You can't drive your batteries to chuffing Sainsbury's though !?! Roll on V2G!!! That will end this madness.
Connecting radiators to UFH Manifold?
Nickfromwales replied to valmiki's topic in Central Heating (Radiators)
Actually, just zoomed in. The TMV goes to 60oC so as this is the attic, and heat rises, the TMV could probably stay in for a trial run ( with it fully open ). -
Nope, you'd just remove the TMV from the manifold so it gets 'full-range' heat from the boiler flow. -
That'll be for another day then....
But you have to factor in the replacement cost when the cells die. Sorry to poop on the maths, but the above is an admirable achievement. Give the costs to @SteamyTea as he loves to work this kind of thing out. Then we can find the true cost per killerwhale hour ( KwWh or something )
It's German, and Solarwatt is owned by the brother and sister who own BMW. Smartness and predictive-ness a plenty my friend. If these two were in a pub brawl, the Tesla would call its mum to come get it
They all have moving algorithms which learn / watch behaviours, so yes, that is likely the explanation for this 'behaviour' vs a fault etc. As you say, leave it alone, it's prob smarter than we are.
Nope. Solarwatt offering in 2.4kWh modularly stackable cells goes to 19.2kWh per stack, then add another stack, and then add another stack, and keeps going until you run out of wall. Also has true unlimited throughput.
It doesn't look like the mesh is continuously evident, and possibly that the mesh didn't get wrapped around the corner ( in both directions ). The mesh is obvious at the bottom of the pic, but then is not visible / evident from the middle and top ( you can see the broken fibres where the mesh defo was ). What ar the manufacturers guidelines / installation practices regarding mesh at corners / where mesh stops and starts? eg overlap etc.
Brick cladding when the glazing is already installed ?
Nickfromwales replied to Post and beam's topic in Brick & Block
The parts about retainers needs to be in writing. Sent is enough, you don't need a reply. Same email needs to state also that the company employing the brickies is responsible for any making good / repairs / replacement ( including all associated losses ) and not the brickie(s) themselves. Include the name of the person and company to which it is addressed. -
Visible tundish yes, but then can go into correctly rated ( suitable ) waste pipe for conveyance to the domestic FW network. Most installers do this via waterless traps which do not rely on water to maintain the seal.
Nudura ICF and external cladding
Nickfromwales replied to Martin S's topic in New House & Self Build Design
I suppose that Nudura will soon start selling more of the XR35 kit as people start to become aware that it is an option which would mitigate downstream laminations ( and the time / cost of doing so ). -
An interesting snippet, including the impact of summer overheating and mitigatory cooling ( subsequent ) energy costs. Fails to specifically mention if PV is involved, but does take that into consideration ( given most shitty mass-produced development builds have some token PV to offset laborious and costly insulation programs ) God forbid they should do both How SAP works SAP works by assessing how much energy a dwelling will consume when delivering a defined level of comfort and service provision. The assessment is based on standardised assumptions for occupancy and behaviour. This enables a like-for-like comparison of dwelling performance. Related factors, such as fuel costs and emissions of carbon dioxide (CO2), can be determined from the assessment. SAP quantifies a dwelling’s performance in terms of: energy use per unit floor area a fuel-cost-based energy efficiency rating (the SAP Rating) emissions of CO2 (the Environmental Impact Rating) These indicators of performance are based on estimates of annual energy consumption for the provision of space heating, domestic hot water, lighting and ventilation. Other SAP outputs include: estimate of appliance energy use the potential for overheating in summer the resultant cooling load -
Inverter, PV and Battery Storage Location
Nickfromwales replied to Luke1's topic in Photovoltaics (PV)
I was going to do similar but with some greenhouse tubular heaters, to heat the entire space ( was thinking about inverters etc benefitting too ). Heat pads sound a better ( more targeted ) solution for the batteries, thanks. -
Not quite. The panels are only typically "self-cleaning" after 12 degree inclination, eg the rain will do the job. Solar irradiance improves quite significantly after the 12-15 degree mark, so I'd re-think my policies there -
Wall plates on curved inner leaf wall
Nickfromwales replied to health mechanic's topic in Roofing, Tiling & Slating
It's there, just covered in snots. -
You've just described my house and my thoughts tbh. As I've been off-the-chart busy lately I've had to belay my own install. I'm putting 21 panels ( Solarwatt 400w ) on top of the upper garden shed / pergola ( 50/50 at 11m wide x 4m deep / sloping roof to compliment ) and a further 18-21 panels on the gazebo roof ( upper garden gets hammered by the East sun and gazebo same for West ). I think you'll want the same that I plan, which is a hybrid inverter, as this allows the panels and batteries to be seamlessly integrated on the DC side. The DNO then only care about the max kW rating of the inverter as that's the only bit of kit 'visible' as AC connected equipment. My plan is to insulate the shed potion with lots of cheap insulation, but to also plan ahead for cooling it during the summer ( by purging vs fans but not ruling them out as they'd run off excess generation anyways ) and install all of the kit in there, running AC back to the house via a decent sized SWA cable. I plan to have a load of panels to give me a decent amount of winter generation, as solar irradiance levels drop to ( well ) below 25% for the 3 months or more of UK wintertime. -
We stayed in a Greene King ( 👎 💩 ) hotel In Halstead a while back where the shower curtain was used when the loo roll ran out. When my colleague complained the staff quickly apologised profusely, took him to directly to his room, and then SWAPPED the curtains over to / from the adjacent ( occupied ) room. Then said "That OK, sir?" We didn't go back there. -
In the worst case, possibly, but you'd have the money in your back pocket to pay the rug doctor to come and make it all poop-free. Statistically you're more likely to die crossing the road than going into the air in a flying, fuel filled thermos flask ( aka aeroplane ). I will walk to the shops later, regardless, but I will remember to look both ways before crossing, , because someone recommended how I should / could mitigate against the risks. -
More importantly, your thoughts on bacon? Then a new thread on red or brown sauce. 🤔 +1. People are far more considerate when it is coming out of their pockets. "All damages must be paid for". A retainer will sieve out any trades who have zero faith in their own capabilities / actions. Neanderthals will just walk away stating "I'll get back to you with a price". What they mean is "F**k that, I'm off to the next easy job / pushover". This will need effort, and persistence, but if you're as worried as you are then it's time and effort well spent eh? -
PIV, heating and cooling: pros and cons, can and can't
Nickfromwales replied to Garald's topic in Other Heating Systems
The DHW cylinder is full of potable water which cannot go anywhere else than the hot water taps / outlets, and that is propelled by cold mains pressure feeding into the cylinder. The heat from the ASHP heats this via a sealed and independent coil. These are two separate bodies of water at two completely different pressures / potentials. What you are likely thinking about doing is achieved by using a buffer tank with multiple tappings, in addition to a DHW cylinder. -
Anyone with experience of. Honeywell evohome system
Nickfromwales replied to magunn's topic in Central Heating (Radiators)
In view of never wanting to EVER over-complicate things, I only use the installed WC and modulation of the heating source manufacturer ( eg Panasonic for ASHP which comes ready to roll out of the box ). I only ever consult / provide M&E for folk building to very high spec ( lots of insulation / very airtight / PH or near as damnit etc ) so do not often need to 'go mad' with weather comp as these types of dwellings suffer very little effect from what's going on outside. KISS wins every single time. -
The plug'n'play posse are everywhere. TBH it's deliciously simple from their PoV. Just rock up, install like your painting by numbers, get in van, leave. Why would they choose your job over the next plug'n'play one...... There are decent fitters out there and you just need to keep looking, which would be a very wise investment as your ( spare ) time is free, so to speak. My 2 cents is, accept the considerable disruption and get a 40mm waste pipe installed there, go unvented, and then you'll have no niggling worries about pump service / failure / replacement and repairs after damage etc, plus you'll have mains pressurised ( clean / potable quality ) DHW and kick-ass showers. The waste pipe can be done sympathetically by a separate plumber, whom you can work independently with to minimise disruption, and then the plug'n'play massive can do the 'easy' bit with their pre-plumbed 1st year apprentice ethos. Just check these learner drivers won't then have any issues with knowing the class / type of waste pipe used and what class / type of pipe it finally discharges into etc etc ( and they then refuse to G3 it / connect to the new waste pipe . You can just pump of course, still go pre-plumbed, and live with having to periodically purge the pump to see if it's still 'alive'. You can set a reminder to do that, and the G3 service, annually.
