Calculating ducting size
Nickfromwales replied to jayc89's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I've got runs of 35m in my current PH job and I have simply doubled up with 92mm ducts. I expect zero issues / elevated sound levels etc. Trickle flow rates are equivalent to a decent sized hamster coughing. People seriously over-think this. -
Search "multi foil" here
Seriously?
NuHeat = 💩.
"wee"
Not even half a pasty?
I feel a crowd-fund event a-coming........
It's your type of 'sport' alright..... You could mount this outside on top of the glazing. Think of the views then, but watch out for a crack appearing
Twat! PMSL.
Conversely, I find PTFE better for this 'stop when it points to 12 o'clock' situation. I turn the fitting in dry, counting the number of turns until it stops ( in the wrong place ). I then turn it back out and count the number of revolutions again to be sure. I PTFE the thread, with around 21 turns, and then count the revolutions when going back in, knowing which one is the last full revolution before it goes past and bottoms out. Served me well to this day, and I'll carry on doing this for the next ones.
Timber Frame & Insulated Raft - One company?
Nickfromwales replied to SonnyB's topic in Timber Frame
Happy days. The airtightness scores we've had from a few on their builds have been extremely good ( 3 with sub 0.3 ACH, one was 0.25! ). Allows us to spec smaller heating systems too. Darren, who heads the airtightness team, is very meticulous. There are, indeed, very few who offer what they do. Consider the 300mm blown cellulose offering ( their upper tier passive spec ) as, combined with the 400mm in the roof, the sound deadening is incredibly good vs PIR filled roof / wall types ( if budget allows that is ). -
Understood. @pocster PLEASE do not mount this on your dining table. There, that better?
You are NOT mounting this on top of your dining table. NO.
Sorry @Andehh, but that is not great. That duct should not be exposed externally, so please insulate it at the very least. And internally too! The cold bridge you've introduced there is "significant". You should have bonded these down and then gone through with a pre-insulated duct. https://flexibleflueliners.com/product/high-temp-177-330mm-multi-purpose-flat-roof-flashing-black/?utm_source=Google Shopping&utm_campaign=Main Feed&utm_medium=cpc&utm_term=633&campaignid=18820525657&adgroupid=140474702782&keyword=&device=c&gclid=CjwKCAiAk--dBhABEiwAchIwkSyJgYhRAyV1DIPmCmTWlkPxB28yFB7SYkzKJGPVnFJwlRbkKIqNPRoCpOQQAvD_BwE I hope they last, but I would not accept that on any of my ventilation projects. ( Sorry again ).
Fibres every single time. A no-brainer afaic. Why not make this a pissy mix of 6mm aggregate concrete all-in? Lots of shouting at it and it'll practically lay itself.
Yup, and oddly it's coming out of you faster than you're drinking it.....
Noisy in the rain, that's the only downfall with those. Best off with that, and have wall lights up lighting the ceiling instead of ceiling lights?
This is nothing to do with the UFH, is on a different circuit, and won’t remove air from the UFH loops. The vents need to be on the manifold rails to resolve your issue. Go buy some. Don’t make me come down there 💪.
The gate valve is there to balance the flow between the heating and the hot water cylinder coil, eg so the cylinder doesn’t become an accidental bypass reducing flow to the heating if / when both are calling for heat at the same from the one shared boiler pump. Defo not on cold inlet.
I always bin the pressure gauge and install 2x AAV's.
Thanks. You should remove the two manual vents and install automatic ones. https://www.heatingcontrolsonline.co.uk/index.php?route=product/product&product_id=821&gclid=CjwKCAiAk--dBhABEiwAchIwkWErcuPQ_EMthpOZ5eBY3VATYjXY3CtsfJKiW2tDL7MfCHybjLhgixoCUXoQAvD_BwE Will be a like for like swap, 5 mins work with an adjustable spanner and an old towel. And possibly some wellies, depending on your plumbing skills. Just turn off the red and blue taps as per your pic ( they seem to be in the closed position in that pic? ) and then you’ll only lose a pint or so of water when you remove the old vents. I’d expect this would solve the problem tbh. Worth trying that first for sure.
Lol. You would have cropped the bits I wanted to see on the far right, One more pic please. Ta.
Can you upload a pic of the manifold etc? You should defo have at least one bottle vent / AAV on this arrangement?! Doesn't matter. Likely needs doing again. Get it done, put this behind you, go to pub. Simples.
Loops will all likely need to be manually purged again, as the flow rates from the UFH manifold are too low to shift stubborn air pockets. You ( or they ) can sit there and let it run whilst venting / refilling and repeating ( for ages ) or you ( or they ) can just purge with cold mains and be done in an hour. You just need to put a hose on the return manifold drain off point, remove all actuators temporarily, open the drain and allow that to run freely to outside, then open the filling loop on the boiler to allow masses of cold mains water in / through one loop / out to drain, and repeat for each loop ( doing ONLY one at a time ). You'll need to manually open each loop by pressing down gently on the pin ( that pin that gets depressed by the actuator ) to allow water to flow through. The installer should be familiar with all this.
