, unless you'll assume they're blind / inept at the good ol' HMR of C They would use their "additive mathematics" to tell you to stop taking the Micheal. A Ring chime is £30. Try fitting that instead?
  7. Is this new works, and subject to BRegs?
  8. Lol. Twat is a bit harsh, you penis. The other favourite is closing the isolation valves to do the work, and forgetting to reopen them. My least favourite was my neighbour asking if I could see why their combi had suddenly stopped working. Flame failure. Went out to check the flue, and the painter doing the outside had bagged the bloody flue and gone home for the day. Now HE was a real twat.
  9. Ok. I'm slowly coming back around to room by room ventilation ( via MVHR or other ). Detailing internal junctions ( if IWI ), eg where internal corners meet, where ceilings meet walls etc etc will be of absolute and critical importance here, or you'll get very localised issues where ( for eg ) dot and dab has bridged the covered cold wall to the interior of the room. This is something I have suffered myself, where I let dab squeeze between the insulation of the two abutting insulated plasterboards in my bathroom. You can literally draw with a pencil where I have done this as the damper part of the wall reacts after every shower is taken. A sloppy installer will just bring the problems further forwards, so you need to vet the installer and be firm with what you expect from them, what the issue is that you're resolving, and how you wish to understand how it is to be carried out.
  10. Same weapon of choice here. I'm blown away by how quiet they are for the money. Easily as quiet as the Stiebel Eltron units ( which command a LOT more of your hard earned ). Can't you provide them with a written waiver, stating that you will meet any subsequent removal costs etc if it all goes south? Once it's in, show the installers how quiet it is and they'll get a very much needed education.
  11. Just create a stud partition wall 1200mm behind the external wall, parallel with it, with a second secure door to the house. The interior of that new space would need lining with a suitable material ( maybe uPVC cladding etc ) and air would just take the path of least resistance. Ergo the input grille would ideally be 20-30% bigger than the exhaust so you dont pull air from the dwelling. A drawing can follow, but family business awaits atm.
  12. I've recommended doing this in sections, same way an EDPM roofer would detail a roof membrane. You don't have to go to Specsavers Bruce, they'll come to you
  13. Ah, ok. Then you absolutely do not want to be pressurising the house with air taken from the street!! You will still have access, as the door doesn't 'go', it just becomes a transfer grille. Or, if you can, make 2x transfer grilles; 1 up high for inlet air, and a lower one for exhaust. The partition section becomes a 'wind-tunnel'.
  14. Ah, ok. Well, they'll actually drill a hole in the wall, then insert a rawl plug, then insert a screw. So not actually a 'hole', more a penetration.
  15. Why not partition the end of that room off and create a 'wind tunnel'? Eg with the full eternal door being a large louvre / transfer grille? Have the heat pump sucking air in through the transfer grille ( external door ) and then exhaust it back to outdoors through a second grille in the outside wall ( which connects the front of the HP to atmosphere via a sealed duct ). You then install a second door into the new partition wall to get access into the 'garage'. Your climate is 'different' to ours, but in the UK we'd certainly NOT want to be positively pressurising the dwelling with cold / damp air from atmosphere.
  16. Assuming your going to be affixing the plasterboards with dot and dab? Or do you plan to cement coat and plaster with a full wet system?
  17. Ok. Yup. Then the OP should say speakers, amplifiers, cables + install etc? Or are these £1k speakers?
  18. Only if you could prove that they were the ONLY sounders, eg that the equipment relied on a 3rd party item to complete the functioning system. If the doorbell makes a noise out of the box, it's a very thin bit of ice you'd be skating on imho. Is it really worth the aggravation of an inspection for a couple of tenners?
  19. Hi. Yes, I just installed a manifold ( like an UFH manifold ) but without the thermostatic valve. Ideally you'd have a pump on this manifold as the rads and the GF UFH will need to be hydraulically separated. Will need a small buffer or a low loss header to do this. The pipe runs from the rads manifold can be continuous runs, but will likely need to have a joint before they rise out of the floor, as the pipe will likely not have a very tight bending radius. You cannot use 10mm pipe as it's a heat pump, so 15mm minimum pipe size will be required for the flow rates to be optimal.
  20. Not sure is the honest answer. Learning and adapting at this very moment!! Ask tech support at Drytek and see what they recommend, but AFAIC you just apply the mesh and render and it sticks like 💩 to a blanket. @nod who else does these render systems ( with BBA to go onto ICF? ) @Russell griffiths what did you use, Bruce?
  21. I think he should. May mean his plans for the weekend go out the window, but he needs to consider our needs and really buckle down.
  22. All of my clientele are building to passive or just below, some above ( NZEB / ZEB etc ), but you’re right to point this out for the masses reading info here. The bigger the buffer ( or buffers ) the closer to input temp you can store at. As I posted elsewhere, if there’s going to be a buffer plumbed in anyways, why not just make it a monster and load shift. Just needs to get you to midday for a cheeky bit of top-up off whatever solar is going begging.
  23. With / without trickles?
  24. Matters not one jot what you’re doing after, but this is the only way I will detail these junctions from hereon in. The render is just about the only thing that will stick, and STAY stuck. No good being great on the day, then gives up over the next couple of years when it’s waaaaaay too late to do anything to quick-fix this. Check with BCO and read up on manufacturers recommendation for these reveals, they should provide guidance. BCO will probably know the square root of fcuk all here, and could cause undue stress / work so take that info and choose what you do with it. FR should be a concern, as if an open flame gets to the EPS, it’s “goodbye house” at a rapid rate of knots. Not often discussed.
