TonyT
Everything posted by TonyT
Is it the brandering under the ceiling as it’s not nailed on every joist, this may be the squeak
Manifold system versus hot return system
TonyT replied to Russell griffiths's topic in General Plumbing
Plus one for bronze pump on DHW. -
First day in static caravan... electric tripping, help!
TonyT replied to Tom's topic in Consumer Units, RCDs, MCBOs
Yes, split the ring into smaller sections and carry out further tests, keep doing this until you find the fault on one particular cable and replace cable. -
https://www.appliancesdirect.co.uk/p/eiq-12wminv/electriq-eiq12wminv-wall-split-air-conditioner?refsource=apadwords&mkwid=sTq41ApBF_dm&pcrid=316375285866&product=eIQ-12WMINV&pgrid=60291385853&ptaid=pla-446815102020&channel=googlesearch&gclid=EAIaIQobChMIodGs_r-A7wIV8IBQBh2LDAtCEAQYAiABEgJ-Y_D_BwE what about one of these?
Was the plumber paid direct to you or the main contractor? If you fine, otherwise I would be speaking to the main contractor all the time for all the defects and let them organise trades
Appointing a main contractor/builder - things to consider
TonyT replied to Tom's topic in General Self Build & DIY Discussion
Payment after agreed stages are complete. -
Maybe worth adding another loft hatch to get better access to the underside of the roof/ assist with diagnosing problem.
You can’t say you are going to do a good job if you aren’t insulating under the UFH. ?
If you are flipping the flat for profit, what gives more profit. Radiators or UFH?
Sorry to see you are having problems. good luck
It’s not the first flat with concrete floors and ceiling to get rewired and new heating system. Post a layout drawings of the flat, showing boiler positions, cupboards etc you can make box skirtings to hide pipes, put radiators back to back etc UFH will be pants in this flat
Self build in Scotland - advice please?
TonyT replied to 2nd Time Around's topic in Introduce Yourself
https://www.navitron.org.uk/forum/index.php/topic,29794.0.html close?? -
https://www.diy.com/departments/angara-grey-composite-deck-tile-edge-l-0-4m-w-200mm-t-45mm/3663602613299_BQ.prd?gclid=EAIaIQobChMImeSqr7H77gIVoejtCh1XCQU2EAQYAyABEgJ7gvD_BwE to finish off the decking/ground transition
Airtight walls & fixing stuff to them
TonyT replied to WWilts's topic in New House & Self Build Design
What Dave says I used 35mm thick timber as I needed 47mm deep boxes for cooker points and data points. -
I was in B&Q this morning and picked up some adjustable decking joist supports. look like plastic dinner plates that spin to adjust height. 10 for £14. I’m going to use these to build a bike store at the side of the house
No you can’t mix and match different manufacturers -
Sounds reasonable that the whole RCD is faulty if it’s not holding in after all that fault diagnosis don’t know what spares are like for a like for like replacement RCD , may be cheaper to replace the whole board £ 30 -£40 at screwfix. -
http://www.civil-engineering-calculators.com/Quantity-Estimator/Excavation-Calculator Afraid I just left the guys to it, thankfully the guys doing the excavation also own the village dump /skip company so excavation costs were minimal. soil does bulk up when excavated approx 30/40%. So take this into account.
underfloor heating Underfloor heating installation opinions on work quality
TonyT replied to Pbb's topic in Introduce Yourself
It’s not good, so cancel the screed until this is resolved. how thick is the insulation? is there any up the sides of the walls on the external walls. have you looked at the manufacturer instructions for the system that’s installed? That will give you specific info to discuss with the ‘plumbers’- 26 replies
Flow & Pressure should be checked, but that can change depending on the network which can change with local issues, bursts, extra load on the network such as new housing schemes.lots of variables.
some info -
Oh and make sure all appliances are switched off and lights off as you switch anything on watch for power going off invade this helps prove part of circuit/appliance causing issue
