TonyT
Everything posted by TonyT
Landlord should pay the maintenance! if you are the tenant why are you doing all the coatings? strange
Exterior grade filler for wooden eaves.
TonyT replied to epsilonGreedy's topic in Building Materials
Ronseal 2 part filler -
Can’t remember think it was some vegetable based product ( in case of a leak) it was 15 pages, it also discussed his PV, and Lead acid battery then move to Lion batteries.
Sounds like you would be better off just installing a new boiler. if you clarify who the people make changes are slow etc as you will need additional cabling/ equipment to go electric and if that’s the attitude of say a landlord the cheapest option is straight swap with a new boiler.
Options for Replacing garage roof
TonyT replied to TonyT's topic in General Self Build & DIY Discussion
Sorry…. Flat. -
Existing garage. No in roof panels just, surface mounted rails and PV panels- already have them ( second hand) -
Good Morning, looking to hear others opinions on roofing materials. the garage is separate from the house, timber frame, used for storage and a bit of DIY. PV panels will be fitted later. initially looked at metal roofing, then thought about torch on felt, then watched some videos on GRP. What’s the most cost effective DIY solution? thanks in advance tony
no he’s the last person in the house, so he’s just fitting equipment probably on price work. the local authority( tenant liaison officer or somesuch name) and subcontractor will have visited each home a few weeks/months before the install date to measure up the house, explain the disruption and check where equipment can go. Back at the office, some basic heat calcs will be done, and equipment ordered and rough layout drawing produced for the installer. He’s just fitting it as quickly as possible. to make as much money as possible- no different from fitting gas central heating to social housing. I used to walk around with the TLO on some jobs back in the day.
The £5k will just pay for the additional paperwork of the scheme and the inflated price of the installers. look at the PV price while Fit was on the go, look now, same install probably £5k cheaper.
Just buy the ready made version of trowelling mastic . You don’t want to ruin the oven?
Google Hugh Piggot. He builts them, sells plans. Living off grid his experience is well worth looking into
Have a look at the old Navitron website, Nowty did this with a culvert under his house, copper coils submerged. Worked for him
Health and safety isn’t over the top it’s there to protect you, your kids, grandkids workmates at work etc. too many people take short cuts when building.
I disagree. You need to provide training and supervision and unless you are qualified to do so, leave yourself exposed. let the professional provide their own equipment
Plus 1 above. It’s to stop the underside of the kitchen units being destroyed and to comply with gas regs https://www.gassaferegister.co.uk/help-and-advice/gas-cooker-and-hob-appliance-guide/
That’s one thing I’ve never tried actually, doesn’t appeal though, will stick to burning gas until I’m at an insulation stage to go with an alternative heat source.
No part p in Scotland?
Building control definitely applied, they were all over my house for 20 seconds before the issued the completion certificate
I’ve just re read one of my posts where I say 430 volt to earth- clearly I was being a twat apologies for the confusion….
On your drawing connections D&E are connected together- that’s the neutral and earth, so measuring any phase to neutral and phase to earth will have the same reading
neutral and earth are joined together so effectively the same when putting voltmeter on line to earth
John ward is good at explaining things
