Marvin
    3
Everything posted by Marvin
  1. At least there looking at tidal power generation, the most constant and reliable "Green Energy" available. Every time it goes dark here my lights go out...
  2. kW hour now 3.
  3. I set up a 0.5 watt led night light that is on when the bright main lights in the windowless en-suite are off, as a movement sensor used a lot more power, and she didn't want to click a switch at night (also the light is a nice dim yellowy orange so it disturbs the sleeping patterns less).
  4. I'm sure we will get over it but we just had our first kW of PV. ???
  5. With that I usually run silicone along where the 2 parts touch and screw up in the cill recess. On mine I filled the cill under the window with insulation....
  6. I'm surprised more people don't.
  7. Permission received from my DNO to install and connect to the grid 6kW PVs! (Distribution Network Operator = Scottish and Southern Electricity = SSE) All I have to do is accept SSE's quotation for the "Non-Contestable Works" and pay the fee. (there are no additional works required).For my £360.00 including Vat SSE will complete a site inspection. The checking of the network system has already been completed and there is no additional work to be carried out. For your information; Although I applied stating I would use a CT clamp to limit the PV power to Main Grid, SSE will not take the CT clamp restriction into account and have taken the inverter limit as the worst case scenario. @Wil was right. ???? The inverter maximum wattage is 6kW. the panels will supply up to 5.12kW Time line: Application submitted in full 29th September 2020, quotation received 26th November 2020, so about 2 months at present. IF we had other works, the SSE would need to do, they estimate they would have got back to me about the works in about 6 months after paying the quote. Good luck with your project. Marvin
  8. Well @LSB, stepping back from the situation, the depth to me seems odd. As I understand it, foundations are used to ensure the weight of the building is dispersed over a ground surface area capable of supporting the structure plus a factor of safety. So larger surfaced than usual foundations usually indicate either a heavier building or dodgy ground or a point load - say a pad foundation for a steel. Deeper foundations point to poor ground or tree roots. The only time I've known 2.4m deep underpinning was because the roots from a mature oak tree 10 meters away were undermining the foundations of a house. If there isn't anything indicating tree root potential then it has to be poor ground and the only way to tell how far to go down is to dig a trial hole or bore down to see where the good ground starts. Other things of note are sites with steep sloping ground or near other properties or your going for a basement. This is the limit of my knowledge so I leave it to others to point out my failings. You need to get to the bottom of this. (Sorry I couldn't resist) All is not lost! Hang in there. Best of luck Marvin.
  9. If you stand under the inlet valve and you have as much hair as me, then yes in about 50 seconds.
  10. That makes me a nobody. ?
  11. Don't know whether to laugh or cry!
  12. Remember reading 40 years ago in Mad (the one with Alfred E Neuman) about changes to come: People in the future having to wear head covers on the beach and put gallons of sun cream on to protect them from the sun. Who's laughing now? Back on topic... I think that the calculations for heat pumps will be superseded by calculations for cooling pumps as we go forward. Even with limited glazing in our house (no south facing) the peak solar gain almost equals the peak demand for heating! Never did like being cold...
  13. A nice little storey on cause and effect (or is it the other way round?) is Joseph Conrad's short story Typhoon....
  14. Put a tissue on the window board and leave over night to see if it's running off the window...
  15. Its a mathematics thing! You don't learn it you can't use it! The two most important subjects to be learnt to a good level: Communication and mathematics. And the other one I recommend is Yard Sticks - the ability to stand back and view the probable outcome.
  16. Well this calculation is getting worse by the minute! ???
  17. Also not sure of basin, bath waste pipes or where the water supply pipes are or any heating pipes, so lots to consider.
  18. Yes but cut carefully and packed out between the ridges on the panel side. You would have to choose a thin cat flap, and this assumes the door is not open to the elements, otherwise you will need to seal all around the outside edge using something like frame sealant. Avoid cutting the bottom thick part of the door, or the door structure will be weakened. Good luck M
  19. This is what I am installing but a 5.12kWp roof mounted self installed system which will cost about 3k. 1kW immersion with adjustable CT clamp on PV 240v output cable and the same for EV charging set at 2kW after. Also the higher PV power produced in the summer will be used for cooling via the ASHP air to water coils in MVHR system. We will see what happens. M
  20. This indicates to me that the floor in the shower room was taken up to change the design and this will have to be done again to reverse the layout.
  21. This is posted during the design and installation phase during the winter 2021/2022. The cooling side results are not expected to be known until Summer 2022. As the air passes through the water coil it changes temperature depending on the coil water temperature. If the coil is going to be used for heating only it can be used without a condensate trap. However as this is going to be used for cooling as well I have constructed a drain in the bottom. Coil with lid off. Air flow from top of picture to bottom. Drain in bottom side of coil where air would be coldest. This is a picture looking down into the bottom side of the coil. I have added water to test that it runs away which it does. Because the coil is on the push side of the system ( inlet to rooms ) the condensate pipe requires a set of bends to form a sort of trap that the air would not escape from but water would. The air pressure in my system is very low as an MVHR pushes in and pulls out air in the building at the same time, so quite balanced.
  22. Any pictures? Sometimes the fiber washers crack. Try undoing the heater a couple of turns and wrap a whole roll of PTFE on the exposed thread and then do it back up. Plumbers mate and gutter sealant no good. Clean these all off.
  23. Nothing wrong with 150mm in one go. If you have 2 layers it's thought a good thing to stagger the joints, a bit like 2 layers of plasterboard or loft insulation.
  24. Better prey not.
