Temp
Everything posted by Temp
Calculating rebuild cost for insurance.
Temp replied to epsilonGreedy's topic in Self Build Insurance
As I understand it repairs (for example after a flood or storm that rips off the roof) are generally liable for VAT that can't be reclaimed by anyone. The only way VAT could be reclaimed is if the house was so badly damaged it had to be demolished and rebuilt. -
About 30 mins.
Some "high street" outlets deserve to go out of business.
Temp replied to ProDave's topic in Kitchen & Household Appliances
The sheds have given up on the quality/custom end of the market. They just want to shift easy to sell stuff like homewares, surprised they sell kitchens at all these days. Got our latest washing machine from AO. They delivered it next day which was a Sunday. They would have unpacked it and installed it had we wanted. They took away the old one. There aren't many built in microwave ovens (according to our kitchen supplier) and they are more expensive. Ours is a Neff. Our Bosch dishwasher has given good services. Currently 11 years old. Had to replace a heater last year but Bosch parts are easy to get. -
You don't necessarily need a motorized cutter for wall tiles but maybe for thicker floor tiles. Iv done a bathroom just using a hand score and snap type cutter. Much less mess. I have a water lubricated cutter now and it has to be used outdoors and you get soaked.
Find out if what you want needs planning permission (PP). It's not always obvious. You could do your own rough sketch plan and post it on this forum for comment. Even if PP is needed you may not need an architect. With care it's possible to make your own scale drawings and do your own planning application. If you can't make scale drawings then an Architectural Technician might be cheaper than an Architect. For a simple box extension on side or back a good builder could work from the planning drawings. Building Control would definitely need to be involved but they may agree to do it on a "Building Notice" rather than require "Full Plans Approval". A builder should be able to estimate the total cost from a back of the envelope sketch with dimensions and a site visit to check for any issues (like manholes to move or build over). Get him to do a proper quote when you have planning permission or better drawings.
Some lithium cells can catch fire if fast charged after an excessively deep discharge. Usually the tool cuts off before the voltage gets too low to safely recharge the pack but if they are put away flat they can slowly self discharge below the safe recharge voltage. Some chargers will detect the low voltage state and only allow trickle charging until the voltage come up enough to allow fast charging. Some just assume the battery is toast.
A bewildering choice of shower heads
Temp replied to vivienz's topic in Bathrooms, Ensuites & Wetrooms
What flow rate can you get from your hot water system? No point in having a rain type 40L/min head if you can only get half that from your supply. We have a diverter on our mixer that can switch the output to either 1) an 8" overhead old fashioned rose or 2) a hand held "telephone" style rose. The overhead rose is all metal has a great flow rate to get soap out of your hair. The hand held has great pressure and a decent flow rate. So we know we can get pretty much any combination of flow or pressure from our mixer depending on the rose. Recently I've had requests from family to replace the overhead with something more like the hand held. I've tried three so called high flow rate plastic heads off Amazon and elsewhere but none have been any good. I've taken two apart and they all have narrow channels moulded in. Especially if they have any kind of ball joint to allow it to swivel. So next I plan to try a smaller all metal fixed head rose, perhaps something like this 5" rather than the 8" we have. https://www.just-perrin.co.uk/5206-perrin--rowe-5-130mm-shower-rose-2524-p.asp -
Longest available foul drain pipe section.
Temp replied to epsilonGreedy's topic in Waste & Sewerage
You could always pressure test your joint before burying it or even install a second backup run in parallel in same trench. You can get 110mm OD HDPE in 50m coils ... http://www.abwplastics.co.uk/excel-pe100-water-pipe-blue-110mm-od---coils---sdr17-20151-p.asp Not sure about shorter lengths. May not lay flat easily. -
Careful... Many tricks only apply to NiMH cells. Many tricks only apply to over discharged Li-ion cells. Can you put a voltmeter on the pack? I'm wondering if the internal fuse has blown.... In that case the charger might be raising it's output voltage to try and push current into the battery and that higher voltage is fooling it into thinking it's fully charged.
electricity connections Extortionate price
Temp replied to recoveringbuilder's topic in Electrics - Other
+1 Make sure to get that in writing. -
MVHR with extract only mode
Temp replied to MikeGrahamT21's topic in Mechanical Ventilation with Heat Recovery (MVHR)
We find the main benefit of MVHR is the constant level of ventilation it provides. We still throw the windows open at night in summer to cool the place down. -
Commercial to residential conversion - business rates!
Temp replied to Tosh's topic in Party Wall & Property Legal Issues
I don't think there is a legal definition of habitable but google found.. https://legal-dictionary.thefreedictionary.com/habitable https://www.legislation.gov.uk/ukpga/1957/56/part/II/crossheading/definition-of-standard-of-fitness/enacted?view=plain -
+1 Only what's on your grant of planning permission matters. This document usually has "Decision" in the title online so that's where I'd start. If it was granted some years ago without an S106 or CIL you might want to get a move on and officially start work before it expires. If you need to renew your planning permission they may have an opportunity to add an S10 or CIL if planning policy has changed in the meantime.
I'm sure you all know this but make sure your layout has pipes meeting at the correct angles. Joints will accommodate a small error in the angle but it's a pain to have to make a connection if the angles are way off standard.
Interesting.
As I understand it you need a large burner in a combi to provide the flow rate needed for a shower. This determines the minimum burner size which is also used to provide the central heating. It's not (such) a problem for a system boiler because they don't have to instantly heat the water for a shower. Instead it's the hot water tank that provides the high flow rate needed.
Looks like rules on smoke alarms in Scotland are changing or have changed post Grenfell.... https://www.bbc.co.uk/news/uk-scotland-43443725
- 25 replies
- landlord
- low voltage
(and 5 more)
I think the problem is finding a small combi. Less of a problem if you want a small system boiler feeding a hot water tank. WB have 9 and 12kW gas system boilers. https://www.worcester-bosch.co.uk/products/boilers/directory/greenstar-i-system-9kw-to-24kw Pretty sure they modulate down to 30% but best check with them. If that's correct then I think your rads still need to total over 3kW.
I think HG also make a teak restorer intended for garden furniture.
Thanks. Not sure why the links don't work. I thought I used URL tags to stop them breaking up but the tags don't show up if I edit the post.
I currently have a pair of 47kg propane cylinders on an auto changer feeding a 6 ring gas hob in the kitchen. The pigtails are all brass, this type.. https://gasproducts.co.uk/gas-regulators/pigtails/20-148-propane-gas-pigtail-pol-x-w20.html I'd like to switch to smaller 19kg cylinders and to do that need longer pig tails. Was thinking of switching to this type of pigtail which don't need a spanner.. https://gasproducts.co.uk/gas-regulators/pigtails/gaslow-easy-fit-1-5m-propane-gas-hose.html Obviously that makes the cylinders easier to pinch but I can fit a padlock to prevent that. I'd like to know if anyone has experience of these? It looks like they have a rubber seal rather than brass on brass. Are they prone to leaking or any other issues I should know about?
Not sure if that link works but the original can be found here.. http://www.greenbuildingforum.co.uk/newforum/comments.php?DiscussionID=15130&page=13#Item_13
Someone called "lineweight" posted this detailed expert witness report on how the tower did/did not comply with the Building Regulations... https://www.dropbox.com/s/9f9679e7k0yppyj/Dr Barbara Lane report_1.pdf?dl=0 It's full of horror stores so I just pick out..... "11.18.22 I have found no evidence that proprietary cavity barriers were specified at any stage of the design or installed during construction to close the openings created in the external cavity walls by the windows." snip "11.18.29 I therefore conclude that every window opening in Grenfell Tower was not compliant with the provisions made in section 9.3 of ADB 2013 to provide cavity barriers to close around openings in the external wall"
As a last resort... One possibility might be to go down the Traveller site route. However you might have problems later getting it changed to a dwelling as that would involve the loss of a travellers site. Government policy has changed over the years but I think this is current.. https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/457420/Final_planning_and_travellers_policy.pdf Also check out your local development plan. It It's not clear if the person applying for planning permission for a traveller site actually needs to be a traveller themselves. I see nothing in the guidance that requires this. Nor does the site have to be open to all travellers. Many traveller sites are privately owned by the travellers. Around here the approach is to apply for a standard traveller site layout (eg pitches and laundry blocks) then once approved they build whatever they actually want. Lots of sheds, log cabins etc. One option might be to argue that travellers need accommodation for animals and include a barn, then after 10 years as a home for your horse you might be able to convert it to a house. However you would need to plan ahead. Some issues discussed here.. https://www.wrighthassall.co.uk/knowledge/legal-articles/2017/05/19/class-q-permission-barn-conversions/ I'm only half joking.
