TonyT
    6
Everything posted by TonyT
  1. I would go for a 5 core. or run a separate earth alongside the 4core, so back to a 5 core then?
  2. Treadaire dreamwalk for me.
  3. It’s not flash to use a puffer, it’s following manufacturer’s instructions. I prefer hilti, and follow their instructions, so it’s generally a 2mm bigger hole than the rod.
  4. Run a cable to an additional access point?
  5. In 2004/5 I put in cat 6 cause I was using it on a job and it was leftover. cat 6 has a larger bending radius so needs deeper boxes than cat 5 so that may be a consideration. im not doing anything fancy computer wise, just streaming films, kids playing xboxes and general internet surfing
  6. Nothing wrong with a 7 kW charger.
  7. Doubt it, it’s a 10 hour drive.? maybe the viesmann website will have a list of local installers?
  8. He is Viessmann registered and has to be Viessmann trained to get onto installers portal to enter the data for the warranty.
  9. Oh and for £180 you get a full 10 year warranty complete with parts and labour
  10. Fitted a vitodens combi in the in-laws house 2 weekends ago, great boiler As they are getting on, we just used the existing 230vac stat and programmer, as they were getting worried about a new one. so plus one for vitodens from me!
  11. Pop up mini wine cellar
  12. Do you need mechanical fixings on the copes now?
  13. Pull it out, and make wants to Harry Potter fans
  14. Personally I would leave the main switch and swap the mcbs fo rcbos. Rcd main switch will plunge you into darkness( assuming no EM lighting installed) when anything trips.. minimising grief is the name of the game!
  15. Buy decent switches too
  16. It’s standard practice to have a switched spur control an appliance, you could put 2 side by side or build something with grid switches
  17. Magic gel https://www.toolstation.com/magic-gel-ip68/p47003?store=D6&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&mkwid=s_dm&pcrid=515847200330&pkw=&pmt=&gclid=CjwKCAjw95yJBhAgEiwAmRrutMbFP_3FJh1BFyTz7BTyhLuRdWt6QiOxe75boJYbbcFRb3jFXH9ZMhoCa-YQAvD_BwE&gclsrc=aw.ds
  18. Vague instructions means it doesn’t matter if you are out a little bit, it’s not like self levelling compound that specify x amount of litres of water per bag. don’t worry it will be fine
  19. The EU said so
  20. Just put sleeving over the original conductors to change ‘function’ if required
  21. I think your first post asked should I be getting an electrician in for this? I think the answer now is yes, it will be sorted quickly and safely and let you move on.you gave it a bash, time to call out the pro. dangerous stuff electricity!
  22. They might have an external antenna to wire up to the meter, would that work?
