Oz07
Everything posted by Oz07
Passive raft vs traditional (strip/trench) costs assesment
Oz07 replied to SuperJohnG's topic in Foundations
Does whatever your cladding the frame with have an impact too? Any kind of masonry don't you end up with a mini strip found around the outside sure one member had here -
The mode ones weren't too dear I forget which online retailer sells them
Should be an 8" pipe not 6" but I like living on the edge. Insulation and stainless steel scouring pads as packing as per @Jeremy Harris advice
Most expensive trade, you’ve had.
Oz07 replied to Russell griffiths's topic in General Self Build & DIY Discussion
Bet it's not on day rate. Fair play -
What kind of building trade quote a crazy hourly rate? I reckon 30quid he would be about top line in Midlands without being a super specialist. Whereas m2 blokes can earn 500 in a day on the right job. What's a tiler earnon a good day @nod? -
I've gone for a frameless full enclosure to 2 sides with pivot door. Less places for the gunk as @joe90 says but still keeps all the splash in. I've got a rainfall head and reckon you'd need 1500mm to avoid splash
I find the most expensive people are on a m2 rate or fixed price. Nobody really comes out with crazy day rates. -
Surely he doesn't climb for nothing. Bet its more of a lop it job -
Has that skirting firred up yet next to shower @joe90? I found the mitres in my old place firring after being mopped near even though glued well. I used timber skirts in this place but even with knitting some have come through. Everything is crap now. How much better is MR mdf in real life?
Yep done that a few times
They always charge more for slip couplers than normal. It's a rip off
Don't think you should be relying on grout regardless.
Went halfs with my mate on on of those kind of lifters recently. Don't you find them flimsy? Might just be the way he put it together. I've defintley used better. What gun you using for the screws I got one of the dewalt ones good for the money.
Casting thin concrete.
I'd try grano rather than conc. Like a benching mix -
@nod didn't have a basement like you. Just screw up into the blocks if you can't use any proprietary fixing strap/band
No way will a surveyor ever notice 30mm. 300 maybe. Anyway I'm sure there's an indemnity for such situations
Had the exact same problem on a job. Gable fronted dormer bungalow. I caught it as I was putting the trimmer in for to floor joists thinking how the hell are these stairs going to work with that valley coming down architects had drawn it too far forward. I pushed the trimmer back 3 or4 ft luckily it didn't knacker the clients layout
Is it already dry overhead?
Keeping it Internally Down to a Dull Roar
Oz07 replied to ToughButterCup's topic in Waste & Sewerage
Presumably you will be boxing in? Can't you just acoustically insulate around outside of pipe within the boxing -
I think op is asking in the real world what's likelihood of these systems failing? Could some contaminated ground or a spillage cause damage to the eps? Is rodent damage a genuine concern once the building is finished? Can rats burrow? Are they likely to burrow and chew through eps? All valid questions id have thought I'll leave it to others with the system to answer as I don't know
Sure the one I worked on went in before Windows and doors.
Really?!
That gypsum based stuff which gets done at 50mm is Bombproof. Have worked ontop of it before
