Roundtuit
    2
Everything posted by Roundtuit
  1. I cut ours with a bog standard hand saw; you'll soon get your eye in and be able to cut it to a snug fit with minimal foam required (a fraction oversized also fits if you apply a batten and a lump hammerπŸ˜‰). The dust is a b@$tard; wear a mask keep hoovering up!
  2. As @Nickfromwales says, it may not be optimal on paper, but realistically, I struggle to believe it makes a significant difference in most cases. We have the exhaust on the south pitch and intake on the north pitch, mainly to fit around solar panels without using loads of ducting and compromising internal roof space. I balanced the system without a problem, but accept that I have no idea which way the wind, if any, was blowing at the time. The system has continued to do it's job with no noticeable difference in performance over the last few years, regardless of weather, which is fine for me!
  3. Depends on the look you're after. I used oak sleepers.
  4. It depends on the raft design and how close to your neighbours you're building, but yes, it sounds reasonable. We used a raft rather than piles for our garage foundation which avoided any Party Wall complications.
  5. We've done exactly that with no noticeable issues. Exhaust is on the south side of the roof, and intake on the north pitch.
  6. Check ducting prices before you commit; last time I bought some from a merchant, bigger was cheaper due to the volumes they sold.
  7. Sounds like bull$hit. The movement makes it less safe rather than more I reckon. l can't imagine anyone being happy with that. Probably worth getting hold of the manufacturers installer instructions if you can.
  8. Welcome! You're in the right place for advice; no matter how random the question, someone probably has experience to share. Good luck, and we look forward to hearing more!
  9. I used a bit of 9mm ply* to mark a pencil line around the frame as a guide to make sure the tape would be covered by the plasterboard. *with a couple of nails knocked through and bent over to sit on the outer edge of the window frame, otherwise you don't have enough hands...
  10. 'Pass and repass' doesn't automatically give them free reign. Have a look at Harrison v. Duke of Rutland for some of the original case law. I'm sure there's been loads more since. It's not going to solve your problem, but might form the basis of a polite solicitors letter.
  11. If it's a brick outer skin, you need to get the cavity closed properly to provide insulation and a fire break. The timber cheek of the reveal shouldn't be an issue.
  12. Some sensible answers above re: movement due to temperature changes and settling down. Might be worth ruling out squirrels in the loft though; they can be noisy little critters.
  13. Apologies, but I'm going to have to ask why? The windows are already unbalanced and look odd; if you need more light, I'd be trying to work with the existing to achieve something more aesthetically pleasing.
  14. Since I found out how well vegetable oil lifts paint off your hands (I know... proper painters keep it on the brush), I'd be tempted to give that a try. Cheap, easily available, and fairly innocuous. As above, test where it won't be noticeable πŸ˜‰
  15. Sorry, not a professional by any stretch of the imagination; more of an enthusiastic amateur πŸ™‚ Crack-stitching involves cleaning out a horizontal mortar joint, maybe 50cm either side of the crack, and then embedding a helical steel rod deep in the joint with a resin compound. You can buy kits and diy it, but you really need a professional opinion as to whether it's an appropriate solution for your situation.
  16. Like a pheasant?
  17. Black IBC's are used for shipping light-sensitive products. I don't think it extends the life of the IBC itself tbh.
  18. I can't remember the rules, but I think windows may also need safety glass if below a certain height. I think anything you do on the inside is going look a bit 'unusual'. How big a job is it to move the window, or replace with a laminated non-opener?
  19. I suspect the timber is a later addition to try and support the brickwork. Looks like the brickwork wasn't bonded very well when it was constructed and has possibly settled a bit over time (not unusual with old chimney stacks; there's a lot of weight there). I'd get a professional to have a look at it for peace of mind, but I'd rake out and stitch maybe every 5th or 6th course.
  20. In a previous job I had to get rid of a dozen or so IBC'S that had gone brittle and got damaged. Not sure of timescales, but definitely several years rather than months, and I can only assume that was through weather and UV exposure. Google suggests a 10yr lifespan for an HDPE IBC, so I'd either cover them, or plan to replace if and when.
  21. May be no need for a trap to stop smells if you're not connecting to a waste water system, but is it possible that your mvhr is drawing fresh air through the condensate drain, or losing warm air? Waterless trap on ours.
  22. Of course...πŸ™‚
  23. Looking good. A cable tie and a couple of self tappers would be easier than printing perhaps.
  24. Any plaster snots on the floor will just scrape off. I'd wait until plastering is completed to sand the laitance off the screed though, assuming sanding is a requirement.
