Nickfromwales
    345
  1. What's the full title of the vp400 dave? When the shedshop is finally built, I'll be wanting to concentrate on the interior and had planned to leave the outside just membraned, prob for one full season. If yours is holding up in the Highlands then I'm all ears. Do you know roughly how much per roll / per m2 it costs please? Edit. Does yours have nail penetrations thorough it for fixing? How have you held it down and remained watertight etc.
  2. When you upsize to 40mm at the tee, it in effect creates an air break as soon as the 40mm is running horizontal so prob no need for air admittance. When the two basins are running at max normal flow rate the water still won't fill either pipe, the 32 or the 40, so as water is going down, air travels up and over it if needed. The only time you'll need AAV on the basins is if there is a significant vertical drop before an air break. If your going down to floor level, then upsizing to 40, you'll have ZERO issues. It wouldn't hurt to use anti-vac basin traps, but you'll deffo not need an additional, stand alone AAV for either basins with my proposed method. If you do decide to go the longer route with the second basin, I'd still upsize to 40mm tbh as they're quite prone to gunking up over time.
  3. Make sure you buy one that you can choose when the heater comes on. Most come on with the light which is daft. Chewing electric for no reason.
  4. Welcome aboard
  5. Hi and welcome.
  6. Use a 40mm tee to connect the two basin 32mm pipes together, and run a single 40mm back to the elephant foot.
  7. I'd be happy ( confident ) enough with these for a 'fit and forget' install, so this could go in the joist space therefore not increasing your boxing in size one jot.
  8. I wouldn't go less than 70-80mm, but as you've prob got off cuts of soil, use that with a long radius bend.
  9. Boiler in bedroom is fine. They're classed as 'room sealed' . Get it up the attic out of the way, or in an utility etc. . Boiler in bedroom = a no no for me.
  10. It's pretty much bombproof tbh, but it's the criteria set out by the water authority that dictates the way it's pulled in in most circumstances. 700-750mm below ground, 4" duct / sleeve of non aggressive material, then the stopcock, then a non-return ( double check ) valve and a drain off cock. Anything less and they refuse to connect you down here. Always remember that the WB will want YOU to excavate the foundation of the boundary wall, and will ONLY dig OUTSIDE the boundary. Your pipe needs to have a good bit of slack and be free to pull under the boundary wall at said depth.
  11. Yup, bugger all gets through once it's squashed into place.
  12. He was old gold. Pissed me off tbh as he said about stuffing it full of mineral wool / rock wool etc so I had to go buy a full roll for two poxy handfuls. Live and learn. Cheers J. ( I'll quote you next time ).
  13. I doubt if you've got more than minutes to live................. The issue is created when the 'goop' that the tape is saturated in enters the water, thus contaminating it. Ultimately this can only really happen when the pressure around the pipe exceeds the pressure inside the pipe, or where the tape was applied to a hole and could then directly 'wash' into the water. If your confident that those couldn't occur then relax for he moment, bit can I assume that you'll be changing the entire cold mains now anyway? Fwiw, I'm a fan of denso ( just checked the spelling ) and use it to cover any copper gas runs etc where applicable. Only problem is you have to buy a chuck-away craft knife and loads of disposable gloves as it's the anti-Christ of tapes when it comes out of the wrapper.
  14. Afaik, denzo has been banned for use on potable water supplies. Why fit it over a pipe when you can just change the pipe
  15. That's why I asked . It was a Welsh Water "Johnny Jobsworth" that came out and he ran me through the grinder at every stage. Thanks for the comprehensive reply, another reason why I'm on here. . Peter, stand down foam alert
  16. Are you aware of these fittings ? The pipe terminates vertically so I'm a fan.
  17. Welsh water guy told me it would fail if I used it . They came out to check a new mains I had installed on an insurance job, and said a few had done it and had to remove it. @JSHarris. any truth in it?
  18. Waxoil or chain lube. The latter goes on like liquid, but solidifies after a short period leaving a waxy layer where it needs to be ( and stay ). WD40 doesn't stay on long at all. What do you know.....WD40 are one step ahead of us
  19. For the issue of airtightness, just picture the pipe going down through the duct to the ground, and then as it exits the duct the pipe is surrounded with compacted fines ( dust ) which will be wet. That'll stop just about any movement of air between the house and the atmosphere Do NOT squirt expanding foam down the soil pipe to 'plug' the hole as it reacts with alkathene / mdpe and is a big no no.
  20. Both, of course. . You've never tried chewing denzo tape before then ? PS, Dave, you cannot use denzo on a leaking cold mains pipe . It'll contaminate the drinking water. Apart from that, top idea
  21. 3 x 4.0's for change of £90 is a good deal imo. I'll get some when my next couple die. At the mo I've got 2 x 5's, 6 x 4's ( nearly new ) and one 3ah that is 2012 stamped and just refuses to die. Was running 3 single chargers but on the last kitchen job one decided to start showing red / green flash on every battery ( so buggered charger ) and another was very noisy ( fan ) so I decided to give it an 'encouragement' slap, where a flash and a bang quickly followed. Two chargers dead in the space of 5 mins . Bought one of these dual chargers last week and it has a handy USB socket to charge the phone too. . Id recommend these in a heartbeat, for the money, and haven't used my 3rd ( now spare ) single charger since tbh. I wanted to buy the new radio, Bluetooth and USB, but the loons at makita REMOVED the DAB receiver and sent it back to 1980 with AM/FM . Ass Hoooooooooooooooles.
  22. Go get a beer.
  23. Good spec for the money. I think I'd be inclined to go for the Bosch 3 line as it's got good accuracy over 50+ M's and its just so bloody handy for so many other jobs on the rest of the build. Do the 'dumpy' sets give distance or just level? I've never used one tbh.
