TonyT
    6
Everything posted by TonyT
  1. That’s a fair point, the 3 sides that are in the wall isn’t a problem, and the front does require a clean. i use a wipe and push it into the gap and pull it along, takes 2 minutes.
  2. Get a tray with an upstand too, saves a lot of future grief!
  3. https://www.tlc-direct.co.uk/Products/QUWS1W.html
  4. Get a price from Mull Joiners Ltd to build a frame on site?
  5. Ditto, they did mine like this last year.
  6. This has some info, not sure if its online, taken 5 minutes to uploads the screenshot , not in a good signal area today
  7. I’m sure there is a British standard for fixings, pretty sure i remember downloading it before I left the free access to all the standards with my last mob
  8. Looks like 2 phase supply, assuming that it’s actually energised at the cut out. bit rough leaving the blue conductor not terminated
  9. https://www.drainagepipe.co.uk/perforated-filter-drain-pre-wrapped-80mm-o-d-x-50mtr-coil-p-FD8050/?keyword=&matchtype=&device=m&campaign=&gclid=Cj0KCQjw18WKBhCUARIsAFiW7JxMA9BBlnr9PqDx4sHtpMME7Sn1mEWjVn3ph3ut7iBgKN136c6RjBYaAsdZEALw_wcB
  10. Which you can confirm with a multimeter
  11. Isn’t it just a volt drop problem so increasing the csa of the conductor would let the distance be greater.
  12. The point where you plan to provide power from should have a line/live, neutral and earth. you don’t need to go back to the consumer unit, unless of course it’s more convenient for cabling reasons
  13. I’ve heard from installers that you should leave a gap in the adhesive I.e. not a continuous bead around the perimeter to let air in.
  14. Still air blocked , flush 1 zone at a time
  15. Don’t let the builder dictate how you want it done after you have researched it, cause 90% of the time his method will be a shortcut to save him time, effort or materials or a combination of all 3. At work I insist that walls/floors are inspected prior to a covering/plasterboard being applied to ensure no shortcuts.
  16. Is that one twin and earth feeding both immersions?
  17. So that’s photos of my 3 phase 22 kw charger. first photo is power in via swa cable and top photo is the socket.
  18. Where will you store 5000 litres of hot water?
  19. I will take a photo of one at work tomorrow if i remember!
  20. My pipe is outside, it’s only 600mm diameter to let a pump float switch and pump sit without obstruction. we could have done it with conductivity probes and a smaller diameter pipe, but the way we did it was simpler and cheaper
