dpmiller
Everything posted by dpmiller
How to seal around the stove to insulation pass through?
dpmiller replied to Andeh's topic in Stoves, Fires & Fireplaces
^ yep. We used Ignis Protect to go through the walls in an airtight manner. -
can we see these please?
Solar PV and hot Water Diverter - Advice
dpmiller replied to bob the builder 2's topic in General Plumbing
How many amps is an IEC plug rated for continuous? -
It's not "above" if it's inside and not exposed to UV
Bog-standard Apeer composite door here, confirmed as being 0.94
Yep, the Carel controller on the CoolEnergy unit can do this too- four programmable time/ temp steps, for heating, cooling, and DHW at each step.
The finances / income of self employed sole traders
dpmiller replied to Moonshine's topic in Costing & Estimating
What is your motive for asking tho? Are you trying to second-guess a prospective contractor's own pricing structure, or thinking about going self-employed yourself? -
The big phone switch over/off in 2025
dpmiller replied to Temp's topic in Networks, AV, Security & Automation
For now, BT still cling onto the old geographic rules. One of the reasons I went 4g was that with VOIP I could retain the number, whereas BT refused to let the number even move between sub-exchanges in the same main exchange group. Irony is, now that the number is ported to voip, it could in the future be ported back to BT *anywhere* in the UK... -
openreach no longer offer copper at either of our local exchanges and fibre is looked after by a 3rd party who hasn't completely trunked our road yet. Plus, fibre installs are subsidised under Project Stratum but the area was surveyed prior to our build So 4g it is, for us. the router and voip box are both on UPS, and my old landline number is now safely transferred to VOIP and in my ownership -
UFH - zone not heating up. No flow...
dpmiller replied to Newbuildnewbie's topic in Underfloor Heating
flow gauges act as a coarse NRV do they not? -
NTC sensor + 8m of cable = profit. / in other words, just extend the cable...
why not tho? Seemed like a no-brainer as the wiring was going past a zero-volt relay contact... /if it does ever go off at least I know the emptied property is being purged.
@JohnMo I never said anything about staying in the house...
On the fire/ smoke side of things, will the Aicos all be wired interlinked or will you be having any on wireless? Do you have any need for CO monitoring? gas hob/ woodburner/ whatever? Whilst we're on wireless, I've used an Ei414 fire alarm interface for two functions- MVHR off during fire alerts MVHR boost during CO alerts.
Enclosing hot water cylinder stat in insulation?
dpmiller replied to andyscotland's topic in Boilers & Hot Water Tanks
the temperature calibration will alter a wee bit, but as the cylinder isn't running too hot and there's no big current being switched there's no safety implication IMHO -
^ to avoid any ambiguity, @Conor has a sensor in the buffer that was supplied with the ASHP, some brands don't have this option. I'd suggest if you want to have a thermostat on the buffer, simply putting it in series with the demand signal from the wiring centre might work for your case? If either heat demand or buffer are satisfied the the ASHP will be commanded off, and it'll only come back on again if you still need more heat *and* the buffer has cooled.
thanks guys. @nod Blackstone or Ironwax Gloss?
if we knew what it was then...
anyone? @PeterW @nod
Which ASHPs are more prone to defrost cycles
dpmiller replied to Steve W's topic in Air Source Heat Pumps (ASHP)
they defrost when they need to. If it's iced up sufficiently that the fan can't pull fresh air through, it needs a defrost. Simples. You absolutely *can* get your LWT over 45c, but you'll need to reduce your energy demand to allow it to happen... / I can make mine ice up and need defrosts at around the same intervals, yes. But only by starting it from a cold house, in DHW mode, but leaving the CH circuits open too. -
what's wrong with the stuff you've already got, it's just the same?
