TonyT
    6
Everything posted by TonyT
  1. The swa has been glanced in a metal box and the live and neutrals are passing through the box to prevent a joint. The earth cable at the bottom of the box is supplying a flying lead to an earth somewhere else? Without seeing the whole installation at least that looks well done
  2. Indeed, if they missed the flue inspection for all those years, they probably won’t even bother looking in the hatch, just happy that a hatch is there ?
  3. Hope there is some surge protection in the building with all that expensive gear! love the panel, and can’t wait to see some pics energised, I’m a fan of this type of set up at work! , but not at home I’m afraid..
  4. The one thing you may get pulled up on is the lack of clamps supporting the flue, effectively all the weight of the bends , pipe, terminal piece are sitting on the flue on the boiler.. Pipe clamps with threaded rod are normally used to either hang of timber work or masonry.
  5. Seems close to standard persimmon homes extras. builder probably gave you the £60 figure before he spoke to the spark, extras/day works are where everyone in the trade makes money! a friend unfortunately bought one of their homes
  6. As long as the voltage is the same and the head physically fits no issues in swapping out actuators
  7. Likewise I think I will add some underground ducts in the next phase of external works and save some grief in future.
  8. spend money on good products, installed properly and you will reduce your maintenance costs, keep all 3 flats the same to standardise spares.
  9. I was only talking about heating as per the OP request.
  10. Use a 3 core cable the same size as the rest of the lighting in the property. take 1 cable from the isolation switch position, if this was the uk you would use a fused switched spur to allow you to switch and fuse it down to the first light, and then from the first light to the second light and so on.
  11. My first flat was a new build one bedroom flat all electric that was 25 years ago storage in hall storage in lounge with convector panel heaters everywhere else electric shower. E7 supply no hassle. now insulate to the max. storage in hall storage in lounge with convector panel heaters everywhere else electric shower. so the only change would be to insulate to a higher standard to reduce heat loss.
  12. The 4 pairs in the cat 5 are split, 3 do power 1 pair does data. that’s what industry has done for decades. So the cat 5 can do IP based camera or analogue HD. That’s what I have , happy with 1080p resolution.
  13. https://heatmisershop.co.uk/?gclid=EAIaIQobChMI1_aImaWh7QIVQflRCh3fCwOSEAAYASAAEgK53PD_BwE
  14. You can use normal analogue HD cameras with baluns on the cat 5 cable and go old school, get a DVR 1TB hard disk away you go old skool rulz
  15. I would run a radial for the fridge and freezer so that only the appliance/circuit itself can trip that circuit minimising grief in my life..
  16. Well even a stelrad double panel double convector could be considered designer compared to a single panel radiator so the choice is limitless.
  17. Make sure the pipes are sleeved to aid removal for future use, don’t want to fall fowl of the water regs! the internal diameter of the 22mm plastic is way smaller than the 22 mm copper so make sure you allow for this not for this install, but I’m a fan of 10mm copper microbire with white plastic coating. Great to install, etc
  18. I use the festool Hoover!
  19. Plenty of ways to cut this insulation, but I run a decent workshop Hoover next to me to catch most of the particles. Worked a treat
  20. i would repoint with lime mortar, to give a sympathetic repair to the existing building, it will make the building look very smart indeed, the lime has many benefits to period properties
  21. I use dual tech sensors combination of pir/microwave sensors where both sensors have to detect to activate a signal these are in one unit and require 1 cable
  22. Go with the cables if you can it will be worth while having to save change batteries etc, possible interference etc. personally I think it’s better. run 8 core to each point back to the control panel, remember to mark each cable at the control panel.
  23. https://www.mkelectric.com/en-gb/Products/WD/albanyplus/Floormounted/Pages/740MCO.aspx MK do some. i prefer 2amp sockets and switching the table lamps on from the door switch location.
  24. I tried to get 2x900mm sheets of multi panel , merchants quoted the same price as a 1200mm sheet, needed cut so 3 x1200mm it was then. Gives options if ends are damaged. i cut mine down to 2200 from shower tray level. chop saw with metal blade did the aluminium trims no probs
  25. Can you not isolate the flow and return from the boiler and tie in a standard ASHP. Have a large buffer tank with PV immersion dumps
