dpmiller
    4
Everything posted by dpmiller
  1. @markocosic that was my feeling too. But the ASHP unit itself has some interesting features- more liquid and vapour injection modes I think?
  2. RED are worth a look too as they have a couple of tricks to get to efficiency tailored per install. Pity the hydronic system is so different to everyone elses'...
  3. UFH wiring hubs can have a dry contact for each channel and you can do nifty linking of the inputs and outputs to give different combos. I've one of these (Hetta branded, but they don't sell them any more) https://www.aliexpress.com/item/4000221789143.html with four thermostats. Multiple stats can be assigned to a channel, and channels can be paralleled also. Plus an additional dry, and a live mains contact.
  4. I think that cover just clips over- try gently levering away from the door just where the hole is for the Allen...
  5. How fancy are you wanting? We just wanted UPVC and got good pricing and service from Turkingtons.
  6. it's an NN-CF760, but looking at the current range you'd probably need to go up to one of the steam units to get a comparable spec?
  7. ^ do that a couple of times and you could've paid for an air fryer... We've a Panasonic flatbed combi and it's a super thing. It will do all three modes simultaneously (has a proper oven element) and it's inbuilt programs for pizza and jacket spuds are very good indeed.
  8. some info here ST https://refrigerationclub.com/oil-compatible-coolant/
  9. no the logic is that the startup of the compressor is controlled, and so oil and gas can be gently redistributed rather than with a switch-start 1ph machine the pump is "blocked" from starting by the liquid refrigerant same thing applies to air compressors- a switch-start machine has a valve built into the pressure switch to "unload" the pump head until the rpms and output pressure build. Switching the compressor on at the wall instead of the airswitch results in a humming noise and a blown fuse...
  10. @JohnMo yes the supply to the ASHP is singlephase, but the inverter converts it to a nice controllable voltage-, current-, and frequency- controlled 3phase.
  11. "single phase" there means it doesn't apply to any inverter units as they use a 3-ph compressor and slowly ramp up speed, automatically clearing down gently with no "protector" to trip out anyway...
  12. @Tamdray where did the last photo in your post come from as it's from a different door?
  13. I do wonder how accurate the readings of power analysers are vs certified meters, especially at the low end and with odd power factors...
  14. Is there a maintenance procedure for clearing it of mould, insects etc?
  15. If it's not actually leaking, could you not just add another expansion vessel elsewhere in the system?
  16. something like this https://www.ebay.co.uk/itm/255271428161 as the rubber seal works commendably well. I did however glue a washer onto each flap, to weight it a bit more and ensure it *only* opened with the strong flow from the hood. For motorised, you're probably looking for a spring-return fire damper unit, as the cheap chinese motorised units require an odd switching logic that would be difficult to integrate with our way of wiring things, IMO.
  17. what's the thermostat on the heater set to?
  18. If the duct runs vertical for a bit, there are good sealed gravity flaps available. That's the route I took. Motorised damper is another possibility.
  19. better that than acidic condensate dripping and marking whatever's beneath it.
  20. Isn't quoted boiler efficiency combustion efficiency? Certainly the average combustion analyser gives efficiency numbers based purely on this, it cares not what the water temperature is...
  21. there are other brands of router that have built in NAS, I know Draytek often do. I've now got two old routers reconfigured as access points/ switches hanging off the Huawei 4g one. One is a Talktalk homehub thingy, the other is a Draytek 2850. It's got a USB that will run either as a printer server, an NAS, or take a 3/4g dongle for failover purposes.
  22. Band 1 is 2100MHz I think GPRS is a slow data connection, your local mast isn't 3g is it?
  23. Is the Howdens account in your name or the Builder's?
  24. I wanted to retain our existing panasonic fax/ DECT base and acquired a Cisco SPA232D adaptor. I first configured it for a cheapo geographic number from the provider to test it's functionality and to get a fixed phone at the site, and it has been working well.
  25. I'm just awaiting our number port to VOIP completing, and then I will be pleased to be shot of any copper connection to BT. Outgoing calls are working already, inbound is to switch on Tuesday.
