Temp
Everything posted by Temp
If you rent out the new house then I believe there is a problem with reclaiming VAT. You should seek advice on the following as it might be out of date... https://www.glovers.co.uk/news-articles307.html Normally new houses are zero rated when sold so VAT paid on materials can be recovered either by you using the self build reclaim scheme or by your builder.. But if its let then its an "exempt supply" not "zero rated". The difference is that VAT cannot be reclaimed according to...
Could this be a case of the liquids going too fast and leaving the solids behind? I've heard that can happen if drains are too steep by not sure if its a myth?
I didn't do mine but our architect produced quite a lot... Lots of sections through key areas. Eg showing foundations, Walls and floors, beams and lintels, cavity trays and closures, damp proof courses and membranes. Calculations for any universal beams (aka RSJ). Specifications for bricks and blocks (density of blocks and frost rating of bricks I think?) Drainage layout showing stacks, approx pipe runs, inspection chambers. Think we only had to provide U-Values for elements when we built our house but think you now need to provide SAP and predicted EPC? If any of the construction is non standard you may get asked to show how it complies with Part E sound. To avoid them asking you to do a sound test at the end (with risk of failure) you can provide so called Robust Design Detail drawings which I think you have to pay for. Before you do that try asking the company selling you insulation to see if they have a Robust Detail Drawing that matches your construction detail (or change your design to match their drawing?). This shouldn't be necessary if you are using reasonably standard construction. If its three storey there may need to be some detail drawings to show compliance with part B. Fire rated doors? You might consider telling the BCO you have a pretty good idea what's required but ask if he has a check list? Edit: Sorry I'm talking about England. Not sure how Scotland differs.
Minimum Reasonable wall width for good U values?
Temp replied to puntloos's topic in Heat Insulation
Thats ok but If the structural timbers are on the cold side of insulation they need to be well ventilated. -
Wedi Board supplier : recommendation?
Temp replied to ToughButterCup's topic in Bathrooms, Ensuites & Wetrooms
Think I got a few sheets from Travis Perkins but their list prices are probably high. Aside: I think BnQ are discontinuing Hardi Backer board as I got a the last sheet from a store near me at a very good/clearance price? -
Studs would make great kindling if split up. Probably shouldn't burn the wood preserver but hey ho.
Paul from Wales starting on timber frame extension with DPC question
Temp replied to hotnuts21's topic in Introduce Yourself
We have a split level house so there are similar changes in level under our house. I was also concerned about water penetration. Built a french drain...We dug regular foundation trenches and filled them with concrete then we built brick and block walls up above the high side. These block walls were tanked on the outside with a paint on rubber tanking solution down to and including the tops of the concrete. Then a sand blind and a perforated pipe in gravel were installed before back filling. The drain pipe led to the rest of the rainwater collection system. -
You can get plinth bricks that have a 45 degree sloping top. You run a strip of lead flashing behind the timber cladding (and any membrane) down onto the plinth bricks, out and about 1" down the sloping part. This helps stops frost damage to the top of the bricks. An alternative to plinth bricks is to use some slate set on a mortar bed but plinth bricks are better in my opinion. -
There is a physical limit. How crazy do you want to get? I think Aerogel has the lowest thermal conductivity known to man so wall made only of that stuff would be the thinnest possible. However its horribly expensive not readily available and wouldn't carry much load. Its also translucent. The next best material is PIR (polyisocyanurate) insulation which is a lot cheaper and more widely available then Aerogel. Some form of timber frame infilled and covered with PIR is probably going to give the best U value for minimum thickness. The outside could be rendered, clad with brick slips or battens and some form of rain screen/siding. One issue is the difficult of cutting and fitting PIR tightly between a timber frame. Poor workmanship can ruin a good theory. Some form of compressible rockwool batt between the frame might work better because its easier to get right even though the U-value is theoretically worse than PIR. A combination of Rockwool between and PIR outside would be reasonable. A layer of plywood or OSB would probably be needed to prevent racking. You might also look at a SIP panel construction. -
Heads Up! Ordering from Germany.
Temp replied to ToughButterCup's topic in General Construction Issues
PS I got my Geberit frames from a German seller on eBay UK but that was a decade ago. -
I claimed 21% Belgian VAT when VAT here was 17.5%. Think I just converted the VAT paid from Euro to £ and wrote it on the self build reclaim form. Presumably this will still be allowed after 31st January? -
All applications are meant to be acceptable in their in their own right. I would have a look at the Design & Access statements for these other properties. Ditto the planning officers recommendation report to the committee (if they went to committee). These will give you a good idea what if any objections the planning officer had and possibly how they were overcome. For example one objection to rural development might be a lack of services and public transport. So you should check there are spaces at the nearest schools and a school bus to get there. Ditto access to doctors and ideally shops. Planners call this sustainable development (nothing to do with being green). You need to do this even if you don't have kids - planners have to assume anyone could live there.
No they won't do that but they sghould get utility maps as part of the normal searches they do for any house purchase, eg to check there don't need to be wayleaves or other rights of way/access. Typically it takes a solicitor 3-4 weeks to get them from the utility company. What I did was call them up pretending I was digging on site and had found a cable/pipe. Asked if any chance I could pop into their office later same day to pickup a map. Said I didn't need a meeting of anything. Had a map same day. They need the coordinates and scale you want. Once you know where the nearest services are you can estimate likely costs. Most of which is usually the cost of digging trenches in the verge/road. If they are in the road past the plot that's about as good as it gets. Any services that are more than say 50m away should start affecting the value of the plot as you could be looking at £5-10k to get them to the site. Main thing to check is that none of the route is privately owned. You can also ask neighbours or physically look for manholes or access hatches.
When you purchased the plot did your solicitor do "searches"? A good solicitor will contact the utilities to get a map as part of that process. Just in case there is an 11kV line or a gas main under the plot. If you can find out where the utility co has their asset mapping office you might blag a map quicker/free. Worked for me. Free map in a few hours but i had to collect it.
Showers - enter at your peril.
Temp replied to epsilonGreedy's topic in Bathrooms, Ensuites & Wetrooms
Bit too snug for me. Minimum I would go for is 100 x 80. Main reason we went for shower trays and screens is I hate getting wet socks. With pre-planning you can recess a shower tray as @Declan52 said so there is no plinth under it. Trays are available with or without anti slip embossed patterns and/or coatings. I recommend ensuring the top of the tray is at least 5mm above the tiles not flush so the door seal doesn't scrape on the tiles when opened. -
I'm about to fit a MacAlpine ST90CB10-70 top access trap that appears to be rod-able through the removable top access trap. If that's not sufficient one option is to have a small access panel in the floor to one side of the shower tray. Under that you have a gentle 90 or 45 bend with a cap on that leads into the shower waste pipe.
Another mad idea. But who can tell me what exactly this Plywood is?
Temp replied to Patrick's topic in General Joinery
I would hope that the core is always waterproof plywood but that might not be the case with some grades.. https://www.builderdepot.co.uk/18mm-phenolic-film-faced-shuttering-grade-plywood-2440mm-x-1220mm-8ft-x-4ft -
Google phenolic coated plywood. Can get it with various patterns on it. -
Only one I had issue with was the water company. We had to get a water main diverted as well as the connection. They wanted to charge a lot of VAT on the diversion part. Refused to pay until the VAT was removed. I referred them to https://www.gov.uk/guidance/buildings-and-construction-vat-notice-708
Google found some drawings of typical make up of a tarmac footpath... https://www.york.gov.uk/downloads/download/1539/highway_design_guide_-_technical_specification_drawings_and_plans_pdf Perhaps see if your council have similar drawings or make your own drawings based on these (eg a site plan showing where the path will go, a cross section of the path showing the make up and a cover letter). Ask them to confirm these details are acceptable before doing the work. When the work is finished apply for the condition to be discharged along with any others you have met at the same time.
As i mentioned above, do not start work until the CIL exemption paperwork is done. Its a multi step process, miss a step and you loose the exemption and become liable to pay it. One bit of paper lost in the post or even lost by the council and you loose the exemption and become liable to pay it and a penalty! You need to be able to prove you have jumped through all the hoops. I would not leave this to the Architect. Example: Man hit with £40,000 bill because he told the council he was starting work by email instead of using the right form!... https://www.lexology.com/library/detail.aspx?g=ca104a53-d127-4442-b05e-1c01a0389058
I love plumbing...not... I'm currently working on an en-suite we never finished when we built the house. The pipe in the floor is Osmaweld grey but nobody seems to sell the other bits I need in grey locally. I figured white bits would be fine as it's all under the tray/floor. Wrong. It seems Osmaweld white and grey are slightly different sizes. The short length of Grey 40mm pipe I have is a bit too loose in a white 50-40mm adaptor for comfort. And yes its all same make and all solvent weld. Another 30 mile round trip tomorrow I guess
Welcome to the forum. Before you do anything on site have the council said anything about the CIL in your planning permission? https://www.chichester.gov.uk/article/29769/Would-CIL-be-chargeable-on-a-barn-conversion If you are liable then it is essential you apply for the self build exemption before doing any work. Failure to follow the multi step process to the letter and you become liable, possibly with no way back. One letter or form lost in the post has cost people £lots. If you're an SE you will probably know a lot of this (so sorry in advance)... That's called a "warm roof construction" because the rafters are far enough on the warm side of the insulation to prevent interstitial condensation. Ideally you should aim for as much insulation above the rafters as possible but usually a compromise has to be made. That will also give you nice exposed rafters on the inside if you want. Typical construction might be: Tiles Tile Battens Counter Battens Vapour Permeable Membrane Insulation Rafters with insulation between (possibly insulated plasterboard). There can also be an OSB layer somewhere in the mix to prevent racking. Not always necessary. Seems more common in Scotland? The counter battens lift the tile battens off the membrane allowing any water that is blown under the tiles to run down and not pool above the battens causing them to rot. Typically you need special long fixings to fix the battens to the rafters through the insulation. I gather these can be quite expensive but other can advise better than me. It can be tricky getting them to go in straight and hit the rafters. Ideally a condensation risk analysis should be done to confirm the ratio of insulation above/between is ok. Some insulation suppliers may do one for free. Many insulation suppliers have apps notes.. https://www.celotex.co.uk/assets/between-and-over-rafters_application-datasheet_nov18.pdf
