Roundtuit
Everything posted by Roundtuit
I cant claim any expertise, but it doesn't look particularly dodgy to me. Plot addresses are frequently 'land adjacent to ...' or similar. Speak to Approved Inspectors Ltd and ask for a copy of the initial notice referred to in para 2, so as you can see the 'official' scope of works. If electrics/glazing was part of the notice, then I expect certificates were provided to the inspector prior to his sign off.
Recommendations for good landscaping rake
Roundtuit replied to machtucker's topic in Landscaping, Decking & Patios
+1 for steel tarmac rake; they're built to last. Shovel the type 1 as much as possible or you end up raking the big stuff out and leaving the fines that bind it behind. -
Had decided to go with 140mm blocks as 150's seem particularly difficult get hold of, but locally they're all measuring up at 130-135mm... Is there such a thing as a 'true' 140mm block?
Our local Buildbase (now Huws Gray) can only get me a full load they reckon, so it might have to be 140mm with 10mm of frame overhang into the cavity.
I'm finally getting around to building a garage and am planning to use a 150mm oak frame. Ideally, this would sit on a coarse of 150mm wide 7n concrete blocks as they won't be seen but am struggling to find any locally (only need about 65), and Google isn't much help. Can anyone suggest a source, or sensible alternative pls?
Have a look at other houses in the street to see if they've suffered any settlement perhaps. Historic settlement would have happened in the first few years I imagine. Is the water ingress linked maybe? Leaking gutters or downpipes affecting the foundations? That would explain more recent movement. Definitely a professional opinion required.
I lost a wheelbarrow too. Didn't realise it was a 'thing' until now. Keep an eye on Facebook market place for cheap 'disposable' wheelbarrows and use them to destruction; even when they're proper knackered you can often still salvage a spare wheel. Alternatively, save yourself the hassle and get whatever your local BM sells the most of, x2 (one barrow is never enough 😉)
Home renovations after so many so so builders
Roundtuit replied to Shock999's topic in Introduce Yourself
Welcome aboard! The site is a fantastic resource; please chip in where you can. -
Erection of 1.8m fence adjacent to highway
Roundtuit replied to Amala Singh's topic in Planning Permission
Just to be clear; you want us to help you find a way to circumvent the boundary constraints you accepted when you bought the house? -
Treatment Plant discharge into watercourse
Roundtuit replied to Lincolnshire Ian's topic in Waste & Sewerage
It's fairly standard to discharge to a dyke around here, so shouldn't be a problem. I'd guess that you may have to go directly to the dyke rather than via a storm drain, so the roadworks sounds like the challenging part of the proposal. I believe you can mole 110mm pipe, so that might be cost-effective way of negating red tape perhaps? -
It wouldn't be my first choice, but out of interest, why not? If the screw bites, does it matter whether the plug is timber or plastic, or a combination of both? The load will be vertical rather than trying pull the plug out wouldn't it?
As @joe90 suggested would be my first go. Plan B would be to put the screw in part way so you can pull the plug out using pliers on the screw, then start again.
Is this tube of Silicone Sealant probably "dead"?
Roundtuit replied to David001's topic in Waterproofing & Sealants
Corrected. You're welcome. Mrs Pocster
Problem with planning - Two storey rear extension
Roundtuit replied to Tennisman's topic in Planning Permission
As above, BC and Planning are two different things, and you have to comply with both. I think your BCO has overstepped his remit somewhat, however well intentioned, and has got himself in the middle of an embarrassment. I'd have a candid conversation with the planning department, and start working out which of the remedies are cheapest... -
As above, repaint until its covered. Whilst caulk is paintable, it tends to be a bit shiny and paint never takes quite as well as the wall. Not much help now, but that looks like a huge amount of caulk. I only fill the gap and wipe off all excess, rather than run a bead like you would silicon round a bath for example.
Large tree stumps where house will be on the plot- foundation help
Roundtuit replied to Jane W's topic in Foundations
I'd guess that the only complication will be the size of the hole created by the stump removal, and the additional cost of shuttering for the foundations. If these are old stumps and rotten then additional work might be minimal. Even if they're relatively 'new' I can't see it being a a show-stopper. Removing trees in a conservation area is likely to require consent, but Leylandii is unlikely to pose a problem if you follow due process. -
Just for clarity and best advice, what do you need to keep in your garden?
My wife imposed a 'No caravan' condition on our self build, so we rented a bungalow for 18 months. There was certainly an additional cost implication, but on balance she was right. To be fair, we also had 2 young kids and a dog to consider. Maybe if it had just been two of us I might have pushed the caravan route a bit more, but as above, there's the potential for plenty of stress on a relationship without adding to it unnecessarily.
Airtightness detailing - Timber frame to Masonry
Roundtuit replied to john0wingnut's topic in Timber Frame
I'd foam and gap-fill as you build; any air movement through the structure is bypassing the insulation, but your membrane and tape will do the airtightness job. -
I'd foam any gaps between the dpm and frame to minimise cold bridging, but suspect you won't get much in, and that's not really an airtightness solution I don't think. What's the airtightness strategy for the rest of the extension? Membrane taped to masonry? -
Yes, and yes, although I don't recall paying extra for it. You'll also get the design flow rates that you can use for commissioning. Is the cost deducted when you place an order perhaps?
Sorry... dodgy 80's game show reference. Ted Rogers would have liked it....
