Nickfromwales
    346
  1. Not a chance! My clients all report the towels drying out very quickly, zero damp / dampness, tea-towels drying out quickly in kitchen etc. A good shower will still make the room 'steamy' but then it goes away quickly along with any residual moisture. You have to remember that the airflow is constant throughout the house so nothing gets a chance to loiter about, but this can affected by how thoughtfully the air valves were positioned. Some designers will install next to the doors, which doesn't promote airflow across the whole room as well as placing the valve at the furthest point away from the door does. As with most things; "done poorly = performs poorly", but I've not heard anyone having such issues to date.
  2. Outdated pile of bullshit. Are these guys in their 90’s or something ? You can discharge D2 internally into a waterless trap, providing the pipe into which that discharges is a modern product that can receive high temp water for ‘short’ periods. You need to challenge these muppets. Prob find their forwarding address is Stonehenge. Ffs.
  3. @Meabh I’ve just emailed Telford tech dept, and waiting to see if they can send me a copy 👍 I’ll post it here if / when they do.
  4. What he said. Odd, as Chelmer seemed to me to be a decent crew. I liaised with them previously over a design for complex biomass installation I had on and they were very helpful ( but busy too ). Thought they’d be able to spit this info out in the wink of an eye tbh….
  5. Hi. What information specifically on the cylinder? Should be easy to get this tbh.
  6. Seriously need to de-clutter, there’s stuff all over the place. 🙄 Don’t visit my house whatever you do. Looks a million dollars, well deserved recognition.
  7. Whichever one you want, I think. Ask Tom. 👍
  8. Even a couple of kWp will put a huge dent in your annual electricity bills. A mate of mine has 4 second hand 250w panels that he rescued from a skip. Routinely belting out around 700-800w. Almost all of his bare loads whilst in work are dealt with by them. Reconsider maybe? With a PV diversion controller a lot could be stored as hot water during the summer
  9. Hi @Dan F Give Tom Barrand ( EcoCell ) a call, he's on 07927 082118. Great guy, and he's pencilled in supporting / commissioning for my own install also.
  10. Hi and welcome. If you need any help uploading images, please ask IIRC we don't have a restriction on image quality / size etc.
  11. Nope....youu're defo in the clear.
  12. I can put you in touch with a decent battery / inverter installer. Decent and knowledgeable chap. No direct affiliation, and standard caveats would be applicable "try before you buy" etc etc. He doesn't want to be 'famous' so PM me if that's of any interest / help. PS, only one "u" in use, OK Don't worry, I don't think anyone noticed.....
  13. Just post it here, less the company's details if you want some more opinions.
  14. These series "branched" systems just seem so impractical and impactful from an installation PoV, plus typically start off with larger bore for larger dwellings. I will always stick to radial systems with 92mm or its 'oval' equivalent ( which is almost rectangular btw ). If you don't want huge posi-joists just for the sake of getting MVHR installed, it's got to be radial.
  15. Got one such install, ground graduated slightly with the mini-digger to help with angle, and that's chucking out a megawatt a month through summer
  16. Oops.... I take it you've not properly read the forum T&C's? If you brag it up too much and you've less than 10 posts, you have to buy everyone a pint. Sorry matey, rules is rules. Check the small-print next time eh
  17. Why not in pods / tubs? You don't need a frame system, other options are out there.
  18. I would disagree with the above ( sorry again ). I almost always install these in corners of the rooms, diagonally opposite the doorway wherever practicable.
  19. Yup. You should be making the runs as least resistance as possible, to ensure fan speed is minimal and audibility is low / non existent. Remember to include box attenuators at the machine to kill the noise at source. Install them on the ducts to atmosphere also if you have neighbours / other noise close by.
  20. Depends on the application / room. If I want super-quiet I’ll do 2 single runs to 2 valves, or if it’s for flow ( en suite shower ) I’ll just do 2 runs to 1 valve because on boost it won’t be heard anyways. Designs should be bespoke, and adapted to each project room by room. 👌
  21. Can’t trust anything anyone from Carmarthen says, sorry. 🤥😂
  22. Basically clear silicone, the last hope for a wonky plumber.
  23. Depends on the room / space, and what it's doing ( fresh or extract ) and so on.
  24. It's our thing....it's what we do lol. Not quite. As it is, eg metal exposed to the elements, you're in a world of hurt. Just imagine snow resting up against that and a bit of wind-chill to boot. The duct will conduct that like crazy. Much as you want to pull the door closed on this, I'd pull it out and do it again, properly. The issue is the spiral seam which naturally wants to track water through the point at which the sealant / or compression seal is trying to keep water out. Random image grab; https://www.google.com/search?q=ubbink+roof+terminal&rlz=1C1CHBF_en-GBGB910GB910&source=lnms&tbm=shop&sa=X&ved=2ahUKEwjI9Mu1ibv8AhXSQcAKHfkfAvMQ_AUoAnoECAEQBA&biw=1280&bih=609&dpr=2#spd=16728725204361805693 This is what it should look like, so imagine rain on that, and how the joint is lost up high within the cowl of the fitting.
