Temp
Everything posted by Temp
Our floor has been down 13 years. Only had to recoat the WC. Have occasionally mopped the floor but only with a damp mop.
PS. We got our 21mm x 200mm engineered oak from Woods of Wales. It came precoated with Hardwax Oil. Shop around as some engineered wood i picked up at the shows was a very strange colour when I got it home. You need to see it in natural light.
We have engineered oak in many rooms over wet UFH. In my view the key is to have JUST engineered wood over the UFH. Some people buy 14mm thick engineered wood then discover the Building Regs (?) require 18mm minimum. So they end up laying 18mm chipboard first and 14mm engineered wood on top making 32mm. Its much better to use 18-21mm Engineered wood directly on joists or battens with UFH between.
What will the window cleaner charge ...
Temp replied to ToughButterCup's topic in General Self Build & DIY Discussion
I've seen a house in Belgium that looks like someone took an axe to the ridge and cut a V shape glazed notch out of the ridge. -
Yes to starting in the middle but first check won't be left with very thin cuts to do around the edges later. If that's going to happen put a grout line in the middle.
If its only a few areas that need rebuilding you can try spelling out what you propose in the planning application. Call it a conversion but make it clear somewhere in the Design and Access document the parts that will need rebuilding. If most of it needs rebuilding you will need to apply for a knock down and rebuild. Perhaps go for the former and let the planning officer decide if it needs to be considered a knock down and rebuild.
Bookmark this site for when you need info on anything like paving/drainage etc.. https://www.pavingexpert.com/ Check Block Paving in the index.. https://www.pavingexpert.com/pavindex Loads of info. They also have specifications for some work you can ask a contractor to quote against.
My guess is the builder will use two steels the same size so he only needs calculations for the one with longer span. No doubt another forum member can recommend a cheaper SE service.
My understanding is the planning rules are different. A class Q "Prior Approval" application to convert agricultural buildings cannot be refused by the planners if it complies with the rules (eg must be capable of being converted) so of course the pre app would be favourable (they don't really have much choice). Just be sure there is evidence of agri use. Some people have had refusals because the buildings were used to store old cars in or rented out for storage. That means they aren't agricultural buildings anymore so may not qualify for class Q. The approach some councils take is very different to others. In some areas an appication to demolish and rebuild might be treated like a new house in the countryside and refused. So the issue of structural suitability and evidence of current use might be key. You might consider making the purchase conditional on getting PP one way or the other.
What sort of cover do you want? I decided a certificate wasn't worth having and went with a warranty. I figured its very unlikely we would have a problem that the Architect could be liable for. Some 6 years after we finished we discovered the tiles on one side of our garage roof were spalling badly. Architects certificate would not have covered it.
Bit expensive but fast enough to share with a few neighbours if that's allowed..
Turn a habitable room into dressing room to avoid fire regs?
Temp replied to Mat1's topic in Building Regulations
Some sort of fire escape platform above the glass would be allowed but bit ugly. -
Exposed vs concealed shower valves/pipework
Temp replied to Adsibob's topic in Bathrooms, Ensuites & Wetrooms
With care you can test for leaks before tiling or even boarding the wall.. -
You can drop it onto the slope (we have that in several places). You normally fit a bend at the bottom that directs water points across and down the slope. I would support the overhang at 3 with posts and perhaps run two downpipes one down each post to cope with the flow. We have had issues with overflowing. Not really due to the capacity of gutters exactly but due to the higher speed and depth of water on the roof causing some to overshoot the edge of the gutter.
The problem is once a neighbour complains and they find a breach of the regs they are kinda obliged to "regularise" the situation... https://www.lgo.org.uk/make-a-complaint/fact-sheets/planning-and-building-control/planning-enforcement Yours might not be quite that bad but I don't think they have any powers to approved a breach unless you make a retrospective application. If they approve it the neighbour can't really complain that the due process wasn't followed.
- 14 replies
- planning permission
- enforcement
(and 2 more)
+1 Worth considering strengthening the whole floor if you are planning to tile it.
I think cafes are now use class E so may need planning permission to change from F2 to E.
From Google.. https://www.lexology.com/library/detail.aspx?g=ab2d7bdc-5751-4b87-ae99-f273c0260918#:~:text=Class F2%3A Local community&text=A hall or meeting place,use of the local community.&text=An area or place for,involving motorised vehicles or firearms.&text=An indoor or outdoor swimming pool or skating rink.
Have they given any hints on the likely outcome? Sometimes they suggest a retrospective application if they think it will be approved.
- 14 replies
- enforcement
(and 2 more)
Do I have a siphonic toilet?
Temp replied to ash_scotland88's topic in Bathrooms, Ensuites & Wetrooms
Sounds like a partial blockage in the drain. Symphonic wc do fill up the pan but then drain out more rapidly than you describe. As I recall the waste outlet pipe is a smaller diameter on a syphonic so I don't think you have one of those. -
In the end I hired a Paslode IM350+ from HSS for the weekend. They gave me a brand new machine! Amazing bit of kit. I was shooting 51mm galvanised ring shank nails with notched heads. Never missed a beat. Made it way easier as I could push the gun through the neighbours prickly plants.
How about this stuff.. https://www.tilingsuppliesdirect.co.uk/product/no-more-ply-tongue-groove-board-18mm-22mm#.YF50wMinw1I "No More Ply Tongue & Groove Board is a thicker version of the standard No More Ply Tile Backer Board. It is a fibre cement board with a tongue and groove connection that is designed to directly replace floorboards on joists." Does it conduct better than plywood?
I sometimes think that companies like Hardi (makers of Hardi tile backer board) are missing a trick. Isn't there a market for a cement board that.. * Is strong enough to be used over joists (or battens) * Rigid enough (over joists) to take tiles. * Conducts heat well enough for UFH. * Water resistant for wet rooms. Or is it just not possible to make one?
I have 80mm PIR in some rooms and if building again I would fit more. I assume your screed is 150mm thick in the workshop because you will be driving a car on it? Need not be that thick elsewhere.
