dpmiller
Everything posted by dpmiller
MVHR cooker hood idea
dpmiller replied to woodman's topic in Mechanical Ventilation with Heat Recovery (MVHR)
If the duct runs vertical for a bit, there are good sealed gravity flaps available. That's the route I took. Motorised damper is another possibility. -
Relocating boiler to under stairs cupboard
dpmiller replied to jayc89's topic in Boilers & Hot Water Tanks
better that than acidic condensate dripping and marking whatever's beneath it. -
Isn't quoted boiler efficiency combustion efficiency? Certainly the average combustion analyser gives efficiency numbers based purely on this, it cares not what the water temperature is...
- 91 replies
- uwc
- energy use
Does anyone understand how ADSL broadband actually works?
dpmiller replied to ProDave's topic in Boffin's Corner
there are other brands of router that have built in NAS, I know Draytek often do. I've now got two old routers reconfigured as access points/ switches hanging off the Huawei 4g one. One is a Talktalk homehub thingy, the other is a Draytek 2850. It's got a USB that will run either as a printer server, an NAS, or take a 3/4g dongle for failover purposes. -
Mobile Phone Reception issue?
dpmiller replied to ashthekid's topic in Networks, AV, Security & Automation
Band 1 is 2100MHz I think GPRS is a slow data connection, your local mast isn't 3g is it? -
Is the Howdens account in your name or the Builder's?
I wanted to retain our existing panasonic fax/ DECT base and acquired a Cisco SPA232D adaptor. I first configured it for a cheapo geographic number from the provider to test it's functionality and to get a fixed phone at the site, and it has been working well. -
I'm just awaiting our number port to VOIP completing, and then I will be pleased to be shot of any copper connection to BT. Outgoing calls are working already, inbound is to switch on Tuesday. -
And we're in. So much still to do, but we need to move on the "other place" before the market dies off.
- 367 replies
- 2
- ireland
- timber frame
no, more like this: https://www.amazon.co.uk/150mm-White-Window-Plastic-Capping/dp/B077SYJZNH
bit of bullnose pvc cut to suit.
Acorn nut instead of ordinary one?
https://www.toolstation.com/screws-fixings/galvanised-nails/c107 "bright" means raw uncoated metal. edit: and these for the joist hangers https://www.toolstation.com/sheradised-joist-hanger-nail/p96841
Hep2O Sleves/pipe-inserts Stuck in Hep2O Fittings
dpmiller replied to GandyP's topic in Introduce Yourself
yep, had this too. Shame, as some other brands can be unscrewed to make removal easier /ducks -
It's a similar scheme to my own, but as well as using a Laddomat-style load unit, I've also chosen to use a stove with a cooling coil in it for boil protection. You might want to consider this safety aspect yourself- maybe using an STS valve to supply cold mains to the bottom of the store in the case of a catastrophic overheat?
ridge tiles Does this make sense?
dpmiller replied to Confused123's topic in Roofing, Tiling & Slating
the flat roof is level with- or slightly above- the roof peak? -
prices don't look too bad to be but will you be actually saving very much once you get all the mounting kit locally, and deal with any Duties and the onward freight from "London Port"?
do you actually need the legionella cycle?
heated rear window repair paint.
I'd be checking for loose terminal screws in the CU. L,N and E...
Alternative broadband supplier questions
dpmiller replied to ProDave's topic in Networks, AV, Security & Automation
Our road had had fibre run along it as part of the Project Stratum initiative- which is for externally-funded rural FTTP. But I can't get it because there's currently no copper phone line to the house. And the local exchange is apparently now closed to new copper connections... I'll be sticking with the 4g I think. -
what 4g options do you have? -
Is anyone else data logging their fridge?
dpmiller replied to Radian's topic in Kitchen & Household Appliances
does the current unit have a condenser fan and could it have failed? Undercounter integrated certainly do.
