Roundtuit
    2
Everything posted by Roundtuit
  1. Check ducting prices before you commit; last time I bought some from a merchant, bigger was cheaper due to the volumes they sold.
  2. Sounds like bull$hit. The movement makes it less safe rather than more I reckon. l can't imagine anyone being happy with that. Probably worth getting hold of the manufacturers installer instructions if you can.
  3. Welcome! You're in the right place for advice; no matter how random the question, someone probably has experience to share. Good luck, and we look forward to hearing more!
  4. I used a bit of 9mm ply* to mark a pencil line around the frame as a guide to make sure the tape would be covered by the plasterboard. *with a couple of nails knocked through and bent over to sit on the outer edge of the window frame, otherwise you don't have enough hands...
  5. 'Pass and repass' doesn't automatically give them free reign. Have a look at Harrison v. Duke of Rutland for some of the original case law. I'm sure there's been loads more since. It's not going to solve your problem, but might form the basis of a polite solicitors letter.
  6. If it's a brick outer skin, you need to get the cavity closed properly to provide insulation and a fire break. The timber cheek of the reveal shouldn't be an issue.
  7. Some sensible answers above re: movement due to temperature changes and settling down. Might be worth ruling out squirrels in the loft though; they can be noisy little critters.
  8. Apologies, but I'm going to have to ask why? The windows are already unbalanced and look odd; if you need more light, I'd be trying to work with the existing to achieve something more aesthetically pleasing.
  9. Since I found out how well vegetable oil lifts paint off your hands (I know... proper painters keep it on the brush), I'd be tempted to give that a try. Cheap, easily available, and fairly innocuous. As above, test where it won't be noticeable 😉
  10. Sorry, not a professional by any stretch of the imagination; more of an enthusiastic amateur 🙂 Crack-stitching involves cleaning out a horizontal mortar joint, maybe 50cm either side of the crack, and then embedding a helical steel rod deep in the joint with a resin compound. You can buy kits and diy it, but you really need a professional opinion as to whether it's an appropriate solution for your situation.
  11. Like a pheasant?
  12. Black IBC's are used for shipping light-sensitive products. I don't think it extends the life of the IBC itself tbh.
  13. I can't remember the rules, but I think windows may also need safety glass if below a certain height. I think anything you do on the inside is going look a bit 'unusual'. How big a job is it to move the window, or replace with a laminated non-opener?
  14. I suspect the timber is a later addition to try and support the brickwork. Looks like the brickwork wasn't bonded very well when it was constructed and has possibly settled a bit over time (not unusual with old chimney stacks; there's a lot of weight there). I'd get a professional to have a look at it for peace of mind, but I'd rake out and stitch maybe every 5th or 6th course.
  15. In a previous job I had to get rid of a dozen or so IBC'S that had gone brittle and got damaged. Not sure of timescales, but definitely several years rather than months, and I can only assume that was through weather and UV exposure. Google suggests a 10yr lifespan for an HDPE IBC, so I'd either cover them, or plan to replace if and when.
  16. May be no need for a trap to stop smells if you're not connecting to a waste water system, but is it possible that your mvhr is drawing fresh air through the condensate drain, or losing warm air? Waterless trap on ours.
  17. Of course...🙂
  18. Looking good. A cable tie and a couple of self tappers would be easier than printing perhaps.
  19. Any plaster snots on the floor will just scrape off. I'd wait until plastering is completed to sand the laitance off the screed though, assuming sanding is a requirement.
  20. Yep, less bugs. As above, the only ones that get in are the ones you let in when doors and windows are open, and they don't last long. We let the occasional spider in when opening the bi-folds or French doors, but I think the internal environment is too dry for them to last more than a couple of days.
  21. In what way? I have a layer of insulation between floor & screed. Don't most people?
  22. Heard similar about someone cleaning up after their new puppy. Turns out it had swallowed a few pebbles...
  23. I've got flat/low spot in the gutter above my front door I need to adjust. Visually and functionally it's fine, but as above, the pigeons drink from it and $h!t on the doorstep...
  24. Yup. Make sure you sit down for a pee at night, because when the pump kicks in, you'll $h!t yourself.
