TonyT
Everything posted by TonyT
I’ve just installed a 600mm diameter pipe 2.5 metre vertically, with a pump operated via float switch to relieve pressure off an old concrete slab with 30 plus construction joins in the slab( big slab) It worked in my situation
Temporary power to static caravan
TonyT replied to DragsterDriver's topic in General Self Build & DIY Discussion
I would buy an inverter generator, generally quoted and better AC output and couple that with Pro Dave’s suggestion of gas fire, water heater etc. -
Flue Outlet Location Change - Do I need Permission?
TonyT replied to ashthekid's topic in Stoves, Fires & Fireplaces
As long as manufacturer regulations regarding the flue are observed crack on -
You want a box with enough space to bland all the cables in the bottom. you get a 20mm hole saw and drill the holes to suit yourself.
Forget about the pratley boxes Use plastic Ip box, fit with CW glands and IP washers, bottom entry on cables into joint box and it will look smarter and be cheaper.
We build a 4x2 timber partition, to bring services up the island, fix units to it and help take weight of granite worktop.
Your choice it’s a couple of cubic metres if it’s 100 or 150mm thick, all depends on the quality of ground, preparation and workmanship. You get one shot to do it right with minimal grief, after that remedial works are a pain and generally a compromise. you could have fibres added to the mix to add reinforcement that way?
- 8 replies
- garden room
- summerhouse
And the top of the wall too.
Lift it up to the render or fit a larger pipe onto the vent to extend the length?
https://mytradeproducts.com/products/manthorpe-refurbishment-weep-vent-g952?variant=35033746047129¤cy=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=Cj0KCQjws4aKBhDPARIsAIWH0JU5CUfqV1eeo2PQO7YQMG8aD8lbYNeRbtMdXxuWSnybKiVNCSxwn1IaArxzEALw_wcB would be easy to fit and not damage the render.
I would stop the work now.
How much of 1 meter depth trench to fill with concrete
TonyT replied to Paul Alan's topic in Foundations
Normally trial holes next to the existing building are dug to determine this info and let the structural engineer design the foundations. Layers of mesh in the concrete, potential method of tying into existing foundation, ie rebar resined into existing foundation and into new trench. best to ask the SE -
Don’t tell anyone then, and it will be fine!
Built-in fridge with ice dispenser
TonyT replied to puntloos's topic in Kitchen & Household Appliances
It’s the fridge appliance plumbing that always goes faulty, not my awesome pressure tested plumbing! -
I will stick with the £1 bag of ice from the local shop and the ice tray. hate plumbed in fridge freezers- too many leak and cause damage -
The FiT registration states the equipment installed, so apart from a like for like repair that doesn’t alter the potential output you aren’t to change components. Unless you want the fit payment stopped and at 55p a unit generated that would be daft.
I would just get a joiner to build it on site
Waiting for 2nd fix, can I fit faceplates myself?
TonyT replied to Mike_M's topic in Regulations, Training & Qualifications
Could have been a fault on the ring, and the customer didn’t want to pay for fault finding/running in new cable, safest way to make safe is to change to 2 radials -
Isn’t that a street fitting that would be a thicker wall construction?
Drill all the holes in one go!
Take the plastic fitting out and cut 1/2” off the end and reintstall.
Mobile Phone Reception issue?
TonyT replied to ashthekid's topic in Networks, AV, Security & Automation
I’ve just moved office and staff with company mobile phones now have an app so that the old landline number calls the mobile phone 2 weeks now and I can hear the ‘landline’ ring but can’t answer it- awesome! -
https://www.screwfix.com/p/everbuild-dpm-polythene-joint-tape-black-20m-x-75mm/713FR?tc=MC3&ds_kid=92700058168037085&ds_rl=1249416&gclid=CjwKCAjwp_GJBhBmEiwALWBQk1-LUP_xatiCxPo8DOc3Ni2W-fG-qKtMXb1nQNB6-xVZ418cAK-aVRoC6MsQAvD_BwE&gclsrc=aw.ds
Mounting hardware can add up, I’m away to DIY 2kW once I sort my garage roof.
We had an aerator in a sewerage plant work loose. cause- the mechanical fitter didn’t blow the dust out properly and overtime it worked loose and vibrated itself to death- site closure, drive from middle England to Fife, Scotland for repair local crane hire on-site redrill and fix 3 days in total. all at the contractors cost! expensive repair cause the fitter thought he knew what he was doing.
